Ha-VIS eCon 3000 Fast Ethernet Basic
3 to 16 Ethernet ports RJ45 and SC
English
Unmanaged plug and play Ethernet switches for DIN rail assembly in
control cabinets
Commercial temp.: 0 °C ... +55 °C / Industrial
temp.: -40 °C ... +70 °C
Energy
Efficient
Ethernet
■ Fast Ethernet Non-Blocking switch architecture in accordance with
IEEE 802.3
■ Variants with industrial temperature range of -40 °C ... +70 °C
■ Wide range power supply 24/48 VDC
■ Surge protection and reverse polarity protection
■ Minimum energy consumption due to energy-efficient Ethernet
■ Optimised DIN rail bracket
Target markets
Machinery & Robotics
Automation
Industrial network
infrastructures
Wind Energy,
Solar Energy
Transportation
Shipbuilding
General description
The Ha-VIS eCon 3000 Fast Ethernet family of unmanaged Ethernet switches
is equipped with up to 16 Fast Ethernet ports and allow for cost-efficient
and quick expansion and/or reconstruction of network infrastructures. The
slender design of the switches enables an extremely high packing density
on the DIN rail. The selection includes various combinations of variants with
RJ45 and fibre optic ports. Automatic detection of the transmission rate
(auto-negotiation) and of the wiring of the twisted pair data cable (autopolarity and auto-MDI(X)) allow for simple plug and play. All variants are
available with the temperature ranges "Industrial" and "Commercial".
Technical characteristics
Switch features
Ethernet ports 10BASE-Te / 100BASE-TX EEE
Enclosure width
25 mm
38 mm
38 mm
Number of ports
3, 5, 6, 7, 8
9, 10
16
Type of connection
RJ45
Auto-negotiation
Yes
Yes
Switching technology
Store and Forward
Auto-polarity
Supported standards
IEEE 802.3
Auto-MDI(X)
Yes
Frame size
1522 bytes
1632 bytes
2000 bytes
MAC table size
Transfer conditions
1k entries
2k entries
8k entries
448 kbit
1 Mbit
2 Mbit
Transfer speed
10 / 100 Mbit/s
Transfer length
100 m (Twisted Pair, Cat 5)
Packet buffer size
Non-blocking
Yes
Quality of Service
Yes
Energy Efficient Ethernet
Yes
PROFINET compatible
Yes
EthernetIP compatible
Yes
Twisted pair
Ethernet ports 100BASE-FX
Type of fibre
Multi-mode (MM)
Type of connection
Transfer conditions
FOC
Wavelength
Power supply
Nominal voltage
24 VDC
Permissible voltage range
48 VDC
9 VDC ... 60 VDC
Surge protection
Yes
Reverse polarity proof
Yes
Output power
Input sensitivity
Starting current
1.6 A
Overcurrent protection at input
Yes (12 A for 8 ports)
Max. power consumption @ 24 VDC
Conductor cross-section
Type of connection
Pinout
3.2 A
1.80 W ... 6.72 W
0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG)
3-pole, pluggable screw type terminal block
Supply circuit (according to 60950)
SELV (circuit breaker 10 A)
HARTING Technology Group
P.O.Box 1473, D-32325 Espelkamp
Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany
ICPN-Service@harting.com | Service hotline: +49 5772 47-9479
Fax: +49 5772 47-495 | www.HARTING.com/de/ethernet-switches
1310 nm
Transfer speed
Transfer length
Single-mode (SM)
SC Duplex
100 Mbit/s
2 km
15 km
-20 dBm ... -14 dBm
-15 dBm ... -8 dBm
≤ -30 dBm
≤ -32 dBm
Environmental conditions
Commercial temperature range
Industrial temperature range
Storage temperature range
0 °C ... +55 °C
-40 °C ... +70 °C
-40 °C ... +85 °C
Relative humidity (operation)
0 % ... 95 % (non-condensing)
Relative humidity (storage and
transport)
Air pressure
2000 m (795 hPa)
Note: We reserve the right to make technical changes to the products and to the content of this
document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the
rights to this document and the topics and illustrations contained within it. Copying, disclosure to
third parties or use of its content - even partially - is forbidden without the prior written consent
of the HARTING Technologiegruppe.
