BPH-002T-P0.5S
BPH-002T-P0.5S
    JST
    这是一款薄型、低矮的 2.0 mm 间距连接器,安装后高度为 8.0 mm,宽度为 4.5 mm。它旨在满足内部电线与印刷电路板的高密度连接需求,结构紧凑、可靠性高且成本低。
BPH-002T-P0.5S 数据手册
Crimp PH CONNECTOR Emboss Tape Disconnectable Crimp style connectors 2.0mm (.079") pitch Features –––––––––––––––––––––––– • Reliable contact The contact has long dimples near the center to ensure a good connection at all times, even under conditions of vibration and mechanical abuse, and when used with low voltage and low current circuits. • Easy and effective crimping Although the contact is compact, it has a long wire strip holding length of 2.6 +/- 0.4mm (.102" +/-.016"). This long length simplifies automatic crimping and the crimping of shielded wires. • Fully shrouded header The fully shrouded header has walls on all four sides to prevent improper connection to the mating housing and to prevent the instruction of flux and other contaminants. • High solderable square post The square post is copper-undercoated and tin/lead-plated for superior solderability and for whisker prevention. • Printed circuit board retention mechanism This is a thin, low-profile 2.0mm (.079") pitch connector 7.5mm (.295") in height after mounting and 4.5mm (.177") in width. It is designed to meet the demand for high-density connection of internal wires to printed circuit boards. It is compact, highly reliable and low in cost. The solder side of the header has a retention mechanism that prevents it from floating during soldering. As a result, the header can be positioned accurately. • Compatible with the KR insulation displacement connector The same shrouded header can be used for either PH crimpstyle connector or KR insulation displacement connector. This allows both types of connector to be used interchangeably without replacing the header. • Surface mount model (SMT) This connector is also available in a surface mount configuration. Its housing is made of heat resistant resin so that it is not adversely affected during reflow soldering. Because of its tiny size and ability to be surface mounted, this connector meets the demand for high-density mounting of components inside electronic products. Specifications ––––––––––––––––––– 6 5 4 • Current rating: 2A AC, DC (AWG #24) • Voltage rating: 100V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/10m Ω max. After environmental testing/20m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 800V AC/minute • Applicable wire: AWG #32 to #24 • Applicable PC board thickness: 0.8 to 1.6mm(.031" to .063") * Contact JST for details Standards –––––––––––––––––––––– 0 1 2 Recognized E60389 Certified LR20812 R75087 21 3 2 PH CONNECTOR Contact ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Applicable wire Model No. 5.7(.224) 