Data sheet from 23.11.2010
Item no.:
231-605/019-000
Product description:
Male connector with fixing flange 5 pole pin spacing 5 mm /
0.197 in for screw or similar mounting types for parallel or
perpendicular mounting
Produkt kann von Bild abweichen / product may differ
Packing unit 50 pieces
Product group
3 (Multi Conn. System)
Weight
8.51 g
Color
grey
No. of connection Points
5
No. of potentials
5
pole count
5
Height
14.3 mm
Height
0.563 in
Width
39.8 mm
Width
1.567 in
Depth
27.5 mm
Depth
1.083 in
Pin spacing from
5 mm
Pin spacing from
0.197 in
Rating based on
IEC/EN 60664-1
Overvoltage category EN I
III
Pollution degree
2
Measured voltage EN
320 V
Measured shock voltage
4 kV
1 von 5
Current intensity EN
12 A
Overvoltage category EN II
II
Pollution degree
2
2 von 5
Measured voltage EN
630 V
4 kV
12 A
Overvoltage category EN III
III
Degree of pollution
3
Rated voltage EN
320 V
Rated surge voltage
4 kV
Nominal current
12 A
Connection method
CAGE CLAMP®CONNECTION
Cross section [mm²]
0.08 - 2.5 mm²
Wiring method
solid
Cross section [mm²]
0.08 - 2.5 mm²
Wiring method
fine-stranded
Cross section [mm²]
0.25 - 1.5 mm²
Wiring method
fine-stranded (with ferrule and plastic collar)
Cross section [mm²]
0.25 - 2.5 mm²
Wiring method
fine-stranded (with ferrule, without plastic collar)
Cross section [AWG]
28 - 12 AWG
Strip length from
8 mm
Strip length to
9 mm
Strip length from [inch]
0.31 in
Strip length up to [inch]
0.35 in
3 von 5
Material group
I
Insulating material
PA 6.6
Temperature stability
-60 °C to +100 °C
Flammability category, based on UL 94
V0
Clamping spring material
Nickel-chromium spring steel (CrNi)
Contact material
Electrolytic copper (Ecu)
Contact plating
tin-plated
xxx-xxx/033-000
Strain relief plate 20 mm
4 von 5
Item number
Admission office
Approval no.
Voltage [V]
Current [A]
Cross section [ mm² ]
231-605/019-000
ABS
04-HG469925/1-PDA
400
12
5,0
231-605/019-000
BV
11915/A0
400
16
2,5
231-605/019-000
CCA
5764
250
12
0,08-2,5
231-605/019-000
CSA
154112-1466354
300
15
22-12
231-605/019-000
GL
17296-00HH
400
12
5,0
231-605/019-000
KEMA
2083746.02
250
12
0,08-2,5
231-605/019-000
KR
HMB05880-EL003
250/400
12/16
2,5
231-605/019-000
LR
96/20035
400
12
5,0
231-605/019-000
RMR
11130002
400
12
5,0
231-605/019-000
UR
E45171
600
15
28-12
231-605/019-000
UR
E45172
300/150/300
15/15/10
22-12
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
5 von 5
