09061326931
09061326931
    HARTING(浩亭)
    弯插,P=5.08mm
    板对板连接器 弯插 针脚数:48Pin 间距:5.08mm 排数:3
09061326931 数据手册
Directory chapter 02 - DIN Power (to 6 A) Types D, E, F, FM, 2F, F9, interface connectors I/U Page 02.10 Type D connectors . . . . . . . . . . . . . . . . . . . . 02.11 Type E connectors . . . . . . . . . . . . . . . . . . . . 02.15 Technical characteristics piggyback connectors . . . . . . . . . . . . . . . . . . . . . . . . 02.20 Piggyback connectors . . . . . . . . . . . . . . . . . 02.21 Technical characteristics types F, F9, FM and 2F . . . . . . . . . . . . . . . . . . . . . . . 02.24 Type F connectors . . . . . . . . . . . . . . . . . . . . 02.25 Type F9 connectors . . . . . . . . . . . . . . . . . . . 02.35 Type FM connectors . . . . . . . . . . . . . . . . . . 02.36 Type 2F connectors . . . . . . . . . . . . . . . . . . . 02.38 Coding systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 02.41 DIN Power to 6 A Technical characteristics types D and E . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 02 . 01 Technical characteristics Number of contacts Type D Type E Contact spacing (mm) Type D Type E 32 48 5,08 male connector 5.08 x 5.08 male connector 2.54 x 5.08 female connector 5.08 x 5.08 Types D and E Current carrying capacity The current carrying capacity is limited by maximum temperature of materials for inserts and contacts including terminals. The current capacity curve is valid for continuous, non interrupted current loaded contacts of connectors when simultaneous power on all contacts is given, without exceeding the maximum temperature. Control and test procedures according to DIN IEC 60 512 Working current Clearance Types D und E Type E male connector row separation 2.54 mm Creepage  3.0 mm  1.6 mm  3.0 mm Working voltage The working voltage also depends on the clearance and creepage dimensions of the pcb itself and the associated wiring Test voltage Ur.m.s. Contact resistance Insulation resistance Temperature range The higher temperature limit includes the local ambient and heating effects of the contacts under load according to the safety regulations of the equipment Explanations see chapter 00 1.55 kV  15 m for wire wrap and solder connections  20 m including crimp connections  1012  – 55 °C … + 125 °C Degree of protection for crimp terminal IP 20 according to DIN 40 050 Electrical termination Male connector Female connector Solder pins for pcb connections Ø 1.0 ± 0.1 mm according to IEC 60 326-3 Wrap posts 1 x 1 mm diagonal 1.34-1.45 mm Solder pins for pcb connections Ø 1.0 ± 0.1 mm according to IEC 60 326-3 Angled solder pins 1 x 1 mm for pcb connections Ø 1.6 ± 0.1 mm Solder lugs Crimp terminal 0.09-1.5 mm² Insertion and withdrawal force 32 way  40 N 48 way  75 N Materials Mouldings Contacts Contact surface Contact zone 1) 02 . 10 Thermoplastic resin, glass-fibre filled, UL 94-V0 Copper alloy Selectively gold plated according to performance level1) Explanation of performance levels see chapter 00 Mating conditions Coding systems Mounting clips see chapter 00 see pages 02.41 and 02.42 see chapter 00 Working current DIN Power to 6 A 6 A max. see current carrying capacity chart Ambient temperature Fitting the crimp contacts After crimping the wires onto the contacts with the help of a crimping tool or an automatic crimping machine the contacts should be correctly oriented and inserted into the cavities of the connector moulding in the required configuration. They snap into position and are firmly held in place. A light pull on the wire assures the correct tensile strength of the contact. When using stranded wires with a gauge below 0.37 mm² an insertion tool is necessary. Removing the crimp contacts The removal tool is inserted into a slot on the side of the respective crimp cavity. This action compresses the contact retaining spring therefore the contact can then be easily withdrawn using