2.85(.112) 2.05(.081) Q'ty / reel mm2 AWG # Insulation O.D. mm(in.) SPH-002T-P0.5S 0.05 to 0.22 30 to 24 0.9 to 1.5(.035 to .059) 8,000 SPH-004T-P0.5S 0.032 to 0.08 32 to 28 0.5 to 0.9(.020 to .035) 10,000 1.0 (.039) Material and Finish 2.08 (.082) Phosphor bronze, tin-plated Note: 1. When using AWG#32 or #30 wires, reflow-treated headers (Low insertion force type, Model no. B#B-PH-KL or S#B-PH-KL) are recommendable. Note: 2. Contact JST for gold-plated contacts. 1.5 (.059) Housing ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– B 2.0 (.079) 4.5(.177) 6.35(.250) Circuit No.1 A 0.5 (.020) 1.9 (.075) 0.6(.024) Circuits Model No. 2 PHR- 2 3 PHR- 3 4 Dimensions mm(in.) B Q’ty / box 2.0( .079) 5.8( .228) 1,000 4.0( .157) 7.8( .307) 1,000 PHR- 4 6.0( .236) 9.8( .386) 1,000 5 PHR- 5 8.0( .315) 11.8( .465) 1,000 6 PHR- 6 10.0( .394) 13.8( .543) 1,000 7 PHR- 7 12.0( .472) 15.8( .622) 1,000 8 PHR- 8 14.0( .551) 17.8( .701) 1,000 9 PHR- 9 16.0( .630) 19.8( .780) 1,000 10 PHR-10 18.0( .709) 21.8( .858) 1,000 11 PHR-11 20.0( .787) 23.8( .937) 1,000 12 PHR-12 22.0( .866) 25.8(1.016) 1,000 13 PHR-13 24.0( .945) 27.8(1.094) 1,000 14 PHR-14 26.0(1.024) 29.8(1.173) 1,000 15 PHR-15 28.0(1.102) 31.8(1.252) 1,000 16 PHR-16 30.0(1.181) 33.8(1.331) 1,000 A Material and Finish Nylon 66, UL94V-0, natural (white) As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 22 PHR-2-oo(blank)…natural (white) BK…black R…red TR…tomato red BL…blue Y…yellow L…lemon yellow M…green D…orange N…brown P…purple PK…pink H…gray LE…light blue FY…vivid yellow PH CONNECTOR Through-hole type shrouded header ––––––––––––––––––––––––––––––––––––––––– The shrouded headers are interchangeable with those of the KR, KRD and CR insulation displacement connectors. Model No. Top entry type (2 circuits) 4.5(.177) 1.7(.067) 4.5(.177) 1.7(.067) 6.0(.236) B A 3.4 (.134) 1.95 (.077) 3.4 (.134) 6.0(.236) B (3 circuits or more) 0.5 (.020) 2.0 (.079) A 1.95 (.077) Circuit No.1 0.5 (.020) Circuit No.1 Side entry type 1.95 (.077) 2.0 (.079) A 0.5 (.020) 1.6 (.063) 6.0(.236) B 6.25(.246) 4.8(.189) 1.7(.067) Circuit No.1 Q'ty / box Dimensions mm(in.) Circuits Top entry type Side entry type A 2 B 2B-PH-K-S S 2B-PH-K-S 2.0( .079) 3 B 3B-PH-K-S S 3B-PH-K-S 4.0( .157) 4 B 4B-PH-K-S S 4B-PH-K-S 6.0( .236) 5 B 5B-PH-K-S 6 Top entry type Side entry type 5.9( .232) 1,000 1,000 7.9( .311) 1,000 1,000 9.9( .390) 1,000 500 S 5B-PH-K-S 8.0( .315) 11.9( .469) 1,000 500 B 6B-PH-K-S S 6B-PH-K-S 10.0( .394) 13.9( .547) 1,000 500 7 B 7B-PH-K-S S 7B-PH-K-S 12.0( .472) 15.9( .626) 500 500 8 B 8B-PH-K-S S 8B-PH-K-S 14.0( .551) 17.9( .705) 500 250 9 B 9B-PH-K-S S 9B-PH-K-S 16.0( .630) 19.9( .783) 500 250 10 B10B-PH-K-S S10B-PH-K-S 18.0( .709) 21.9( .862) 500 250 11 B11B-PH-K-S