Ha-VIS eCon 2000 Fast Ethernet Basic
3 to 8 Ethernet ports RJ45 and FOC
English
Unmanaged Plug & Play Ethernet switches for DIN rail assembly in control
cabinets
Commercial temp.: 0°C ... +55°C / Industrial temp.: -40 ... +70°
Energy
Efficient
Ethernet
■ Fast Ethernet Non-Blocking Switch architecture in accordance with IEEE 802.3
■ Variants with industrial temperature range of -40°C ... +70°C
■ Wide range power supply 24/48 VDC
■ Surge protection and reverse polarity protection
■ Minimum energy consumption due to energy-effi cient Ethernet
Target markets
Machinery & Robotics
Automation
Industrial network
Infrastructure
Wind Energy,
Solar Energy
Transportation
Shipbuilding
General Description
The Ha-VIS eCon 2000 Fast Ethernet family of unmanaged Ethernet switches
is equipped with up to 8 Fast Ethernet ports and allow for cost-effi cient
and quick expansion and/or reconstruction of network infrastructures.
Due to the extremely fl at design, these switches can be accommodated
in installations where space is restricted towards the cable connection
at the front. The selection includes various combinations of variants with
RJ45 and fi bre optic ports. Automatic detection of the transmission rate
(auto-negotiation) and of the wiring of the twisted pair data cable
(autopolarity and auto-MDI(X)) allow for simple plug & play. All variants are
available with the temperature ranges „Industrial“ and „Commercial“.
Technical characteristics
Switch Features
Ethernet ports 10BASE-T / 100BASE-TX EEE / 1000Base-TX EEE
Housing width
Number of ports
46.5
60 mm
120 mm
3, 4, 5
8
7, 8
Type of connection
RJ45
Auto-negotiation
Yes
Yes
Switching technology
Store and Forward
Auto-polarity
Supported standards
IEEE 802.3
Frame Size
Auto-MDI(X)
1552 bytes
Transfer conditions
MAC table size
1k entries
Transfer speed
10 / 100 Mbit/s
448 kbit
Transfer length
100 m (Twisted Pair, Cat 5)
Packet buffer size
Non-blocking
Yes
Quality of Service
Yes
Energy Efficient
Ethernet
Yes
PROFINET compatible
Yes
EthernetIP compatible
Yes
Yes
Twisted pair
Ethernet ports 100BASE-FX
Type of fibre
Multi-mode (MM)
Type of connection
Transfer conditions
FOC
Wavelength
1310 mm
Transfer speed
Power supply
Transfer length
Nominal voltage
24 VDC
Permissible voltage range
48 VDC
Yes
Reverse polarity proof
Yes
Starting current
1.60 A
Overcurrent protection at input
Max. power consumption @ 24 VDC
Conductor cross-section
Type of connection
Pinout
Input sensitivity
9 VDC ... 60 VDC
Surge protection
100 Mbit/s
2 km
15 km
-19 dBm ... -14 dBm
-15 dBm ... -8 dBm ≤
≤ -32 dBm
≤ -34 dBm
Environmental conditions
5.60 A
Yes (2/4 A)
0.77 W ... 3.1 W
0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG)
3-pole, pluggable screwed contact
Supply circuit (according to 60950)
Output power
Single-mode (SM)
SC Duplex
SELV (circuit breaker 10 A)
HARTING Technology Group
P.O.Box 1473, D-32325 Espelkamp
Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany
ICPN-Service@harting.com | Service hotline: +49 5772 47-9479
Fax: +49 5772 47-495 | www.HARTING.com/de/ethernet-switches
Commercial temperature range
Industrial temperature range
Storage temperature range
0°C ... +55°C
-40°C ... +70°C
-40 °C ... +85 °C
Relative humidity (operation)
0% ... 95 % (non-condensing)
Relative humidity (storage and
transport)
Air pressure
2000 m (795 hPa)
Note: We reserve the right to make technical changes to the products and to the content of this
document at any time without prior notification. The HARTING Technologiegruppe does not accept
any responsibility for possible errors or incompletions in this document. We reserve all the rights to
this document and the topics and illustrations contained within it. Copying, disclosure to third parties
or use of its content - even partially - is forbidden without the prior written consent of the HARTING
Technologiegruppe.