a light pull on the wire. This action will cause no damage to the contact/ wire which can be repositioned/refitted as necessary. The drawing demonstrates the crimp removal procedure (max. 5x). Removal tool DIN 41 612 · Type D Number of contacts 32 Male connectors Male connector with angled solder pins Number Contact of contacts arrangement 32 Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 3 09 04 132 7921 30 + 2▲ Male connector with straight solder pins 2 1 09 04 132 6921 04 332 6921b) c)09 04 632 6921c) 09 04 132 2921 09 04 132 6951 04 632 6951c) 09 04 632 2951c) b)09 c)09 32 09 04 132 6922 30 + 2▲ 09 04 132 6952 DIN Power to 6 A Identification Dimensions Angled solder pins Straight solder pins Board drillings Mounting side all holes Dimensions in mm Male connectors with 2 leading contacts [(0.8 mm) pos. a2 and a32] Other contact arrangements on request b) Connectors with snap-in clips see chapter 00 c) Connectors with coding see page 02.42 ▲ 02 . 11 DIN 41 612 · Type D Number of contacts 32 Female connectors DIN Power to 6 A Identification Number Contact of contacts arrangement Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 3 Female connector with solder pins 2.9 mm 32 09 04 232 7832 Female connector with solder pins 4.5 mm 32 09 04 232 7831 Female connector with wrap posts 20 mm 32 09 04 232 7821 32 09 04 232 7823 Female connector with solder lugs 2 1 09 04 232 6832 04 732 6832c) 09 04 232 2832 09 04 232 6831 04 332 6831b) c)09 04 732 6831c) 09 04 232 2831 09 04 232 6821 04 732 6821c) 09 04 232 2821 09 04 232 6823 09 04 232 2823 c)09 b)09 c)09 Dimensions a 20 a 2.9 4.5 Solder pins b Wrap posts l1 Solder lugs Panel cut out Board drillings Contact arrangement View from termination side all holes Mounting side 02 . 12 Dimensions in mm b) c) Connectors with snap-in clips see chapter 00 Connectors with coding see page 02.42 DIN 41 612 · Type D Number of contacts 32 Female connectors Number Contact of contacts arrangement Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 1 09 04 232 7826 09 04 232 6826 09 04 232 2826 Female connector with angled solder pins 1 x 1 mm 32 DIN Power to 6 A Identification Dimensions Fixing bracket Metal 09 06 000 99121) 1) order 2 pieces for one connector Board drillings Mounting side all holes Dimensions in mm 02 . 13 DIN 41 612 · Type D Number of contacts max. 32 Female connectors DIN Power to 6 A Identification Number of contacts Part No. 32 09 04 032 3213 Drawing Dimensions in mm Female connector for crimp contacts Order contacts separately Contact arrangement View from termination side Shell housing 09 03 096 0501 see chapter 20 Identification Wire gauge Identification Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 2 1 Female crimp FC contacts Bandoliered contacts (approx. 2 ,500 pieces) 1 2 3 09 06 000 6484 09 06 000 6481 09 06 000 6482 09 06 000 6474 09 06 000 6471 09 06 000 6472 Bandoliered contacts (approx. 250 pieces) 1 2 3 09 06 000 7484 09 06 000 7481 09 06 000 7482 09 06 000 7474 09 06 000 7471 09 06 000 7472 Individual contacts1) 1 2 3 09 06 000 8484 09 06 000 8481 09 06 000 8482 09 06 000 8474 09 06 000 8471 09 06 000 8472 Female contacts with solder lugs2) (lockable) 09 06 000 6420 FC 1 FC 2 FC 3 1 2 3 Wire gauge mm² AWG Insulation ø mm 0.09 - 0.25 0.14 - 0.56 0.5 - 1.5 28 - 24 26 - 20 20 - 16 0.7 - 1.5 0.8 - 2.0 1.6 - 2.8 Identification Bandoliered contacts Individual contacts 02 . 