S11B-PH-K-S 20.0( .787) 23.9( .941) 500 250 12 B12B-PH-K-S S12B-PH-K-S 22.0( .866) 25.9(1.020) 500 250 13 B13B-PH-K-S S13B-PH-K-S 24.0( .945) 27.9(1.098) 250 250 14 B14B-PH-K-S S14B-PH-K-S 26.0(1.024) 29.9(1.177) 250 250 15 B15B-PH-K-S S15B-PH-K-S 28.0(1.102) 31.9(1.256) 250 200 16 B16B-PH-K-S S16B-PH-K-S 30.0(1.181) 33.9(1.335) 250 200 3.4 (.134) B Material and Finish Post: Brass, copper-undercoated, tin/lead-plated Wafer: Nylon 66, UL94V-0, natural (white) As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B2B-PH-K-ooS…natural (white) BK…black R…red TR…tomato red E…blue Y…yellow L…lemon yellow M…green D…orange N…brown P…purple PK…pink H…gray LE…light blue FY…vivid yellow (blank)…ivory 23 PH CONNECTOR Through-hole type shrouded header ––––––––––––––––– Model No. Top entry type (2 circuits) (3 circuits or more) 4.5(.177) 1.7(.067) 4.5(.177) 1.7(.067) B 0.5 (.020) A 3.4 (.134) 3.4 (.134) 1.95 (.077) 6.0(.236) 6.0(.236) B Circuits Circuit No.1 2.0 (.079) A 1.95 (.077) 0.5 (.020) Circuit No.1 Side entry type 2.0 (.079) A 1.95 (.077) 1.6 (.063) 6.0(.236) B 6.25(.246) 4.8(.189) 1.7(.067) 0.5 (.020) Top entry type Dimensions mm(in.) Side entry type B Side entry type 2 B 2B-PH-KL S 2B-PH-KL 2.0( .079) 5.9( .232) 1,000 1,000 3 B 3B-PH-KL S 3B-PH-KL 4.0( .157) 7.9( .311) 1,000 1,000 4 B 4B-PH-KL S 4B-PH-KL 6.0( .236) 9.9( .390) 1,000 500 5 B 5B-PH-KL S 5B-PH-KL 8.0( .315) 11.9( .469) 1,000 500 6 B 6B-PH-KL S 6B-PH-KL 10.0( .394) 13.9( .547) 1,000 500 7 B 7B-PH-KL S 7B-PH-KL 12.0( .472) 15.9( .626) 500 500 8 B 8B-PH-KL S 8B-PH-KL 14.0( .551) 17.9( .705) 500 250 9 B 9B-PH-KL S 9B-PH-KL 16.0( .630) 19.9( .783) 500 250 10 B10B-PH-KL S10B-PH-KL 18.0( .709) 21.9( .862) 500 250 11 B11B-PH-KL S11B-PH-KL 20.0( .787) 23.9( .941) 500 250 12 B12B-PH-KL S12B-PH-KL 22.0( .866) 25.9(1.020) 500 250 13 B13B-PH-KL S13B-PH-KL 24.0( .945) 27.9(1.098) 250 250 14 B14B-PH-KL S14B-PH-KL 26.0(1.024) 29.9(1.177) 250 250 15 B15B-PH-KL S15B-PH-KL 28.0(1.102) 31.9(1.256) 250 200 – 200 16 – S16B-PH-KL 30.0(1.181) 33.9(1.335) 3.4 (.134) Circuit No.1 A Q'ty / box Top entry type Material and Finish Post: Phosphor bronze, copper-undercoated, tin/lead-plated (reflow-treated) Wafer: Nylon 66, UL94V-0, gray As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B2B-PH-KL-oo(blank)…gray R…red E…blue S…natural (white) Through-hole type PC board layout (viewed from soldering side) and Assembly layout ––– 4.5 (.177) 2.0±0.05 1.9 (.079±.002) (.075) min. 8.0(.315) 6.0(.236) 2.8 (.110) min. 6.25 (.246)min. 2.0±0.05 1.9 (.079±.002) (.075) min. Side entry type 0.7 + 0.1 0 (.028 + 0.004 )dia. 0.7 + 00.1 (.028 + 0.004)dia. 9.6(.378) 7.6(.299) 4.8(.189) Top entry type 6.25 (.246) Note: 1. Tolerances are non-cumulative: ±0.05mm(±.002") for all centers. 