Enclosures
Enclosure width
Dimensions H x W x D (without
block and holding bracket)
25 mm
38 mm
142 mm x 25 mm
x 107.5 mm
142 mm x 38 mm
x 107.5 mm
Weight
425 g ... 531 g
Type of installation
35 mm DIN rail acc. to EN 60 715
Material enclosures
Anodised aluminium / powder coated
steel sheet
Protection class (with pluggable
screw type terminal block)
III
Status and diagnostic displays
Power ("Pwr")
illuminated green
Supply voltage is applied
Link/Activity ("L/A") off
No link
Link/Activity ("L/A") illuminated green
Link/Activity ("L/A") flashes green
Link is active
Link is active and data is transferred
Link speed ("Spd") off
EMC and environmental conditions
EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024)
Electrostatic discharge (ESD) EN 61 000-4-2
Electromagnetic field EN 61 000-4-3
Rapid transients (burst) EN 61 000-4-4
Surge voltages EN 61 000-4-5
Conducted interference voltages EN 61 000-4-6
EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15)
IP30
Protection class
Approvals
CE, FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK, ABB IIT
Mechanical stability (EN 60721-3)
IEC 60068-2-6 Vibration
IEC 60068-2-6 Resonance search
IEC 60068-2-27 Shock test
Included in delivery
■ Pluggable screw type terminal block for power supply
■ Installation instructions
10 Mbit/s
Link speed ("Spd") illuminated yellow
Drawings
Technical characteristics / order information
Ports / order information
Industrial temp.: -40 °C ... +70 °C
RJ45
SFP
SC
Enclosure
width
2
1x MM (2 km)
25 mm
97 mA
2.51
Ha-VIS eCon 3021B-AD
24 03 002 1110
Ha-VIS eCon 3021BT-AD
24 03 002 1100
2
1x SM (15 km)
25 mm
97 mA
2.51
Ha-VIS eCon 3021B-AF
24 03 002 1210
Ha-VIS eCon 3021BT-AF
24 03 002 1200
4
1x MM (2 km)
25 mm
111 mA
2.35
Ha-VIS eCon 3041B-AD
24 03 004 1110
Ha-VIS eCon 3041BT-AD
24 03 004 1100
4
1x SM (15 km)
25 mm
111 mA
2.35
Ha-VIS eCon 3041B-AF
24 03 004 1210
Ha-VIS eCon 3041BT-AF
24 03 004 1200
4
2x MM (2 km)
25 mm
142 mA
2.27
Ha-VIS eCon 3042B-AD
24 03 004 2110
Ha-VIS eCon 3042BT-AD
24 03 004 2100
4
2x SM (15 km)
25 mm
142 mA
2.27
Ha-VIS eCon 3042B-AF
24 03 004 2210
Ha-VIS eCon 3042BT-AF
24 03 004 2200
6
25 mm
75 mA
2.29
Ha-VIS eCon 3060B-A
24 03 006 0010
Ha-VIS eCon 3060BT-A
24 03 006 0000
6
1x MM (2 km)
25 mm
121 mA
2.21
Ha-VIS eCon 3061B-AD
24 03 006 1110
Ha-VIS eCon 3061BT-AD
24 03 006 1100
6
1x SM (15 km)
25 mm
121 mA
2.21
Ha-VIS eCon 3061B-AF
24 03 006 1210
Ha-VIS eCon 3061BT-AF
24 03 006 1200
8
25 mm
85 mA
2.16
Ha-VIS eCon 3080B-A
24 03 008 0010
Ha-VIS eCon 3080BT-A
24 03 008 0000
8
1x MM (2 km)
38 mm
227 mA
0.94
Ha-VIS eCon 3081B-AD
24 03 008 1110
Ha-VIS eCon 3081BT-AD
24 03 008 1100
8
1x SM (15 km)
38 mm
227 mA
0.94
Ha-VIS eCon 3081B-AF
24 03 008 1210
Ha-VIS eCon 3081BT-AF
24 03 008 1200
8
2x MM (2 km)
38 mm
273 mA
0.93
Ha-VIS eCon 3082B-AD
24 03 008 2110
Ha-VIS eCon 3082BT-AD
24 03 008 2100
8
2x SM (15 km)
38 mm
273 mA
0.93
Ha-VIS eCon 3082B-AF
24 03 008 2210
Ha-VIS eCon 3082BT-AF
24 03 008 2200
10
38 mm
220 mA
0.91
Ha-VIS eCon 3100B-A
24 03 010 0010
Ha-VIS eCon 3100BT-A
24 03 010 0000
16
38 mm
93 mA
1.75
Ha-VIS eCon 3160 B-A
24 03 016 0010
Ha-VIS eCon 3160BT-A
24 03 016 0000
Copyright© 2014
All rights reserved
Power consumption @ 24 VDC
MTBF in
million h
Switch
Part no.
Switch
Part no.
Date of issue 08.2015
ICPN Datasheet 0842/03
很抱歉,暂时无法提供与“24030060010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2788.899341+362.42459
