A4B-2PA-2DSA(51)
A4B-2PA-2DSA(51)
    HRS(广濑)
    插件,P=2mm
    排针 间距:2mm 插件
A4B-2PA-2DSA(51) 数据手册
A3/A4 Series Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2mm Pitch Miniature Connector Product Page https://www.hirose.com/en/product/compare?searchType=series&targets=A3%2CA4 May. 2023 A3/A4 Series/2mm Pitch Miniature Connector Features 1. Miniature Type and High Density Mounting Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. These connectors are designed to be a miniature and light weight product, and mounted in the high density. The crimp socket is structured in the 2mm pitch grid, so that connectors can be arranged for use. 2. Variation in Number of Contacts In addition to the dip type, SMT and crimping types are available with broad variations. 3. Stacking Variation When the connector is used for board to board, set 6mm between boards in conjunction with the pin header A3B, or 5. 1mm between boards in conjunction with the pin header A3C. Applications Various kinds of electronic equipment 2 A3/A4 Series/2mm Pitch Miniature Connector Product Specifications Rated Current 1A Operating Temperature (Note 1) -55 to +85℃ Rated Voltage 200V AC Storage Temperature (Note 2) -10 to +60℃ Operating Humidity Range 40 to 80% Storage Humidity Range (Note 2) 40 to 70% Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Items Specifications Conditions Insulation Resistance 1000M Ω Min. Measured at 500V DC Withstanding Voltage No flashover or insulation breakdown 650V AC for 1 min Contact Resistance 15m Ω Max. Measured at 0.1A Vibration Resistance No electrical discontinuity of 10μ s or more. Frequency : 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. Humidity Resistance Insulation Resistance : 1000M Ω Min. 96 hours at temperature of 40 ± 2℃ and humidity of 90% to 95% Temperature Cycles No damage, cracks, or parts looseness. -65℃ : 30 minutes → 15 to 35℃ : MAX 5 minutes → 125℃ : 30 minutes → 15 to 35℃ : MAX 5 minutes, 5 cycles Mating Durability Contact Resistance : 20m Ω Max. 100 times Solder Heat Resistance No dissolution of the resin part affecting performance. Solder tank : 260℃ , 10sec. Hand soldering : temperature of soldering iron at 350℃ for 3sec. Note 1 : Includes temperature rise caused by current flow. Note 2 : The storage condition refers to long-term storage of the product on the shelf before assembly. Please use the operating temperature for temporary storage such as pre-assembly and during shipping. Note 3 : Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. Materials / Finish Item Component Material Pin Header (Through Hole) Polyamide Receptacle (Through Hole) PBT Pin Header (SMT) Insulator Receptacle (SMT) Crimp Socket Pin Header Receptacle Crimp Contact Color / Finish Remarks Black PPS Light Brown PBT Black UL94V-0 Brass Contact Phosphorous Bronze Note : Slight variations in color of the plastic compounds do not affect form, fit or function of the connector. 