773-114/K194-4045
773-114/K194-4045
    WAGO(万可电子)
    端子 对接接头,直插式,单独开口 连接器 按进式 12-14 AWG 绿色
773-114/K194-4045 数据手册
Data sheet from 16.07.2010 Item no.: 773-114 Product description: PUSH-WIRE CONNECTOR FOR JUNCTION BOXES 4CONDUCTOR TERMINAL BLOCK Produkt kann von Bild abweichen / product may differ Packing unit 100 pieces Product group 7 (Push Wire Conn.) pole count 4 Cross section [mm²] 1.5 - 2.5 mm² Cross section [AWG] 14 - 12 AWG Connection method PUSH WIRE® Number of strands 4 Cross section [mm²] 1 - 2.5 mm² Cross section [AWG] 14 - 12 AWG Wiring method e Number of strands 4 Measured voltage EN 400 V Measured shock voltage 4 kV Pollution degree 2 Current intensity EN 24 A Weight 2.67 g Color green No. of connection Points 4 No. of potentials 1 Height 13.1 mm Height 0.516 in 1 von 4 Width 13 mm Width 0.512 in 2 von 4 Data sheet from 16.07.2010 Depth 19.1 mm Depth 0.752 in Strip length from 10 mm Strip length to 13 mm 3 von 4 Data sheet from 16.07.2010 Item no. Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 773-114 ABS 04-HG476172/1-PDA 400 24 0,75-2,5 773-114 BV 11941/BO 300 24 2,5 773-114 CB-certificateChina DK2689/A1 400 24 0,75-2,5 773-114 CCA DK2520 400 24 0,75-2,5 773-114 CSA 154112-1059435 600 20 12-18 773-114 DEMKO 99-03689 400 24 0,75-2,5 773-114 FIMKO FI14401 400 24 0,75-2,5 773-114 GL 17294-00HH 400 24 0,75-2,5 773-114 LR 04/20013(E3) 400 24 0,75-2,5 773-114 NEMKO P99102807 400 24 0,75-2,5 773-114 RMR 11130002 400 24 0,75-2,5 773-114 SEMKO 9951003/01 400 24 0,75-2,5 773-114 UL E201573 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 4 von 4 12-18
773-114/K194-4045 价格&库存
很抱歉,暂时无法提供与“773-114/K194-4045”相匹配的价格&库存,您可以联系我们找货
773-114/K194-4045
  • 1+168.922291+21.89555
