11 99 000 0001
11 99 000 0001
    HARTING(浩亭)
    HOUSING CONNECTOR
11 99 000 0001 数据手册
Han-Yellock® Inserting the module into the hoods/housing • The Han-Yellock® module should only be inserted into the „A“ plug-in position in the metal clamp. Disassembling the Han-Yellock® module • The removal tool (part no. 11 99 000 0001) is required to take out the module. • The following illustration shows how to insert the removal tool into the metal clamp. The tool should then be pressed down until it reaches the end stop. • The tool is then pulled back and the module comes out of the housing. • The removal can be made from the connection side as well as from the mating side. "https://b2b.harting.com/ebusiness/en/ " ① plug-in position „A“ • The illustration shows the orientation of the module (see arrangement of contacts 1 ... 5). ① removal tool ② housing, bulkhead mounting The process is identical for both housings, bulkhead mounting, and carrier hoods. The removal tool can be stored on the carrier hood: HanYellock ① ② ③ ④ • 25 . 04 Carrier hood, mating side Carrier hood, connection side Housing, bulkhead mounting, mating side Housing, bulkhead mounting, connection side A distinct click can be heard when the module snaps into position. It is then pushed along the rail to its final position. The plug-in slots must always be completely filled. ① removal tool ② carrier hood
11 99 000 0001 价格&库存
很抱歉,暂时无法提供与“11 99 000 0001”相匹配的价格&库存,您可以联系我们找货
    • 1+10.93453
    • 5+10.39301
    库存:2