3 Partially Gold Plating - A3/A4 Series/2mm Pitch Miniature Connector Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ■ Pin Header (Through Hole type) A 3B - 12 P - 2 DS Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❺ ❻ ❶ Series Name A ❹ Connector Type P, PA: Pin Header ❷ Series No. 3B : Dual-Row 4B : Single-Row 3C : Dual-Row (Low Profile Product) ❺ Contact Pitch 2mm ❸ No. of Pos. Dual-Row : 4, 6, 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28, 30, 32, 44, 50 (44 and 50 pos. correspond to the right angle type only. Straight angle type corresponds to the A3C type.) Single-Row : 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16 ❻ Housing Type DS : Right Angle Type DSA : Straight Type ■ Pin Header (SMT type) A 3 A - 44 P A - 2 SV ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ ❶ Series Name A ❺ Connector Type P:Pin Header ❷ Series No. 3 ❻ A Partially Gold Plating ❸ Positioning Boss A : With Boss No Symbol : Without Boss ❼ Contact Pitch 2mm ❹ No. of Pos. 4, 6, 8, 10, 12, 14, 16, 18, 20, 24, 28, 30, 32, 44, 50 ❽ Housing Type SV : Board Vertical Type ■ Receptacle (Through Hole type) A 3 - 44 D - 2 DS ❶ ❷ ❸ ❹ ❺ ❻ ❶ Series Name A ❹ Connector Type DA:Receptacle ❷ Series No. 3 : Dual-Row 3C : Dual-Row 3D : Dual-Row (For FPC, FFC)(Note) ❺ Contact Pitch 2mm ❸ No. of Pos. 3 : 44, 50 3C, 3D : 4, 6, 8, 10, 12, 14, 16, 18, 20, 24, 28, 32, 50 ❻ Housing Type DS : DSA DSC DSE Note : A standoff has been added to the center portion of the connector to provide stable mounting. 4 Right Angle Type : Straight Type (Lead Length 3mm) : Straight Type (Lead Length 2mm) : Straight Type (Lead Length 1.27mm) A3/A4 Series/2mm Pitch Miniature Connector ■ Receptacle (SMT Type) A 3 A - 32 D A - 2 SV Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ ❶ Series Name A ❺ Connector Type D:Receptacle ❷ Series No. 3 ❻ A Partially Gold Plating ❸ Positioning Boss A : With Boss No Symbol : Without Boss ❼ Contact Pitch 2mm ❹ No. of Pos. 4, 6, 8, 10, 12, 14, 16, 18, 20, 24, 28, 30, 32 ❽ Housing Type SV : Board Vertical Type ■ Crimp Socket A 3B - 44 D - 2 C ❶ ❷ ❸ ❹ ❺ ❻ ❶ Series Name A ❹ Contact Alignment D : Dual-Row S : Single-Row ❷ Series No. 3B : Dual-Row 4B : Single-Row ❺ Contact Pitch 2mm ❸ No. of Pos. Dual-Row : 8, 10, 12, 14, 18, 20, 24, 28, 44 Single-Row : 2, 3, 4, 5, 6, 8, 10, 12, 15, 16, 18 ❻ Connection Type C : Crimping ■ Crimp Contact A 3B - 2630 SCFC ❶ ❷ ❸ ❹ ❶ Series Name A ❸ Applicable Wire Size 2630 : 26 to 30 AWG ❷ Series No. 3B ❹ Packaging Type SCFC : Reel Contact SCC : Loose Contact 5 A3/A4 Series/2mm Pitch Miniature Connector Connector Mating Combinations Diagram ●Receptacle and Socket Side ●Pin Header Side Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Straight SMT Type Straight SMT Type A3(A)-#DA-2SV A3(A)-#PA-2SV Straight Through Hole Type Straight Through Hole (low profile) Type A3C(D)-#DA-2DSA(DSC, DSE) A3C-#P-2DSA Straight Through Hole Type Cable Crimping Type A3B-#D-2C A3B-#PA-2DSA