14 3.5 + 0.5 mm of insulation is stripped from the wires to be crimped Insertion, removal and crimping tools see chapter 30 Packaging unit 1,000 pieces 2) Solder contacts must not be used together with shell housing A. Special contact surface: 2 µm gold. 1) DIN 41 612 · Type E Number of contacts 48 II I Male connectors Number Contact of contacts arrangement Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 3 Male connector with angled solder pins Row separation termination side 5.08 mm I Row separation termination side 2.54 mm II 48 09 05 148 7921 2 09 05 148 6921 05 348 6921b) c)09 05 648 6921c) 09 05 148 2921 05 648 2921c) b)09 46 + 2▲ 48 1 DIN Power to 6 A Identification c)09 09 05 148 6951 09 05 148 7931 09 05 148 6931 09 05 148 2931 09 05 148 6961 46 + 2▲ Dimensions Angled solder pins I II Board drillings Mounting side I II Dimensions in mm Male connectors with 2 leading contacts [(0.8 mm) pos. a2 and a32] Other contact arrangements on request b) Connectors with snap-in clips see chapter 00 c) Connectors with coding see page 02.42 ▲ 02 . 15 DIN 41 612 · complementary to type E Number of contacts 48 DIN Power to 6 A Interface connector I Identification Number of contacts Part No. Drawing Dimensions in mm Interface connector I with solder pins 0.6 x 0.6 mm Performance level 2 acc. to IEC 60 603-2 48 09 05 048 6924 Contact arrangement View from termination side Panel cut out M 2.5 DIN EN ISO 4 032 Board drillings Mounting side 02 . 16 DIN 41 612 · Type E Number of contacts 48 Female connectors Number Contact of contacts arrangement Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 1 09 05 248 6832 09 05 248 2832 Female connector with solder pins 2.9 mm 48 09 05 248 7832 Female connector with solder pins 4.5 mm 48 09 05 248 7831 Female connector with wrap posts 20 mm 48 09 05 248 7821 09 05 248 6821 09 05 248 2821 Female connector with solder lugs 48 09 05 248 7823 09 05 248 6823 09 05 248 2823 Female connector with press-in pins 09 05 248 6831 05 348 6831b) c)09 05 748 6831c) b)09 DIN Power to 6 A Identification 09 05 248 2831 05 748 2831c) c)09 Part Nos. and variants see chapter 04 Dimensions a 2.9 4.5 a 20 b l1 Solder pins Wrap posts Solder lugs Panel cut out Contact arrangement View from termination side Board drillings Mounting side Dimensions in mm b) c) Connectors with snap-in clips see chapter 00 Connectors with coding see page 02.42 02 . 17 DIN 41 612 · Type E Number of contacts max. 48 Female connectors Number of contacts DIN Power to 6 A Identification Part No. Drawing Dimensions in mm Female connector for crimp contacts Order contacts separately 48 09 05 048 3202 05 548 3202c) c)09 Contact arrangement View from termination side Shell housing 09 05 048 0501 see chapter 20 Identification Wire gauge Identification Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 2 1 Female crimp FC contacts Bandoliered contacts (approx. 2 ,500 pieces) 1 2 3 09 06 000 6484 09 06 000 6481 09 06 000 6482 09 06 000 6474 09 06 000 6471 09 06 000 6472 Bandoliered contacts (approx. 250 pieces) 1 2 3 09 06 000 7484 09 06 000 7481 09 06 000 7482 09 06 000 7474 09 06 000 7471 09 06 000 7472 Individual contacts1) 1 2 3 09 06 000 8484 09 06 000 8481 09 06 000 8482 09 06 000 8474 09 06 000 8471 09 06 000 8472 Female contacts with solder lugs2) (lockable) 09 06 000 6420 FC 1 FC 2 FC 3 1 2 3 Wire gauge mm² AWG Insulation ø mm 0.09 - 0.25 0.14 - 0.56 0.5 - 1.5 28 - 24 26 - 20 20 - 16 0.7 - 1.5 0.8 - 2.0 1.6 - 2.8 Identification Bandoliered contacts Individual contacts 02 . 18 3.5 + 0.5 mm of insulation is stripped from the wires to be crimped Insertion, removal and crimping tools see chapter 30 Connectors with coding see page 02.42 1) Packaging unit 1,000 pieces 2) Solder contacts must not be used together with shell housing A. Special contact surface: 2 µm gold. c) DIN Power to 6 A Stamping – state of the art engineering Our claim is quality. Simultaneous and fully automated high-speed stamping of several contacts with small tolerances. 02 . 