2. Hole dimensions differ according to the kind of printed circuit board and piercing method. If printed circuit boards made of hard material such as FR-4 are used, the hole dimensions should be larger. The hole dimensions shown above are reference values. Contact JST for details. 24 PH CONNECTOR SMT type shrouded header ––––––––––––––––––––––––––––––––––––––––––––––––– •The shrouded headers are interchangeable with those of the KR, KRD and CR insulation displacement connectors. ¨ V approved. •SMT type shrouded headers are not TU Circuits B 5.0 2.0 (.197) [ (.079) ] 1.9(.075) A 2.0(.079) 6.6(.260) 2.975 (.117) 1.4 (.055) 2.2 (.087) Circuit No.1 5.5(.217) 2.4(.094) Side entry type 2.0 2.95 (.079) (.116) A B Dimensions mm(in.) Model No. SM3 type Top entry type (with solder tabs) Top entry type Side entry type A B Top entry type Side entry type Q'ty / reel 2 B 2B-PH-SM3-TB S 2B-PH-SM3-TB 2.0( .079) 7.95( .313) 7.9( .311) 1,000 3 B 3B-PH-SM3-TB S 3B-PH-SM3-TB 4.0( .157) 9.95( .392) 9.9( .390) 1,000 4 B 4B-PH-SM3-TB S 4B-PH-SM3-TB 6.0( .236) 11.95( .470) 11.9( .469) 1,000 5 B 5B-PH-SM3-TB S 5B-PH-SM3-TB 8.0( .315) 13.95( .549) 13.9( .547) 1,000 6 B 6B-PH-SM3-TB S 6B-PH-SM3-TB 10.0( .394) 15.95( .628) 15.9( .626) 1,000 7 B 7B-PH-SM3-TB S 7B-PH-SM3-TB 12.0( .472) 17.95( .707) 17.9( .705) 1,000 8 B 8B-PH-SM3-TB S 8B-PH-SM3-TB 14.0( .551) 19.95( .785) 19.9( .783) 1,000 9 B 9B-PH-SM3-TB S 9B-PH-SM3-TB 16.0( .630) 21.95( .864) 21.9( .862) 1,000 10 B10B-PH-SM3-TB S10B-PH-SM3-TB 18.0( .709) 23.95( .943) 23.9( .941) 1,000 11 B11B-PH-SM3-TB 20.0( .787) 25.95(1.022) 25.9(1.020) 1,000 12 B12B-PH-SM3-TB S12B-PH-SM3-TB 22.0( .866) 27.95(1.100) 27.9(1.098) 1,000 13 B13B-PH-SM3-TB S13B-PH-SM3-TB 24.0( .945) 29.95(1.179) 29.9(1.177) 1,000 14 B14B-PH-SM3-TB S14B-PH-SM3-TB 26.0(1.024) 31.95(1.258) 31.9(1.256) 1,000 15 B15B-PH-SM3-TB S15B-PH-SM3-TB 28.0(1.102) 33.95(1.337) 33.9(1.335) 1,000 16 B16B-PH-SM3-TB – – 30.0(1.181) 35.95(1.415) 35.9(1.413) 1,000 Material and Finish 1.6 (.063) 6.0(.236) Post: Copper alloy, copper-undercoated, tin/lead-plated Wafer: Nylon 46, UL94V-0, natural (white) Solder tab: Brass, copper-undercoated, tin/lead-plated 2.6 [ (.102) ] Note: 1. The products listed above are supplied on embossed-tape. 2. Contact JST for the top entry type headers with suction cap. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B2B-PH-SM3-oo-TB (blank)…natural (white) R…red E…blue 25 PH CONNECTOR Taping specifications of SM3 type shrouded headers ––––––––––––––––––––––––––– 380 ± 2.0(14.961 ± .079)dia. Feeding direction [13.0(.512)dia.] 2.5 W1 -+ 1.0 (W1 +.098 - .039 ) Cover tape leader area Feeding direction Tail tape (Unloaded area) 40.0(1.575)min. 150.0 (5.906)min. Connector loaded area Lead tape (Unloaded area) 20 