Right Angle Through Hole Type A3B-#PA-2DS 6 A3/A4 Series/2mm Pitch Miniature Connector Pin Header Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● A3B Straight Type (Dual-Row) Unit : mm Part No. HRS No. No. of Pos. A B A3B-4PA-2DSA(51) CL0621-0401-1-51 4 4 2 A3B-6PA-2DSA(51) CL0621-0402-4-51 6 6 4 A3B-8PA-2DSA(51) CL0621-0403-7-51 8 8 6 A3B-10PA-2DSA(51) CL0621-0404-0-51 10 10 8 A3B-12PA-2DSA(51) CL0621-0405-2-51 12 12 10 A3B-14PA-2DSA(51) CL0621-0406-5-51 14 14 12 A3B-16PA-2DSA(51) CL0621-0407-8-51 16 16 14 A3B-18PA-2DSA(51) CL0621-0408-0-51 18 18 16 A3B-20PA-2DSA(51) CL0621-0409-3-51 20 20 18 A3B-22PA-2DSA(51) CL0621-0410-2-51 22 22 20 A3B-24PA-2DSA(51) CL0621-0411-5-51 24 24 22 A3B-26PA-2DSA(51) CL0621-0412-8-51 26 26 24 A3B-28PA-2DSA(51) CL0621-0413-0-51 28 28 26 A3B-30PA-2DSA(51) CL0621-0414-3-51 30 30 28 A3B-32PA-2DSA(51) CL0621-0415-6-51 32 32 30 7 RoHS Purchase Unit 〇 100pcs per bag A3/A4 Series/2mm Pitch Miniature Connector ■Recommended PCB Dimensions B±0.1 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2±0.05 2±0.05 ● A3B +0.1 φ0.8 _0 Right Angle Type (Dual-Row) 8 A3/A4 Series/2mm Pitch Miniature Connector Unit : mm HRS No. No. of Pos. A B Kink Positions A3B-4PA-2DS(51) CL0621-0351-5-51 4 4 2 2 A3B-6PA-2DS(51) CL0621-0352-8-51 6 6 4 1 or 2 alternately A3B-8PA-2DS(51) CL0621-0353-0-51 8 8 6 2 alternately A3B-10PA-2DS(51) CL0621-0354-3-51 10 10 8 2 or 3 alternately A3B-12PA-2DS(51) CL0621-0355-6-51 12 12 10 3 alternately A3B-14PA-2DS(51) CL0621-0356-9-51 14 14 12 3 or 4 alternately A3B-16PA-2DS(51) CL0621-0357-1-51 16 16 14 4 alternately A3B-18PA-2DS(51) CL0621-0358-4-51 18 18 16 4 or 5 alternately A3B-20PA-2DS(51) CL0621-0359-7-51 20 20 18 5 alternately A3B-22PA-2DS(51) CL0621-0360-6-51 22 22 20 5 or 6 alternately A3B-24PA-2DS(51) CL0621-0361-9-51 24 24 22 6 alternately A3B-26PA-2DS(51) CL0621-0362-1-51 26 26 24 6 or 7 alternately A3B-28PA-2DS(51) CL0621-0363-4-51 28 28 26 7 alternately A3B-30PA-2DS(51) CL0621-0364-7-51 30 30 28 7 or 8 alternately A3B-32PA-2DS(51) CL0621-0365-0-51 32 32 30 8 alternately A3B-44PA-2DS(51) CL0621-0377-9-51 44 44 42 11 alternately A3B-50PA-2DS(51) CL0621-0383-1-51 50 50 48 12 or 13 alternately ■Recommended PCB Dimensions (t=1.6) B±0.1 2±0.05 2±0.05 Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. (Note) φ0.9±0.04 Note : Diameter of 28 or more contacts is φ 0.95 ± 0.04. 9 RoHS Purchase Unit 100pcs per tray 〇 50pcs per tray 40pcs per tray A3/A4 Series/2mm Pitch Miniature Connector Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● A4B Straight Type (Single-Row) Unit : mm Part No. HRS No. No. of Pos. A B A4B-2PA-2DSA(51) CL0622-0401-8-51 2 4 2 A4B-3PA-2DSA(51) CL0622-0402-0-51 3 6 4 A4B-4PA-2DSA(51) CL0622-0403-3-51 4 8 6 A4B-5PA-2DSA(51) CL0622-0404-6-51 5 10 8 A4B-6PA-2DSA(51) CL0622-0405-9-51 6 12 10 A4B-7PA-2DSA(51) CL0622-0406-1-51 7 14 12 A4B-8PA-2DSA(51) CL0622-0407-4-51 8 16 14 A4B-9PA-2DSA(51) CL0622-0408-7-51 9 18 16 