19 Technical characteristics Number of contacts Working current 16, 32, 48 Current carrying capacity 6 A max. The current carrying capacity is limited by maximum temperature of materials for inserts and contacts including terminals. The current capacity curve is valid for continuous, non interrupted current loaded contacts of connectors when simultaneous power on all contacts is given, without exceeding the maximum temperature. see current carrying capacity chart Clearance 16 ways 32, 48 ways piggyback connectors ≥ 1.6 mm ≥ 1.6 mm Control and test procedures according to DIN IEC 60 512 Creepage ≥ 1.6 mm ≥ 3.0 mm Working voltage The working voltage also depends on the clearance and creepage dimensions of the pcb itself and the associated wiring according to the safety regulations of the equipment Explanations see chapter 00 Contact resistance ≤ 20 mΩ Insulation resistance ≥ 1012 Ω Termination Crimp terminal 0.09-1.5 mm² Working current DIN Power to 6 A 16 ways 32, 48 ways Ambient temperature Materials Mouldings and hoods Contacts Thermoplastic resin, glass-fibre filled Copper alloy Piggyback connectors for interfacing with female connectors with wrap posts 1 x 1 mm The problem of interfacing systems designed for the distribution or collection of electronic signals can be overcome by the use of piggyback connectors. Designed to be mounted on the rear of DIN 41 612 type wire wrap female connectors (1 x 1 mm posts) these piggyback elements can be used to terminate input and output cables. Distance fixing brackets are fitted to provide either a latching or screw fixing facility over the two level wire wrap plane. The female crimp contacts used in these versions are designed for 1 x 1 mm posts. After crimping they can be easily inserted into the chambers of the connector body with the aid of an insertion tool. Insertion errors can be simply rectified with the use of a removal tool. hou2 and 3 row piggyback connectors can be mounted in shell sings C and open hood G. Security is provided by either latches or screws to the distance fixing brackets. 02 . 20 ➀ with shell housing ➁ without shell housing Piggyback connectors III Number of contacts max. 48 II Piggyback connectors for 1 x 1 mm wrap posts Number of contacts Part No. 16 09 04 016 3201 I 32 09 04 032 3215 II 48 09 05 048 3204 Identification Drawing IV Dimensions in mm Piggyback connector for crimp contacts Order contacts separately Female FC crimp contacts FC1 individual contacts1) FC2 FC3 Bandoliered contacts FC1 (approx. 2,500 pcs.) FC2 FC3 Mateable with 1 x 1 mm wrap posts Distance fixing brackets for female connectors Type D Type E 09 06 000 6464 09 06 000 6461 09 06 000 6462 09 06 000 6454 09 06 000 6451 09 06 000 6452 III top (pos. 2) 09 06 000 9936 IV bottom (pos. 32) 09 06 000 9937 Packaging unit 1,000 pieces Wire gauge mm² AWG Insulations ø mm 1 0.09-0.25 28-24 0.7-1.5 2 0.14-0.56 26-20 0.8-2.0 Identification 0.50-1.50 20-16 1.6-2.8 3 1 0.09-0.25 28-34 0.7-1.5 0.14-0.56 26-20 0.8-2.0 2 0.50-1.50 20-16 1.6-2.8 3 3.5 + 0.5 mm of insulation is stripped from the wires to be crimped. Crimping tools see chapter 30 top (pos. 2) 09 04 000 9907 bottom (pos. 32) 09 04 000 9906 Type F 1) Identification DIN Power to 6 A I Types D, E bottom top Type F bottom top 02 . 21 Piggyback connectors Identification Drawing Dimensions in mm Mounting examples of piggyback connectors M 2.52) DIN EN ISO 4 032 DIN Power to 6 A M 2.5 x 202) DIN EN ISO 1207 Type D Type E Type F without housings with housings M 2.52) DIN EN ISO 4 032 Shell housing C 09 03 096 0501 (15 mm) 09 05 048 0501 (20 mm) Locking levers 09 02 000 9902 09 02 000 9903 see chapter 20 02 . 22 1) 2) Number of contacts piggyback connector Doesn’t belong to the scope of supply see chapter 20 Type F M 2.52) DIN EN ISO 4 032 Type E M 2.5 x 252) DIN EN ISO 1207 M 2.5 x 252) DIN EN ISO 1207 M 2.52) DIN EN ISO 4 032 Type D Open hood G 09 06 000 9957 DIN Power to 6 A HARTING for Railway Transportation 02 . 