2002-2221/1000-434
2002-2221/1000-434
    WAGO(万可电子)
2002-2221/1000-434 数据手册
Printview: Double-deck LED terminal block; with red led; 24 VDC - Item No.: 2002-2221/1000-434 . Double-deck LED terminal block; with red led; 24 VDC Item No.: 2002-2221/1000-434 . Double-deck LED terminal block; with red led; 24 VDC . Marking . Business data Supplier WAGO Item no. 2002-2221/1000-434 GTIN / EAN 4045454375645 Content 1 Order amount 50 Customer item number . Notes Technical data Miscellaneous Total number of connection points 4 Total number of potentials 2 Number of levels 2 Color gray Ratings according to 1 IEC/EN 60947-7-1 Nominal current [A] 0.025 [A] Nominal voltage [V] 24 [V] Connection technology (1) Push-in CAGE CLAMP® Nominal cross section 1 2.5 mm² Solid sizes 1 0.25 … 4 mm² / 22 … 12 AWG WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Double-deck LED terminal block; with red led; 24 VDC - Item No.: 2002-2221/1000-434 Technical data solid, directly pluggable 1 0.75 … 4 mm² / 18 … 12 AWG Fine-stranded wires 1 0.25 … 4 mm² / 22 … 12 AWG min. fine-stranded with insulated ferrule, push-in terminati 0.75 mm² / 18 AWG Strip length 1 10 … 12 mm / 0.39 … 0.47 in Type of wiring Front-entry wiring Design horizontal Marking level Center/Side marking Insulating material Polyamide 66 (PA 66) Weight [g] 11 [g] Width 5.2 mm / 0.205 in Height from upper-edge of DIN-rail [mm] 51.7 [mm] Height from upper-edge of DIN-rail 51.7 mm / 2.035 in Length 69.7 mm / 2.744 in Type of mounting DIN 35 rail WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Double-deck LED terminal block; with red led; 24 VDC - Item No.: 2002-2221/1000-434 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Double-deck LED terminal block; with red led; 24 VDC - Item No.: 2002-2221/1000-434 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
2002-2221/1000-434 价格&库存
很抱歉,暂时无法提供与“2002-2221/1000-434”相匹配的价格&库存,您可以联系我们找货
2002-2221/1000-434
  • 1+241.254221+31.36227