A4B-10PA-2DSA(51) CL0622-0409-0-51 10 20 18 A4B-12PA-2DSA(51) CL0622-0411-1-51 12 24 22 A4B-13PA-2DSA(51) CL0622-0412-4-51 13 26 24 A4B-14PA-2DSA(51) CL0622-0413-7-51 14 28 26 A4B-15PA-2DSA(51) CL0622-0414-0-51 15 30 28 A4B-16PA-2DSA(51) CL0622-0415-2-51 16 32 30 ■Recommended PCB Dimensions B±0.1 2±0.05 φ0.8 +0.1 0 10 RoHS Purchase Unit 〇 100pcs per bag A3/A4 Series/2mm Pitch Miniature Connector Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● A4B Right Angle Type (Single-Row) Unit : mm Part No. HRS No. No. of Pos. A B Kink Positions A4B-2PA-2DS(51) CL0622-0351-1-51 2 4 2 2 A4B-3PA-2DS(51) CL0622-0352-4-51 3 6 4 1 or 2 alternately A4B-4PA-2DS(51) CL0622-0353-7-51 4 8 6 2 alternately A4B-5PA-2DS(51) CL0622-0354-0-51 5 10 8 2 or 3 alternately A4B-6PA-2DS(51) CL0622-0355-2-51 6 12 10 3 alternately A4B-7PA-2DS(51) CL0622-0356-5-51 7 14 12 3 or 4 alternately A4B-8PA-2DS(51) CL0622-0357-8-51 8 16 14 4 alternately A4B-9PA-2DS(51) CL0622-0358-0-51 9 18 16 4 or 5 alternately A4B-10PA-2DS(51) CL0622-0359-3-51 10 20 18 5 alternately A4B-11PA-2DS(51) CL0622-0360-2-51 11 22 20 5 or 6 alternately A4B-12PA-2DS(51) CL0622-0361-5-51 12 24 22 6 alternately A4B-13PA-2DS(51) CL0622-0362-8-51 13 26 24 6 or 7 alternately A4B-14PA-2DS(51) CL0622-0363-0-51 14 28 26 7 alternately A4B-15PA-2DS(51) CL0622-0364-3-51 15 30 28 7 or 8 alternately A4B-16PA-2DS(51) CL0622-0365-6-51 16 32 30 8 alternately ■Recommended PCB Dimensions (t=1.6) B±0.1 2±0.05 (Note) φ0.9±0.04 Note : Diameter of 14 or more contacts is φ 0.95 ± 0.04. 11 RoHS Purchase Unit 〇 100pcs per bag A3/A4 Series/2mm Pitch Miniature Connector Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● A3C Straight Type (Dual-Row for Low Profile Product) Unit : mm Part No. HRS No. No. of Pos. A B A3C-2P-2DSA(30) CL0621-0601-0-30 2 2 - A3C-4P-2DSA(30) CL0621-0602-3-30 4 4 2 A3C-6P-2DSA(30) CL0621-0603-6-30 6 6 4 A3C-8P-2DSA(30) CL0621-0604-9-30 8 8 6 A3C-10P-2DSA(30) CL0621-0605-1-30 10 10 8 A3C-12P-2DSA(30) CL0621-0606-4-30 12 12 10 A3C-14P-2DSA(30) CL0621-0607-7-30 14 14 12 A3C-16P-2DSA(30) CL0621-0608-0-30 16 16 14 A3C-18P-2DSA(30) CL0621-0609-2-30 18 18 16 A3C-20P-2DSA(30) CL0621-0610-1-30 20 20 18 A3C-24P-2DSA(30) CL0621-0612-7-30 24 24 22 A3C-26P-2DSA(30) CL0621-0613-0-30 26 26 24 A3C-28P-2DSA(30) CL0621-0614-2-30 28 28 26 A3C-32P-2DSA(30) CL0621-0615-5-30 32 32 30 A3C-44P-2DSA(30) CL0621-0622-0-30 44 44 42 A3C-48P-2DSA(30) CL0621-0625-9-30 48 48 46 A3C-50P-2DSA(30) CL0621-0628-7-30 50 50 48 12 RoHS Purchase Unit 〇 100pcs per bag A3/A4 Series/2mm Pitch Miniature Connector Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Recommended PCB Dimensions ● SMT Type 13 A3/A4 Series/2mm Pitch Miniature Connector Unit : mm Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. A3-4PA-2SV(71) CL0621-1000-6-71 A3A-4PA-2SV(71) CL0621-1040-0-71 A3-6PA-2SV(71) CL0621-1001-9-71 A3A-6PA-2SV(71) CL0621-1041-3-71 A3-8PA-2SV(71) CL0621-1002-1-71 A3A-8PA-2SV(71) CL0621-1042-6-71 