23 Technical characteristics Types F, F9, FM and 2F Number of contacts Type F Type FM Type 2F Type F9 Current carrying capacity 48, 32 45 max. 24 max. 9 Contact spacing (mm) 5.08 Working current 6 A max. The current carrying capacity is limited by maximum temperature of materials for inserts and contacts including terminals. The current capacity curve is valid for continuous, non interrupted current loaded contacts of connectors when simultaneous power on all contacts is given, without exceeding the maximum temperature. Control and test procedures according to DIN IEC 60 512 Clearance ≥ 1.6 mm Creepage ≥ 3.0 mm Working voltage The working voltage also depends on the clearance and creepage dimensions on the pcb itself and the associated wiring according to the safety regulations of the equipment Explanations see chapter 00 Test voltage Ur.m.s. 1.55 kV (contact-contact) 2.5 kV (contact-ground) Contact resistance ≤ 15 mΩ for wire wrap and solder connections ≤ 20 mΩ including crimp connections Insulation resistance ≥ 1012 Ω Temperature range – 55 °C … + 125 °C The higher temperature limit includes the local ambient and heating effects of the contacts under load Electrical termination Male connector Female connector Distributor Solder pins for pcb connections Ø 1 ± 0.1 mm according to IEC 60 326-3 Wrap posts 1 x 1 mm diagonal 1.34-1.45 mm Crimp terminal 0.09-1.5 mm² Wrap posts 1 x 1 mm diagonal 1.34-1.45 mm Solder pins for pcb connections Ø 1 ± 0.1 mm according to IEC 60 326-3 Angled solder pins 1 x 1 mm for pcb connections Ø 1.6 ± 0.1 mm Solder lugs Crimp terminal 0.09-1.5 mm² Crimp terminal 0.09-1.5 mm² Insertion and withdrawal force 48 way ≤ 75 N 45 way ≤ 70 N 32 way ≤ 50 N 24 way ≤ 37 N Materials Mouldings Contacts Thermoplastic resin, glass-fibre filled, UL 94-V0 Copper alloy Contact surface Contact zone Selectively plated according to performance level1) 1) Explanation of performance levels see chapter 00 02 . 24 Mating conditions Coding systems Mounting clips see chapter 00 see pages 02.41 and 02.42 see chapter 00 Working current DIN Power to 6 A see current carrying capacity chart Ambient temperature Fitting the crimp contacts After crimping the wires onto the contacts with the help of a crimping tool or an automatic crimping machine the contacts should be correctly oriented and inserted into the cavities of the connector moulding in the required configuration. They snap into position and are firmly held in place. A light pull on the wire assures the correct tensile strength of the contact. When using stranded wires with a gauge below 0.37 mm² an insertion tool is necessary. Removing the crimp contacts The removal tool is inserted into a slot on the side of the respective crimp cavity. This action compresses the contact retaining spring therefore the contact can then be easily withdrawn using a light pull on the wire. This action will cause no damage to the contact/ wire which can be repositioned/refitted as necessary. The drawing demonstrates the crimp removal procedure (max. 5x). Removal tool DIN 41 612 · Type F Number of contacts 48, 32 Male connectors Male connector with angled solder pins1) Number Contact of contacts arrangement 48 32 32 1 leading contact (position z 32) Performance levels according to IEC 60 603-2. Explanation chapter 00 3 09 06 148 7901 09 06 132 7901 06 332 7901b) b)09 09 06 132 7931 47 + 1 31 + 1 2 leading contacts (positions b 2 + b 32) Part No. 09 06 132 7921 46 + 2 2 1 09 06 148 6901 06 348 6901b) 09 06 148 2901 09 06 132 6901 09 06 132 2901 09 06 132 6931 06 332 6931b) 09 06 132 2931 09 06 148 6921 09 06 348 6921b) b) 09 06 148 2921 09 06 132 6921 09 06 132 2921 09 06 148 6925 09 06 148 2925 b)09 b)09 DIN Power to 6 A Identification Dimensions Angled solder pins Board drillings Mounting side all holes Dimensions in mm 1) b) With shroud coding, see also page 02.41 Connectors with snap-in clips see chapter 00 02 . 25 DIN 41 612 · complementary to type F Number of contacts 48, 32 DIN Power to 6 A Interface connectors I Identification Number Contact of contacts arrangement Part No. Drawing Dimensions in mm Performance level 1* Interface connector I with solder pins1) 0.6 x 0.6 mm 48 09 06 048 2905 32 09 06 032 2905 32 09 06 032 2941 Board drillings Mounting side all holes Performance level 1* Interface connector I with wrap posts1) 1 x 1 mm without nut 48 09 06 048 2903 with nut 48 09 06 048 2963 without nut 32 09 06 032 2903 Contact arrangement with nut 32 Panel cut out 02 . 