0999 000 0305
0999 000 0305
    HARTING(浩亭)
    HARTING - 0999 000 0305 - Extraction Tool, Harting Han C Contacts
0999 000 0305 数据手册
Tools for contacts Han® C (09 32 ...) Identification Part number Drawing Dimensions in mm Removal tool for crimp contacts Removal tool 1.5 ... 6 mm² 10 mm² 09 99 000 0305 "https://b2b.harting.com/ebusiness/en/ 09 99 000 0381 "https://b2b.harting.com/ebusiness/en/ " " A removal tool is necessary to remove the contacts. For each „C“ contact cavity, the location of the internal locking levers are marked on the wiring side with two black arcs. The sides of the tool must be first properly aligned so that the edges of the tool engage both levers simultaneously and then inserted until a stop is noticeable ➀. Once it has been inserted, the tool must not be turned. The wire together with the tool can then be pulled out from the wiring side of the insert ➁. a ... lever marking Tools 99 . 10 Stock items in bold type
0999 000 0305 价格&库存
很抱歉,暂时无法提供与“0999 000 0305”相匹配的价格&库存,您可以联系我们找货
  • 1+159.160121+20.69030
  • 3+149.337573+19.41340
库存:30
09990000305
    • 1+243.84812
    库存:3
    09990000305
      • 1+214.452311+27.87811