A3-10PA-2SV(71) CL0621-1003-4-71 A3A-10PA-2SV(71) CL0621-1043-9-71 A3-12PA-2SV(71) CL0621-1004-7-71 A3A-12PA-2SV(71) CL0621-1044-1-71 A3-14PA-2SV(71) CL0621-1005-0-71 A3A-14PA-2SV(71) CL0621-1045-4-71 A3-16PA-2SV(71) CL0621-1006-2-71 A3A-16PA-2SV(71) CL0621-1046-7-71 A3-20PA-2SV(71) CL0621-1008-8-71 A3A-20PA-2SV(71) CL0621-1048-2-71 A3-24PA-2SV(71) CL0621-1010-0-71 A3A-24PA-2SV(71) CL0621-1050-4-71 A3-28PA-2SV(71) CL0621-1012-5-71 A3A-28PA-2SV(71) CL0621-1052-0-71 A3-32PA-2SV(71) CL0621-1014-0-71 A3A-32PA-2SV(71) CL0621-1054-5-71 A3-44PA-2SV(71) CL0621-1015-3-71 A3A-44PA-2SV(71) CL0621-1055-8-71 A3-50PA-2SV(71) CL0621-1016-6-71 A3A-50PA-2SV(71) CL0621-1056-0-71 No. of Pos. A B 4 4 2 6 6 4 8 8 6 10 10 8 12 12 10 14 14 12 16 16 14 20 20 18 24 24 22 28 28 26 32 32 30 44 44 42 50 50 48 RoHS - 120pcs per tube 2 - 80pcs per tube 2 - 60pcs per tube 4 - 48pcs per tube 6 - 40pcs per tube 8 - 34pcs per tube 10 12 16 20 24 28 40 46 Purchase Unit 〇 30pcs per tube 24pcs per tube 20pcs per tube 17pcs per tube 15pcs per tube 11pcs per tube 9pcs per tube ■Recommended PCB Dimensions e) ot (N e) ot (N PCB mounting pattern for 4 pos. Note : The connector positioning boss is a structure that is lightly press-fitted into the board hole. When mounting on the board, press the connector lightly from above to make sure that the positioning boss is inserted securely into the board hole and that the connector leads are not floating off the board. For automatic 0.1 board placement, recommended boss dia. is φ 1.2 + . -0 14 A3/A4 Series/2mm Pitch Miniature Connector Receptacle Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● A3 Right Angle Type (Dual-Row) Unit : mm Part No. HRS No. A B A3-44DA-2DS(71) CL0621-0711-9-71 44 42 A3-50DA-2DS(71) CL0621-0714-7-71 50 48 ■Recommended PCB Dimensions 15 RoHS Purchase Unit 〇 40pcs per tray A3/A4 Series/2mm Pitch Miniature Connector Straight Type (Dual-Row) Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● A3C 16 A3/A4 Series/2mm Pitch Miniature Connector Unit : mm Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. No. of Pos. A B 4 4 2 6 6 4 8 8 6 10 10 8 12 12 10 14 14 12 16 16 14 18 18 16 20 20 18 C A3C-4DA-2DSA(71) CL0621-0501-6-71 A3C-4DA-2DSC(71) CL0621-0531-7-71 A3C-6DA-2DSA(71) CL0621-0502-9-71 A3C-6DA-2DSC(71) CL0621-0532-0-71 A3C-8DA-2DSA(71) CL0621-0503-1-71 A3C-8DA-2DSC(71) CL0621-0533-2-71 A3C-10DA-2DSA(71) CL0621-0504-4-71 A3C-10DA-2DSC(71) CL0621-0534-5-71 A3C-12DA-2DSA(71) CL0621-0505-7-71 A3C-12DA-2DSC(71) CL0621-0535-8-71 A3C-14DA-2DSA(71) CL0621-0506-0-71 A3C-14DA-2DSC(71) CL0621-0536-0-71 A3C-16DA-2DSA(71) CL0621-0507-2-71 A3C-16DA-2DSC(71) CL0621-0537-3-71 A3C-18DA-2DSA(71) CL0621-0508-5-71 A3C-18DA-2DSC(71) CL0621-0538-6-71 A3C-20DA-2DSA(71) CL0621-0509-8-71 A3C-20DA-2DSC(71) CL0621-0539-9-71 A3C-24DA-2DSA(71) CL0621-0511-0-71 A3C-24DA-2DSC(71) CL0621-0541-0-71 3 A3C-24DA-2DSE(71) CL0621-0571-1-71 A3C-28DA-2DSA(71) CL0621-0513-5-71 