26 * Acc. to IEC 60 603-2, performance level 2 on request 1) With shroud coding, see also page 02.41 09 06 032 2963 View from termination side DIN 41 612 · complementary to type F Number of contacts 48 Identification Number of contacts Part No. Drawing Dimensions in mm Interface connector I utilising female crimp contacts1) DIN Power to 6 A Interface connector I Order crimp contacts separately see page 02.29 Performance level 1 acc. to IEC 60 603-2 48 09 06 048 2906 Contact arrangement View from termination side Shell housing see chapter 20 Panel cut out Mounted in shell housing B 02 . 27 1) With shroud coding, see also page 02.41 DIN 41 612 · complementary to type F Number of contacts 48 DIN Power to 6 A Interface connector U Identification Number of contacts Part No. Drawing Dimensions in mm Interface connector U with wrap posts 1 x 1 mm Performance level 1 acc. to IEC 60 603-2 48 09 06 048 2981 Contact arrangement M3x8 DIN EN ISO 1207 M 2.5 x 6 DIN EN ISO 1207 Mounting example View from termination side 02 . 28 DIN 41 612 · Type F Number of contacts max. 48 Identification Number of contacts Part No. 48 09 06 248 3201 Drawing Dimensions in mm Female connector for crimp contacts1) Order contacts separately Contact arrangement DIN Power to 6 A Female connectors View from termination side Shell housing see chapter 20 Identification Wire gauge Identification Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 2 1 Female crimp FC contacts Bandoliered contacts (approx. 2 ,500 pieces) 1 2 3 09 06 000 6484 09 06 000 6481 09 06 000 6482 09 06 000 6474 09 06 000 6471 09 06 000 6472 Bandoliered contacts (approx. 250 pieces) 1 2 3 09 06 000 7484 09 06 000 7481 09 06 000 7482 09 06 000 7474 09 06 000 7471 09 06 000 7472 Individual contacts2) 1 2 3 09 06 000 8484 09 06 000 8481 09 06 000 8482 09 06 000 8474 09 06 000 8471 09 06 000 8472 Female contacts with solder lugs3) (lockable) 09 06 000 6420 FC 1 FC 2 FC 3 1 2 3 Wire gauge mm² AWG Insulation ø mm 0.09 - 0.25 0.14 - 0.56 0.5 - 1.5 28 - 24 26 - 20 20 - 16 0.7 - 1.5 0.8 - 2.0 1.6 - 2.8 Identification Bandoliered contacts Individual contacts 3.5 + 0.5 mm of insulation is stripped from the wires to be crimped Insertion, removal and crimping tools see chapter 30 With shroud coding, see also page 02.41 2) Packaging unit 1,000 pieces 3) Solder contacts must not be used together with shell housing A. Special contact surface: 2 µm gold. 1) 02 . 29 DIN 41 612 · Type F Number of contacts 48, 32 Female connectors DIN Power to 6 A Identification Female connector with solder pins 3.7 mm1) Female connector with solder pins 4.5 mm1) Number Contact of contacts arrangement Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 1 09 06 248 7848 09 06 248 6848 09 06 248 2848 32 09 06 232 6848 09 06 232 2848 32 09 06 232 6858 09 06 232 2858 09 06 248 6835 09 06 248 2835 32 09 06 232 6835 09 06 232 2835 32 09 06 232 6845 09 06 232 2845 48 48 09 06 248 7835 Dimensions row position a 3.7 4.5 Solder pins Board drillings Mounting side all holes position row 02 . 30 Dimensions in mm 1) With shroud coding, see also page 02.41 DIN 41 612 · Type F Number of contacts 48, 32 Female connectors Female connector with wrap posts 22 mm Female connector with solder lugs open solder lug Number Contact of contacts arrangement Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 1 48 09 06 248 7821 09 06 248 6821 09 06 248 2821 32 09 06 232 7821 09 06 232 6821 09 06 232 2821 32 09 06 232 7831 09 06 232 6831 09 06 232 2831 48 09 06 248 7823 09 06 248 6823 09 06 248 2823 32 09 06 232 7823 09 06 232 6823 09 06 232 2823 32 09 06 232 7843 09 06 232 6843 09 06 232 2843 DIN Power to 6 A Identification Dimensions Solder lugs Panel cut out Contact arrangement View from termination side Dimensions in mm Identification strips for female connectors with wrap posts 09 06 000 9939 02 . 