Data sheet | Item number: 2616-1352
PCB terminal block; lever; 16 mm²; Pin spacing 15 mm; 2-pole; Push-in CAGE
CLAMP®; 16,00 mm²; gray
www.wago.com/2616-1352
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
03.06.2020 Page 1/6
L = (pole no. – 1) x pin spacing + 11.5 mm
Item description
PCB terminal blocks with levers and Push-in CAGE CLAMP® connection
Push-in termination of solid and ferruled conductors
Intuitive and tool-free operation
Several clamping units can be held open simultaneously – convenient for terminating multi-core cables
Testing can be performed both parallel and perpendicular to conductor entry
Data
Electrical data
Ratings per IEC/EN 60664-1
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
800 V
Rated surge voltage (III/3)
8 kV
Rated voltage (III/2)
1000 V
Rated surge voltage (III/2)
8 kV
Nominal voltage (II/2)
1000 V
Rated surge voltage (II/2)
8 kV
Rated current
76 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Hansastr. 27
32423 Minden
03.06.2020 Page 2/6
Legend (ratings)
Approvals per UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
78 A
Rated voltage UL (Use Group C)
300 V
Rated current UL (Use Group C)
78 A
Rated voltage UL (Use Group D)
600 V
Rated current UL (Use Group D)
5 A
Connection data
Connection technology
Push-in CAGE CLAMP®
Actuation type
Lever
Solid conductor
0,75 … 16 mm² / 18 … 4 AWG
Fine-stranded conductor
0,75 … 25 mm² / 18 … 4 AWG
Fine-stranded conductor; with insulated ferrule
0,75 … 16 mm²
Fine-stranded conductor; with uninsulated ferrule
0,75 … 16 mm²
Fine-stranded conductor; with twin ferrule
0,75 … 6 mm²
Strip length
18 … 20 mm / 0.71 … 0.79 inch
Conductor connection direction to PCB
0 °
Pole No.
2
Total number of connection points
2
Total number of potentials
2
Number of connection types
1
Number of levels
1
Geometrical Data
Pin spacing
15 mm / 0.591 inch
Width
26,5 mm / 1.043 inch
Height
37,2 mm / 1.465 inch
Height from the surface
33,2 mm / 1.307 inch
Depth
32 mm / 1.26 inch
Solder pin length
4 mm
Solder pin dimensions
1,2 x 1,2 mm
Drilled hole diameter with tolerance
1,7 (+0,1) mm
PCB
contact
Hansastr. 27
32423 Minden
03.06.2020 Page 3/6
PCB contact
PCB contact
THT
Solder pin arrangement
over the entire female connector (in-line)
Number of solder pins per potential
6
Material Data
Color
gray
Material group
I
Insulation material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Color of actuator
orange
Weight
22.2 g
Environmental Requirements
Limit temperature range
-60 … +105 °C
Commercial data
Packaging type
BOX
Country of origin
DE
GTIN
4055143860284
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CSA
DEKRA Certification B.V.
C22.2
70154737
KEMA/KEUR
EN 60947-7-4
71108233
Hansastr. 27
32423 Minden
03.06.2020 Page 4/6
UL-Approvals
Logo
Approval
cURus
Underwriters Laboratories Inc.
C22.2 No. 158
Certificate
name
E4517220171206
Counterpart
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
3.6 MB
Download
URL
Download
CAD/CAE-Data
PCB Design
Symbol and Footprint 2616-1352
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Hansastr. 27
32423 Minden
03.06.2020 Page 5/6
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Handling Instructions
Hansastr. 27
32423 Minden
03.06.2020 Page 6/6
很抱歉,暂时无法提供与“2616-1352”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+117.930761+15.30142