A3C-28DA-2DSC(71) CL0621-0543-6-71 A3C-32DA-2DSA(71) CL0621-0515-0-71 A3C-32DA-2DSC(71) CL0621-0545-1-71 A3C-32DA-2DSE(71) CL0621-0575-2-71 1.27 A3C-50DA-2DSA(71) CL0621-0524-1-71 3 A3C-50DA-2DSC(71) CL0621-0554-2-71 A3C-50DA-2DSE(71) CL0621-0584-3-71 3 24 22 3 28 26 270pcs per tray 2 3 220pcs per tray 2 3 180pcs per tray 2 3 150pcs per tray 2 3 130pcs per tray 2 2 3 2 2 1.27 28 350pcs per tray 2 3 3 2 Purchase Unit 520pcs per tray 2 3 24 RoHS 〇 120pcs per tray 110pcs per tray 90pcs per tray 60pcs per tray 70pcs per tray 3 32 32 50 50 30 48 2 2 1.27 ■Recommended PCB Dimensions 17 60pcs per tray 40pcs per tray A3/A4 Series/2mm Pitch Miniature Connector Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● A3D Straight Type (Dual-Row for FPC and FFC) Unit : mm Part No. HRS No. No. of Pos. A B A3D-8DA-2DSE(71) CL0621-0753-9-71 8 8 6 A3D-14DA-2DSE(71) CL0621-0756-7-71 14 14 12 A3D-44DA-2DSE(71) CL0621-0766-0-71 44 44 42 ■Recommended PCB Dimensions 18 RoHS Purchase Unit 540pcs per tray 〇 300pcs per tray 100pcs per tray A3/A4 Series/2mm Pitch Miniature Connector Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● SMT Type Unit : mm Part No. HRS No. A3-4DA-2SV(71) CL0621-1100-0-71 A3A-4DA-2SV(71) CL0621-1140-5-71 A3-6DA-2SV(71) CL0621-1101-3-71 A3A-6DA-2SV(71) CL0621-1141-8-71 A3-8DA-2SV(71) CL0621-1102-6-71 A3A-8DA-2SV(71) CL0621-1142-0-71 A3-10DA-2SV(71) CL0621-1103-9-71 A3A-10DA-2SV(71) CL0621-1143-3-71 A3-12DA-2SV(71) CL0621-1104-1-71 A3A-12DA-2SV(71) CL0621-1144-6-71 A3-14DA-2SV(71) CL0621-1105-4-71 A3A-14DA-2SV(71) CL0621-1145-9-71 A3-16DA-2SV(71) CL0621-1106-7-71 A3A-16DA-2SV(71) CL0621-1146-1-71 A3-20DA-2SV(71) CL0621-1108-2-71 A3A-20DA-2SV(71) CL0621-1148-7-71 A3-24DA-2SV(71) CL0621-1110-4-71 A3A-24DA-2SV(71) CL0621-1150-9-71 A3-28DA-2SV(71) CL0621-1112-0-71 A3A-28DA-2SV(71) CL0621-1152-4-71 A3-32DA-2SV(71) CL0621-1114-5-71 A3A-32DA-2SV(71) CL0621-1154-0-71 No. of Pos. A B 4 4 2 6 6 4 8 8 6 10 10 8 12 12 10 14 14 12 16 16 14 20 20 18 24 24 22 28 28 26 32 32 30 19 C RoHS - 120pcs per tube 2 - 80pcs per tube 2 - 60pcs per tube 4 - 48pcs per tube 6 - 40pcs per tube 8 10 12 16 20 24 28 Purchase Unit 〇 34pcs per tube 30pcs per tube 24pcs per tube 20pcs per tube 17pcs per tube 15pcs per tube A3/A4 Series/2mm Pitch Miniature Connector ■Recommended PCB Dimensions e) ot (N e) ot (N Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCB mounting pattern for 4 pos. Note : The connector positioning boss is a structure that is lightly press-fitted into the board hole. When mounting on the board, press the connector lightly from above to make sure that the positioning boss is inserted securely into the board hole and that the connector leads are not floating off the board. For automatic 0.1 board placement, recommended boss dia. is φ 1.2 + . -0 20 A3/A4 Series/2mm Pitch Miniature Connector Crimp Socket Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● A3B-#D-2C (Dual-Row) * Contact No. * mark Contact No. 2 mark