31 DIN 41 612 · Type F Number of contacts 48, 32 DIN Power to 6 A Female connectors Identification Female connector “low profile” with solder pins 3.2 mm Female connector “low profile” with solder pins 4.5 mm Number Contact of contacts arrangement 48 Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 1 09 06 248 7833 09 06 248 6833 09 06 248 2833 32 09 06 232 6833 32 09 06 232 6893 48 09 06 248 7834 32 09 06 248 6834 09 06 248 2834 09 06 232 6834 32 09 06 232 7894 Female connector with press-in pins 09 06 232 6894 09 06 232 2894 Part Nos. and variants see chapter 04 Dimensions a 3.2 4.5 Board drillings Solder pins all holes Mounting side 02 . 32 Dimensions in mm DIN 41 612 · Type F Number of contacts 48, 32 I Identification Female connector with angled solder pins 1 x 1 mm Number Contact of contacts arrangement II Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 3 2 1 I 48 09 06 248 6826 32 DIN Power to 6 A Female connectors 09 06 232 6826 II performance level 3 performance level 1 or special or special gold plating 48 09 06 248 6836 on request on request 32 09 06 232 6846 32 09 06 232 6836 Dimensions gold plating I II Fixing bracket 1) Order 2 pieces for one connector Board drillings Mounting side Metal 09 06 000 99121) for version I Plastic 09 06 000 99751) for version II I II Dimensions in mm 02 . 33 DIN 41 612 · complementary to type F Number of contacts 64, 16 DIN Power to 6 A Universal adaptors Identification Number of contacts Part No. 4x4 09 06 016 3301 16 x 1 09 06 016 3302 16 x 4 09 06 064 3302 Universal adaptor utilising crimp contacts crimp contacts see page 02.29 Panel cut out 02 . 34 Drawing Dimensions in mm DIN 41 612 · complementary type F9 Number of contacts max. 9 Identification Number of contacts Part No. Drawing Dimensions in mm Female connector for crimp contacts fixing Order contacts separately 9 DIN Power to 6 A Female and male connectors 09 06 209 3201 polarization Female crimp contacts see page 02.29 Male connector for crimp contacts Order contacts separately 9 09 06 109 3401 fixing Male crimp contacts see page 02.38 polarization 02 . 35 DIN 41 612 · complementary type FM Number of contacts 45 DIN Power to 6 A Male connectors Identification Number of contacts Part No. Drawing Dimensions in mm Male connector 29 angled solder pins 16 cavities for male crimp contacts Performance level 1 acc. to IEC 60 603-2 45 09 06 145 2971 crimp contacts see page 02.38 Board drillings Mounting side all holes 02 . 36 1) A special 48 way version with 3 extra angled solder contacts at position 16 (rows d, b, z) can be supplied DIN 41 612 · complementary type FM Number of contacts 45 I Number of contacts Identification Part No. Drawing Dimensions in mm Female connector Female moulding with 21 wrap posts 22 mm 45 09 06 045 2871 with 21 solder pins 4.5 mm 45 09 06 045 2875 Latches Performance level 1 acc. to IEC 60 603-2 DIN Power to 6 A Female connectors Crimp moulding is supplied with the female moulding Crimp moulding for 24 female crimp contacts I 09 06 024 3202 Contact arrangement View from termination side crimp contacts see page 02.29 Panel cut out Removal tool for the crimp moulding 09 99 000 0172 The crimp moulding can be extracted with the help of the removal tool. 02 . 37 DIN 41 612 · complementary type 2F Number of contacts max. 24 Interface connector I DIN Power to 6 A Identification Number of contacts Part No. 24 09 26 024 3411 Drawing Dimensions in mm Interface connector I for male crimp contacts Order contacts separately Identification Wire gauge Identification Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 2 1 09 06 000 9564 09 06 000 9561 09 06 000 9562 09 06 000 9544 09 06 000 9541 09 06 000 9542 Male crimp FC contacts Bandoliered contacts (approx. 