Data sheet | Item number: 2202-2702
Double-deck terminal block; with push-button; Through/through terminal
block; N/L; without marker carrier; suitable for Ex e II applications; Blue
conductor entry lower deck; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; Pushin CAGE CLAMP®; 2,50 mm²; gray
www.wago.com/2202-2702
Color:
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
800 V
Rated impulse voltage (III / 3)
8 kV
Rated current
24 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Connection technology
Push-in CAGE CLAMP®
Number of connection points (connection type)
2
Actuation type
Push-button
Connectable conductor materials
Copper
Nominal cross section
2.5 mm²
Solid conductor
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
0.25 … 4 mm² / 22 … 12 AWG
Do you have any questions about our products?
We are always happy to take your call at {0}.
05.02.2020 Page 1/2
Solid conductor
Solid conductor, push-in termination
0.75 … 4 mm² / 18 … 12 AWG
Fine-stranded conductor
Fine-stranded conductor with ferrule with plastic collar
1 … 2.5 mm² / 18 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from
Strip length
10 … 12 mm / 0.39 … 0.47 inch
2
Total number of connection points
4
Total number of potentials
2
Number of levels
2
Type of wiring
Front-entry wiring
Note (conductor cross-section)
Depending on the conductor characteristic, a conductor with a
smaller cross section can also be inserted via push-in termination.
Geometrical Data
Width
5.2 mm / 0.205 inch
Height from upper-edge of DIN-35 rail
71.7 mm / 2.035 inch
Depth
92.5 mm / 3.642 inch
Mechanical data
Design
horizontal
Type of mounting
DIN-35 rail
Potential marking
N/L
Marking level
Center/side marking
Material Data
Color
gray
Insulating material
Polyamide 66 (PA 66)
Weight
12.6 g
Commercial data
Packaging type
BOX
Country of origin
DE
GTIN
4055143844604
Customs Tariff No.
85369010000
Subject to changes.
Hansastr. 27
32423 Minden
05.02.2020 Page 2/2
很抱歉,暂时无法提供与“2202-2702”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+95.164361+12.32712
- 10+67.4973310+8.74327
- 25+59.6691525+7.72925
- 50+54.9231950+7.11448
- 100+51.07602100+6.61613
- 250+47.15622250+6.10838
- 500+44.91010500+5.81743
- 1000+43.156581000+5.59029