Contact No. *-1 mark Contact No. 1 mark Note : * indicates the number of contacts. Unit : mm Part No. HRS No. No. of Pos. A B A3B-8D-2C CL0621-0307-3-00 8 8 6 A3B-10D-2C CL0621-0308-6-00 10 10 8 A3B-12D-2C CL0621-0309-9-00 12 12 10 A3B-14D-2C CL0621-0310-8-00 14 14 12 A3B-18D-2C CL0621-0311-0-00 18 18 16 A3B-20D-2C CL0621-0312-3-00 20 20 18 A3B-24D-2C CL0621-0313-6-00 24 24 22 A3B-28D-2C CL0621-0314-9-00 28 28 26 A3B-44D-2C CL0621-0330-5-00 44 44 42 Note : Use other No. of Pos. in combination. (Example : 50 No. of Pos. = 44 No. of Pos. + 6 No. of Pos.) 21 RoHS Purchase Unit 〇 100pcs per bag A3/A4 Series/2mm Pitch Miniature Connector Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● A4B-#S-2C (Single-Row) * Contact No. 1 mark Contact No. * mark Note : * indicates the number of contacts. Unit : mm Part No. HRS No. No. of Pos. A B A4B-2S-2C CL0622-0301-3-00 2 4 2 A4B-3S-2C CL0622-0302-6-00 3 6 4 A4B-4S-2C CL0622-0303-9-00 4 8 6 A4B-5S-2C CL0622-0304-1-00 5 10 8 A4B-6S-2C CL0622-0305-4-00 6 12 10 A4B-8S-2C CL0622-0306-7-00 8 16 14 A4B-10S-2C CL0622-0307-0-00 10 20 18 A4B-12S-2C CL0622-0308-2-00 12 24 22 A4B-15S-2C CL0622-0311-7-00 15 30 28 A4B-16S-2C CL0622-0310-4-00 16 32 30 A4B-18S-2C CL0622-0309-5-00 18 36 34 22 RoHS Purchase Unit 〇 100pcs per bag A3/A4 Series/2mm Pitch Miniature Connector Crimp Contact SCFC Contact Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. SCC Contact Note 2 Note 2 Part No. HRS No. A3B-2630SCFC CL0621-0301-7-00 A3B-2630SCC CL0621-0302-0-00 RoHS Applicable Wire Type Crimping Tool Purchase Unit 26 to 30 AWG Reel Contact Automatic crimper CM-105C + AP105-A3B-2630S 10,000pcs per reel 26 to 30 AWG Loose Contact A3B-TA2630HC 100pcs per bag 〇 (Note 3) Note 1 : The plating specification is shown as follows: (Contact area) : Gold plating (Others) : Nickel plating Note 2 : "30" is stamped on A3B-2630SCFC(SCC). Note 3 : Only crimp contacts are RoHS compliant. 23 A3/A4 Series/2mm Pitch Miniature Connector Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Short Pin HRS No. HRS No. A3-SP(A) CL0621-0180-4-00 Component Case Contact Material Color / Finish Remarks PBT Black UL94V-0 Phosphorous Bronze Partially Gold Plating - RoHS Purchase Unit 〇 1,000pcs per bag Polarizing Key A3-GPIN(A) Note 1 HRS No. A3-GPIN(A) HRS No. CL0621-0178-2-00 Material RoHS Purchase Unit Poly acetal (white) 〇 100pcs per bag Note 1 : This product is provided in a set of 10 pieces in conjunction with a runner. Note 2 : This product cannot be used for A3E series. 24 A3/A4 Series/2mm Pitch Miniature Connector Mated Dimensions Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Note : When the connector is mounted on the board surface, the mounting height is a size designed in single connector. Solder paste used for installation will slightly change according to solder thickness. A3(A)-#DA-2SV A3C-#DA-2DSA A3(A)-#PA-2SV A3(A)-#PA-2SV A3C-#DA-2DSA A3B-#D-2C A3(A)-#PA-2SV A3B-#D-2C A3(A)-#DA-2SV