Housing
Enclosure width
46.5 mm
60 mm
120 mm
113.5 mm x
46.5 mm x
27.3 mm
113.5 mm x
60 mm x
27.3 mm
113.5 mm x
120 mm x
27.3 mm
162 g ... 170 g
217 g
372 g ... 386 g
Dimensions H x W x D
(without pluggable
screwed contact and
holding bracket)
Weight
Type of installation
35 mm DIN rail acc. to EN 60 715
Material hoods/housings
Anodised aluminium
Protection class (with
plugged screwed contact)
IP 30
Protection class
Mechanical stability (EN 60721-3)
IEC 60068-2-6 Vibration
IEC 60068-2-6 Vibrationresonance search
IEC 60068-2-27 Shock test
III
illuminated green
Supply voltage is applied
Link/Activity ("L/A") off
No link
Link/Activity ("L/A") illumindated
green
Link/Activity ("L/A") flashes green
EMC and environmental conditions
EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024)
Electrostatic discharge (ESD) EN 61 000-4-2
Electromagnetic field EN 61 000-4-3
Rapid transients (burst) EN 61 000-4-4
Surge voltages EN 61 000-4-5
Conducted interference voltages EN 61 000-4-6
EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15)
Status and diagnostic displays
Power ("Pwr")
Approvals
CE, FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK, ABB IIT
Included in delivery
■ Pluggable screw type terminal block for power supply
■ Installation instructions
Link is active
Link is active and data is transferred
Link speed („Spd“) off
10 Mbit/s
Link speed („Spd“) illumindated yellow
100 Mbit/s
Drawings
Technical characteristics / order information
Ports / order information
Commercial temp.: 0 °C ... +55 °C
Industrial temp.: -40 °C ... +70 °C
RJ45
SFP
SC
Enclosure
width
Power consumption @ 24 VDC
MTBF
in million h
Switch
Part no.
3
46.5 mm
32 mA
3.13
Ha-VIS eCon 2030B-A
24 02 003 0010
Ha-VIS eCon 2030BT-A
24 02 003 0000
4
46.5 mm
37 mA
2.99
Ha-VIS eCon 2040B-A
24 02 004 0010
Ha-VIS eCon 2040BT-A
24 02 004 0000
5
46.5 mm
42 mA
2.86
Ha-VIS eCon 2050B-A
24 02 005 0010
Ha-VIS eCon 2050BT-A
24 02 005 0000
6
1x MM (2 km)
120 mm
94 mA
1.24
Ha-VIS eCon 2061B-AD
24 02 006 1110
Ha-VIS eCon 2061BT-AD
24 02 006 1100
6
1x SM (15 km)
120 mm
81 mA
1.26
Ha-VIS eCon 2061B-AF
24 02 006 1210
Ha-VIS eCon 2061BT-AF
24 02 006 1200
6
2x MM (2 km)
120 mm
129 mA
1.20
Ha-VIS eCon 2062B-AD
24 02 006 2110
Ha-VIS eCon 2062BT-AD
24 02 006 2100
6
2x SM (15 km)
120 mm
113 mA
1.23
Ha-VIS eCon 2062B-AF
24 02 006 2210
Ha-VIS eCon 2062BT-AF
24 02 006 2200
8
60 mm
58 mA
2.53
Ha-VIS eCon 2080B-A
24 02 008 0010
Ha-VIS eCon 2080BT-A
24 02 008 0000
Copyright © 2014
All rights reserved
Date of issue 02.2015
ICPN Datasheet 0834/01
Switch
Part no.
很抱歉,暂时无法提供与“24 02 005 0010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1186.733811+153.65785
- 国内价格 香港价格
- 1+1192.926671+154.45970
- 10+1114.4687710+144.30100