2 ,500 pieces) Bandoliered contacts (approx. 2 50 pieces) Individual contacts1) FC 1 FC 2 FC 3 1 2 3 2 3 09 06 000 5541 09 06 000 5542 1 2 3 1 2 3 09 06 000 9574 09 06 000 9571 09 06 000 9572 Wire gauge mm² AWG Insulation ø mm 0.09 - 0.25 0.14 - 0.56 0.5 - 1.5 28 - 24 26 - 20 20 - 16 0.7 - 1.5 0.8 - 2.0 1.6 - 2.8 09 06 000 9554 09 06 000 9551 09 06 000 9552 Identification Bandoliered contacts Individual contacts 02 . 38 3.5 + 0.5 mm of insulation is stripped from the wires to be crimped Insertion, removal and crimping tools see chapter 30 1) Packaging unit 1,000 pieces DIN 41 612 · complementary type 2F Number of contacts max. 24 Identification Number of contacts Part No. Drawing Dimensions in mm Interface connector U with wrap posts 1 x 1 mm DIN Power to 6 A Interface connector U Performance level 1 acc. to IEC 60 603-2 24 09 26 024 2981 Contact arrangement View from termination side Mounting example M3x8 DIN EN ISO 12 07 02 . 39 DIN 41 612 · complementary type 2F Number of contacts max. 24 DIN Power to 6 A Female connectors Identification Number of contacts Part No. 24 09 26 024 3201 Drawing Dimensions in mm Female connector for crimp contacts Order contacts separately see page 02.29 Shell housing A with integrated fixing screws 09 26 024 0401 Open hood Supplied with: Open hood 1x Locking screw 2x Screw BZ 2.2x9.5 2x Cable tie 1x 02 . 40 09 26 000 9901 2 x BZ 2.2 x 9.5 DIN ISO 14 81 Supplied with: Shell 2x Locking screw 2x Screw M3x10 2x Nut M3 2x Screw BZ 2.9x9.5 2x Cable clamp 1x Tension relief 1x DIN 41 612 · Coding systems Identification Coding system with contact loss Part No. Code pin for types D, E, F, FM, 2F 09 04 000 9908 Drawing Dimensions in mm To avoid accidental and incorrect mating of adjacent connectors a coding system is required. The coding is achieved by means of a code pin which is inserted into the selected chamber of the female connector (the contact cavity must be filled with a female contact!). The opposite male contact must be removed with the help of the specially designed tool. Plastic DIN Power to 6 A Removal tool for male contacts 09 99 000 0038 Coding system without contact loss with code pin With the aid of the marked indents between the contact rows of the male connector a hole has to be drilled at the desired position (also see drawing). The code pin can then be inserted into the corresponding cavity of the female connector by means of the insertion tool. This coding system is available only for the types D, E, F and interface connectors I Code pin Metal 09 06 000 9950 Insertion tool 09 99 000 0103 Mounting example Code pin Code pin Types D, E shroud coding Type F Code key 09 06 001 9919 Type F Insert the code key into one of the keyways of the female connector as shown in the drawing. Break out the corresponding area of the male shroud. Connectors coded this way can only be applied in a minimum rack spacing of 20.32 mm. Code key Tool for breaking out the coding area of the male shroud 09 99 000 0242 02 . 41 DIN 41 612 · Coding systems Identification Part No. Coding system without contact loss Drawing Dimensions in mm To avoid accidental and incorrect mating of adjacent connectors a coding system is required.This coding system is an integral part of both male and female connactors. A comb with 12 coding pins, which is supplied under a single part number, allows over 900 coding variations. The pins are to be locked into the male and female connectors. Male and female connectors The connectors with the integrated coding facility are supplied for types B, C, D and E and are available for all variants. Please contact us. DIN Power to 6 A Types B, C, D and E see product pages or on request Coding pins 12 pins on a comb 09 02 000 9928 Mounting example B 02 . 42 C D Type D E E
09061326931 价格&库存
很抱歉,暂时无法提供与“09061326931”相匹配的价格&库存,您可以联系我们找货