A3C-#P-2DSA A3C-#P-2DSA A3C-#P-2DSA A3(A)-#DA-2SV A3C-#DA-2DSA A3B-#D-2C A3B-#PA-2DSA A3B-#PA-2DSA A3B-#PA-2DSA A3(A)-#DA-2SV A3C-#DA-2DSA A3B-#D-2C A3B-#PA-2DS A3B-#PA-2DS 25 A3B-#PA-2DS A3/A4 Series/2mm Pitch Miniature Connector Applicable Crimping Tool Manual crimping tool Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● A3B-TA2630HC Automatic crimping machine ● CM-105C This machine is a new model in response to the demands of many users. It has been carefully designed to improve usability and expand the range of applications, including set- up adjustment and installation of various applicators. As an easy- to- use semi- Automatic Crimp Machine, it can be used for crimping and connecting various chain- shaped Contact. Specification Power Supply 100V AC, single phase 200W Gross Weight 75 kg Machining Range 2000 to 4000 contacts/hour Remarks Crimping of various contacts by replacing the applicator Item Manual Crimping Tool Automatic Crimping Machine Applicator Part No. HRS No. A3B-TA2630HC CL0550-0200-7-00 CM-105C CL0901-0001-0-00 AP105-A3B-2630S CL0901-4016-2-00 26 Applicable Contact A3B-2630SCC A3B-2630SCFC Applicable Cable 26 to 30 AWG 26 to 30 AWG A3/A4 Series/2mm Pitch Miniature Connector Precautions 260 MAX 250℃ 240 220℃ 220 200℃ Temperature(℃) Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 200 180 160 140 0 150℃ 90 to120 sec. Preheating(150~200℃) MAX 60 sec. Soldering 220℃ MIN Time(sec.) Solder Method Reflow, IR/hot air (SENSBEY NR-2) Room air Solder Paste (Flux content 11Wt%) (M705-221CM5-42-10.5) Board 85 × 60 × 1.6mm Metal Mask 0.2mm ・This Temperature Profile is the recommended value. The temperature is measured at the top of the connector. ・The reflow process should be performed no more than twice. ・In individual applications the actual temperature may vary, depending on solder paste type, volume/thickness and board size/ thickness, so please check the condition of mounting before use. Also, consult the recommended aperture ratio for metal mask 0.15 mm or smaller. While taking in consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please review the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, the warranty of the product may be affected. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. HIROSE 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com ※ The contents of this catalog are current as of date of 4/ 2023. Contents are subject to change without notice for the purpose of improvements. ※ The HRS logo and "HIROSE" are trademarks of HIROSE ELECTRIC CO., LTD. 27
A4B-2PA-2DSA(51) 价格&库存
很抱歉,暂时无法提供与“A4B-2PA-2DSA(51)”相匹配的价格&库存,您可以联系我们找货
A4B-2PA-2DSA(51)
  • 100+1.86512
  • 200+1.82763
  • 400+1.79118
库存:900
A4B-2PA-2DSA(51)
    • 10+2.7865110+0.36061
    • 50+2.4447750+0.31639
    • 100+2.15560100+0.27896
    • 200+2.08550200+0.26989
    • 400+1.93654400+0.25061
    库存:450
    A4B-2PA-2DSA(51)
    • 10+2.37540
    • 30+2.32229
    • 50+2.27543
    库存:900
