20825010001
20825010001
    HARTING(浩亭)
20825010001 数据手册
Advantages Jacks DIN rail outlet 19" patch panel Junction boxes Device interfaces Service interfaces HIFF-format components 19" patch panel Jacks Components in Keystone-format  Standardised Keystone-format fits for 19" patch panels and outlets  Built-in protective cover Description Part number preLink® RJ45 jack with Cat. 6, Keystone-format incl. cable termination block AWG 24 – AWG 22 20 82 501 0001 preLink® RJ45 jack with Cat. 6, Keystone-format (without cable termination block) Angled version (without cable termination block) 20 82 500 0001 20 82 500 0002 (Package quantity: 24 pieces) 19" patch panel, Keystone-format, empty 20 82 400 0002 19" patch panel, Keystone-format assembled with 24 preLink® jacks for AWG 22 / 23 20 82 405 0001 DIN rail outlet, single Keystone-format, empty 09 45 851 0000 Cover plate set (with 2 covers) 09 45 851 0001 preLink® RJ45 jack with Cat. 6, HIFF-format incl. cable termination block AWG 24 – AWG 22 AWG 27 – AWG 26 20 82 001 0001 20 82 001 0002 preLink® RJ45 jack with Cat. 6, HIFF-format without cable termination block 20 82 000 0002  Fits with HIFF-format jacks  Movable jack carrier – helps to save time and money during the assembly process  Additional strain relief mechanism 19" patch panel, HIFF-format, empty 20 82 400 0001  Suitable for surface mount or installation in electrical cabinet Junction box assembled with 2 preLink® RJ45 HIFF-format jacks, for AWG 22 / 23 20 82 101 0220 Accessories for mounting on DIN rail 20 80 000 0003  Fits with all Keystone-format jacks  Inexpensive because of simple set up  Additional strain relief mechanism  Fits with all Keystone-format jacks  Built-in cover protects against dust  Labelling field  HIFF-format: for use in Han® 3 A, HARTING PushPull (V4), Han® PushPull (V14) and har-port  Robust aluminium die cast housing  Easy to assemble  E xternal attachment and earth connections  Degree of protection: IP65 / IP67  Fits with HIFF-format jacks  Standardised interfaces can be easily implemented in devices as well as electrical cabinets  Degree of protection: IP65 / IP67  Easy to assemble  Compact design  Available as standard in lengths from 0.20 m to 10.00 m Han® 3 A metal outlet, with 2 Han® 3 A RJ45 ports, assembled with 2 preLink® HIFF-format jacks, for AWG 22  /  23 Han® 20 82 102 0101 Han® PushPull (V14) metal outlet, with 2 PushPull RJ45 ports, assembled with 2 preLink® HIFF-format jacks, for AWG 22  /  23 20 82 104 0101 Han® 3 A bulkhead mounted housing Black plastic Grey plastic 09 20 003 0327 09 20 003 0301 Han® 3 A HIFF adapter for assembling the HIFF modules 09 45 515 0024 Han® PushPull (V14) bulkhead mounted housing for HIFF modules Black plastic Rectangular metal Round metal 09 35 012 0331 09 35 012 0311 09 35 012 0312 har-port RJ45 service interface, incl. HIFF coupling 09 45 452 1560 har-port panel feed through, suitable for holding HIFF modules 09 45 452 0000 har-port RJ45 service interface with cable (RJ45 jack to RJ45 plug) 09 45 452 1501 – 09 45 452 1518 Ha-VIS preLink®
20825010001 价格&库存
很抱歉,暂时无法提供与“20825010001”相匹配的价格&库存,您可以联系我们找货
    • 20+53.10360
    库存:20
    20825010001
      • 1+68.75000
      • 5+59.95000
      • 10+58.85000
      • 20+58.30000
      库存:20
      20825010001
        • 1+101.17043
        • 10+96.91117
        • 50+92.74564
        • 100+89.96514
        • 200+87.26796
        库存:178
