Product data sheet
21 03 221 1405
M12-L shielded male 4-pole A-coded
Part number
21 03 221 1405
Specification
HARTING eCatalogue
https://b2b.harting.com/21032211405
Identification
Category
Connector
Series
Circular connectors M12
Identification
M12-L
Element
Cable connector
Specification
Straight
Version
Termination method
HARAX® connection technology
Gender
Male
Locking type
Screw locking
Shielding
Shielded
Number of contacts
4
Coding
A-coding
Technical characteristics
Conductor cross-section
0.14 ... 0.34 mm²
AWG 26 ... AWG 22
Wire outer diameter
≤1.6 mm
Rated current
4 A
Rated voltage
50 V
Rated impulse voltage
1.5 kV
Pollution degree
3
Insulation resistance
> 108 Ω
Contact resistance
≤10 mΩ
Page 1 / 3 | Creation date 2019-04-17 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to
the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality,
conformity with applicable laws and directives, as well as for the electrical safety in the particular application.
HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany
Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com
Product data sheet
21 03 221 1405
Ambient temperature
-40 ... +85 °C
Tightening torque
0.6 Nm
Wrench size
A/F 17 Knurled screw / knurled nut
Mating cycles
≥100
Degree of protection acc. to IEC 60529
IP65 when mated
IP67 when mated
Cable diameter
4.5 ... 8.8 mm
Overvoltage category
III
Isolation group
I (600 ≤ CTI)
Material properties
Material (insert)
Polyamide
Material (contacts)
Brass
Surface (contacts)
Gold plated
Material (hood/housing)
Zinc die-cast
RoHS
compliant with exemption
RoHS exemptions
6c: Copper alloy containing up to 4 % lead by weight
ELV status
China RoHS
50
REACH Annex XVII substances
No
REACH ANNEX XIV substances
No
REACH SVHC substances
Yes
Lead
Specifications and approvals
Specifications
IEC 61076-2-101
UL / CSA
UL 1977 ECBT2.E102079
CSA-C22.2 No. 182.3 ECBT8.E102079
Commercial data
Packaging size
10
Net weight
52.5 g
Country of origin
Germany
European customs tariff number
85366990
Page 2 / 3 | Creation date 2019-04-17 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to
Product data sheet
21 03 221 1405
Commercial data
eCl@ss
27440102 Circular connector (for field assembly)
Page 3 / 3 | Creation date 2019-04-17 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the
很抱歉,暂时无法提供与“21 03 221 1405”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+315.70589
- 10+307.03116
- 50+296.75270
- 100+290.66061
- 250+284.12072
