09643227210
09643227210
    HARTING(浩亭)
    插件
09643227210 数据手册
D-Sub filter connectors Number of contacts Working current Technical characteristics 9, 15, 25, 37 UL recognized Contact arrangement View from termination side 7.5 A max. M F 9 way M F 15 way Test voltage Ur.m.s. M F 25 way 1 kV M F Contact resistance Insulation resistance ≤ 10 mΩ ≥ 1000 MΩ Temperature range -55 OC … + 125 OC + 255 OC Heat deflection temperature limit according to DIN 53 461 M = Male connector F = Female connector D-Sub - F 37 way Mating conditions as per CECC 75 301 Terminations a) Solder buckets max. 0.8 mm² b) Solder pins Ø 0.6 mm for P.C.B. holes Ø 0.8/1 mm c) Solder pins, angled 90O Ø 0.6 mm for P.C.B. holes Ø 0.8/1 mm Materials Insulation PCT, glass-fibre filled, flame retardant acc. to UL 94-V0 Colour: natural Contacts Copper alloy Male and female contacts are turned Contact surface Contact zone Selectively plated according to performance level Performance level Performance level 2, as per CECC 75 301-802, 250 mating cycles, 4 days 4 mixed gas test – IEC 60 512 Metal shell Steel 05 . 03 D-Sub Attenuation characteristics for standard capacitance values Min. insertion loss Attenuation (in dB) vs. frequency [MHz] Capacitance [pF]1) Frequency [MHz] 1 5 10 50 100 47 470 1000 3900 D-Sub - F 1) 1 500 1000 30 35 1 11 16 35 32 1 3 12 24 38 30 6 11 25 35 38 32 Capacitance tolerance = ± 20 % (For other capacitor values see pages 05.30 ff). Measured in 50 Ω system according to MIL-STD-220, no load. Working voltage: 100 V max for standard capacitance values – higher working voltages are available as specific. Dielectric withstanding voltage: 250 V DC max. – higher dielectric withstanding voltages are available as specific (see page 05.30) Insertion loss [dB] Typical insertion loss for different filters (measured) 05 . 04 Frequency [MHz] D-Sub Number of contacts 9--37 Turned solder pins, straight, through hole Identification No. of contacts Part No. male connectors female connectors 9 15 25 37 09 64 122 7210 09 64 222 7210 09 64 322 7210 09 64 422 7210 09 64 112 7210 09 64 212 7210 09 64 312 7210 09 64 412 7210 9 15 25 37 09 64 122 7220 09 64 222 7220 09 64 322 7220 09 64 422 7220 09 64 112 7220 09 64 212 7220 09 64 312 7220 09 64 412 7220 9 15 25 37 09 64 122 7230 09 64 222 7230 09 64 322 7230 09 64 422 7230 09 64 112 7230 09 64 212 7230 09 64 312 7230 09 64 412 7230 9 15 25 37 09 64 122 7240 09 64 222 7240 09 64 322 7240 09 64 422 7240 09 64 112 7240 09 64 212 7240 09 64 312 7240 09 64 412 7240 D-Sub - F Connectors with 47 pF C filter Connectors with 470 pF C filter Connectors with 1000 pF C filter Connectors with 3900 pF C filter 05 . 06 D-Sub Number of contacts 9--37 Turned solder pins, straight, through hole Identification Drawing Dimensions in mm D-Sub - F Male connector No. of contacts A B1 B2 C D E F G 9 30.8 16.9 16.4 25.00 19.3 1.37 2.74 12.50 15 39.1 25.2 24.7 33.30 27.5 1.37 2.74 16.65 25 53.0 38.9 38.5 47.04 41.3 1.40 2.77 23.52 37 69.3 55.3 54.9 63.50 57.7 1.40 2.77 31.75 Female connector Board drillings 05 . 07
09643227210 价格&库存
很抱歉,暂时无法提供与“09643227210”相匹配的价格&库存,您可以联系我们找货
  • 1+490.421251+63.44908
