BH6P-VH-1(LF)(SN)
BH6P-VH-1(LF)(SN)
    JST
    插件,P=3.96mm
    线对板针座 1x6P 直插 间距:3.96mm
BH6P-VH-1(LF)(SN) 数据手册
VH CONNECTOR High box type 3.96mm pitch/Disconnectable Crimp style connectors Specifications ––––––––––––––––––– • Current rating: 7 A AC, DC (AWG #18) 10 A AC, DC (AWG #16)/1 circuit only • Voltage rating: 250 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,500 VAC/minute • Applicable wire: AWG #22 to #16 • Applicable PC board thickness: 1.6 mm Note: Do not branch in parallel current which exceeds the rated current. If branched in parallel, current imbalance or other problems may develop. If it is absolutely necessary to branch such a large current in parallel, be sure to use contacts made of phosphor bronze. Design the circuits without causing imbalance and provide an extra margin for each circuit. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. This is VH connector high box type, with 21.3 mm mounting height (single circuit: 18.6 mm) and with 9.2 mm thickness (single circuit: 8 mm). This connector exhibits the stable electric connection to the condition such as the vibration, the prying, the microcurrent and micro-voltage circuit. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 2 R75122 • Header for use specifically with resin coated ("potted") PC board • Interchangeability PC board layout and Assembly layout 10.6 10.5 ±0.1 8 +0.1 1.3 0 +0.1 0 1.5 1.3 ±0.05 +0.1 (21.3) ±0.05 (18.6) +0.1 φ1.65 0 3.4 +0.1 0 φ1.65 φ1.4 0 3.96 ±0.1 3.6 ±0.1 3.6 0.8 ±0.1 ±0.05 Note: 1. The above figure is the figure viewed from soldering side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guide line. Contact JST for details. 1 VH CONNECTOR High box type Contact Applicable wire Model No. SVH-21T-P1.1 *SVH-41T-P1.1 10.6 3 4.2 4 mm2 AWG# Insulation O.D. (mm) Q't y/ reel 0.33∼0.83 22∼18 1.7∼3.0 4,500 0.5 ∼1.25 20∼16 1.7∼3.0 3,500 Material and Finish 3.8 Phosphor bronze, tin-plated (reflow treatment) RoHS compliance Note: 1. *The current rating when combining with single circuit is 10 A AC, DC (AWG #16.) 2. When using retainer mountable type housing, applicable wire's insulation O. D. shall be 1.7 to 2.2 mm. Crimping machine Crimp applicator Contact SVH-21T-P1.1 AP-K2N Applicator Dies MKS-L MK/SVH-21-11 APLMK SVH21-11 *MKS-SC SC/SVH-21-11 APLSC SVH21-11 Applicator Dies Crimp applicator with dies MKS-L MK/SVH-41-11 APLMK SVH41-11 — — — Crimping machine Crimp applicator Contact Crimp applicator with dies SVH-41T-P1.1 AP-K2N Note: *Strip-crimp applicator Housing N Type Circuits 6.2 1 B 2 A 3 4 5.7 10.5 5 6 7 H JST 8 N type VHR-1N VHR-2N VHR-3N VHR-4N VHR-5N VHR-6N VHR-7N VHR-8N Model No. Retainer mountable type ― ― VHRR-3N ― VHRR-5N ― VHRR-7N VHRR-8N Dimensions (mm) A B ― ― Q'ty/ bag 1,000 3.96 7.86 7.92 11.82 1,000 11.88 15.78 15.84 19.74 19.80 23.70 500 23.76 27.66 500 27.72 31.62 500 * 1,000 * Material 13.3 14.6 PA 6, UL94V-0, natural (white) RoHS compliance * N type ; 1,000 Retainer mountable type ; 500 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. VHR-2N-oo(blank)…natural (white) BK…black R…red BL…blue M…green D…orange Y…yellow PK…pink H…gray Retainer mountable type B 15 5.7 10.5 A 2 VH CONNECTOR High box type Retainer Model No. VHS-3V VHS-5V VHS-7V VHS-8V Circuits 3 5 7 Q’ty/bag 1,000 15.44 1,000 23.36 1,000 27.32 1,000 Material A 4.2 8 A 7.52 Glass-filled PA 66, UL94V-0, natural (ivory) RoHS compliance 7.1 Shrouded header Model No. With a boss BH1P-VH-1 Circuits With a boss 1 Q'ty/box 500 Material and Finish 9.1 Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL-94V-0, natural (white) 3 4 13.4 RoHS compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. BH1P-VH-1-oo(blank)…natural (white) BK…black R…red BL…blue M…green O…orange Y…yellow PK…pink 8 □1.14 Circuits 2 3 4 B 5 9.2 6 7 15.8 8 3.5 φ1.2 3.96 A 1.5 Dimensions (mm) A B Q'ty/ box 3.96 9.80 250 7.92 13.76 200 11.88 17.72 150 15.84 21.68 100 19.80 25.64 100 23.76 29.60 100 27.72 33.56 100 Material and Finish Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL-94V-0, natural (ivory) 1.5 □1.14 Model No. With a boss BH2P-VH-1 BH3P-VH-1 BH4P-VH-1 BH5P-VH-1 BH6P-VH-1 BH7P-VH-1 BH8P-VH-1 3.4 RoHS compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. BH2P-VH-1-oo(blank)…natural (ivory) BK…black R…red BL…blue M…green Y…yellow 3 3
BH6P-VH-1(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“BH6P-VH-1(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
BH6P-VH-1(LF)(SN)
    • 1+4.963441+0.64523
    • 10+3.4422410+0.44748
    • 50+2.9033150+0.37742
    • 100+2.53822100+0.32996
    • 500+2.46868500+0.32092
    • 1000+2.416531000+0.31414
    • 2000+2.390452000+0.31075
    库存:4
    BH6P-VH-1(LF)(SN)
      • 1+3.567421+0.46376
      • 50+3.1875550+0.41437
      • 100+2.69208100+0.34997
      • 300+2.35350300+0.30595
      • 500+2.28744500+0.29736
      • 1000+2.237891000+0.29092
      • 4000+2.204864000+0.28663
      库存:100
      BH6P-VH-1(LF)(SN)
        库存:68
        BH6P-VH-1(LF)(SN)
          • 1+3.755171+0.48816
          • 50+3.3553250+0.43618
          • 100+2.83377100+0.36838
          • 300+2.47737300+0.32205
          • 500+2.40783500+0.31301
          • 1000+2.355681000+0.30623
          库存:168
