BCS–108–L–D–HE
F-218 (Rev 10OCT17)
BCS–110–L–S–DE
BCS–110–L–S–HE
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
BCS–115–L–D–TE
BCS–112–L–D–PE
(2.54 mm) .100"
BCS SERIES
TIGER CLAW PASS-THROUGH SOCKET
Mates with:
TSW, MTSW, HTSW,
HMTSW, TSS, ZSS,
DW, EW, ZW, HW, TSM,
MTLW, PHT
1
BCS
PLATING
OPTION
NO. PINS
PER ROW
SPECIFICATIONS
–S
= Gold flash on contact,
Matte Tin on tail
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (BCS/TSW):
4.6 A per pin
(2 pins powered)
Voltage Rating:
475 VAC
(-TE/-DE/-PE mated with TSM)
450 VAC
(-HE mated with TSW)
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
(4.34 mm) .171" to
(7.24 mm) .285" from top,
(5.64 mm) .222" plus
board thickness minimum
from bottom.
–HE is (4.34 mm) .171"
to (6.35 mm) .250"
RoHS Compliant:
Yes
Lead–Free Solderable:
Yes
OTHER
OPTION
–“XXX”
= Single
–F
For complete specifications
see www.samtec.com?BCS
ENTRY
OPTION
ROW
OPTION
= Polarized
Position
(–BE not
available)
–D
= Double
–L
= 10 µ" (0.25 µm) Gold on contact,
Matte Tin on tail
01 thru 50
–TE
01
= Top
Entry
02
(0.25)
.010
(2.54)
.100
(3.05)
.120
(2.54)
.100
(0.89) .035 SQ TYP
02
–DE
(2.54)
.100
(5.08)
.200
01
RECOGNITIONS
(3.05)
.120
(2.54) .100 x No. of Positions
(0.25)
.010
(4.06)
.160
(1.78)
.070
For complete scope
of recognitions see
www.samtec.com/quality
(7.37)
.290
= Top Entry
(For Bottom
Entry specify
–DE–BE)
Cannot be
used with plated
through-holes
–PE
FILE NO. E111594
(3.25)
.128
(0.48)
.019
(2.54)
.100
(0.51)
.020
(0.25)
.010
(5.08)
.200
ALSO AVAILABLE
(7.62)
.300
= Passthrough
Entry
(For Bottom
Entry specify
–PE–BE)
(MOQ Required)
• Other platings
Contact Samtec.
APPLICATIONS
BCS
TSW
(0.89) .035 SQ TYP
(8.13) .320
(2.79)
.110
(3.18)
.125
(0.25)
.010
HORIZONTAL
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
–HE
= Horizontal
Entry
(5.72)
.225
(5.33)
.210
(0.51)
.020
(2.54)
.100
(3.18)
.125
(7.87) .310
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
很抱歉,暂时无法提供与“BCS-115-F-D-PE”相匹配的价格&库存,您可以联系我们找货