vacancies min. 2.0 ± 0.5 (.079 ± .020) Top entry type (2 to 6 circuits) Top entry type (7 to 16 circuits) 1.75±0.1 (.069±.004) 2.0±0.1 (.079±.004) 1.55±0.05 (.061±.002)dia. 4.0±0.1 (.157±.004) 0.38±0.05 (.015±.002) 2.0±0.1 (.079±.004) 1.75±0.1 (.069±.004) Feeding direction Feeding direction 1.55±0.05 (.061±.002)dia. 4.0±0.1 (.157±.004) Carrier tape Cover tape 0.38±0.05 (.015±.002) F±0.1 (.004) S±0.1(.004) W±0.3(.012) F±0.1 (.004) W±0.3(.012) Cover tape Carrier tape 12.0±0.1 (.472±.004) Side entry type (2 to 6 circuits) Side entry type (7 to 15 circuits) Feeding direction 2.0±0.1 (.079±.004) 1.55±0.05 (.061±.002)dia. 4.0±0.1 (.157±.004) 0.38±0.05 (.015±.002) Cover tape 2.0±0.1 (.079±.004) 1.75 ± 0.1 (.069 ±.004) Feeding direction 1.75±0.1 (.069±.004) 1.55±0.05 (.061±.002)dia. 4.0±0.1 (.157±.004) Carrier tape 12.0±0.1 (.472±.004) 0.38±0.05 (.015±.002) F ±0.1 (.004) S±0.1(.004) W±0.3(.012) F±0.1 (.004) W±0.3(.012) Cover tape Carrier tape Carrier tape 12.0±0.1 (.472±.004) 12.0±0.1 (.472±.004) Taping dimensions mm(in.) Circuits Top entry type Side entry type 26 Reel dimensions mm(in.) Q'ty / reel F S W W1 2 to 3 7.5( .295) – 16.0( .630) 17.5( .689) 1,000 4 to 6 11.5( .453) – 24.0( .945) 25.5(1.004) 1,000 7 to 9 14.2( .559) 28.4(1.118) 32.0(1.260) 33.5(1.319) 1,000 10 to 14 20.2( .795) 40.4(1.591) 44.0(1.732) 45.5(1.791) 1,000 15 to 16 26.2(1.031) 52.4(2.063) 56.0(2.205) 57.5(2.264) 1,000 2 to 3 7.5( .295) – 16.0( .630) 17.5( .689) 1,000 4 to 6 11.5( .453) – 24.0( .945) 25.5(1.004) 1,000 7 to 9 14.2( .559) 28.4(1.118) 32.0(1.260) 33.5(1.319) 1,000 10 to 14 20.2( .795) 40.4(1.591) 44.0(1.732) 45.5(1.791) 1,000 15 26.2(1.031) 52.4(2.063) 56.0(2.205) 57.5(2.264) 1,000 Note: 1. Specifications conform to JIS C 0806. The tape width, connector loading recess square hole dimensions, etc. are determined by the number of circuits and external shape of the connector to be loaded. 2. Specifications are subject to change without prior notice. PH CONNECTOR SMT type PC board layout (viewed from component side) and Assembly layout ––––––––– SM3 type Top entry type Side entry type 1.6±0.1 2.0±0.05 (.063±.004) (.079±.002) 1.0 (.039) min. End face of wafer on the mating side 9.6(.378) 1.0(.039) 7.6(.299) 5.5(.217) 5.5(.217)max. 9.0(.354)min. 3.4±0.1 (.134±.004) 0.2 (.008) 8.6(.339) 6.6(.260) End face of wafer on the mating side 2.0(.079) max. 7.5(.295) min. 3.0±0.1 1.0 (.118±.004) (.039) 1.5±0.1 (.059±.004) 5.0(.197) 1.6±0.1 1.6±0.1 2.0±0.05 (.063±.004) (.063±.004) (.079±.002) 1.0 (.039) min. Note: 1. Tolerances are non-cumulative: ±0.05mm(±.002" ) for all centers. 2. The dimensions above should serve as a guideline. Contact JST for details. Applicator for the semi-automatic press AP-K2N ––––––––––––––––––––––––––––––– Contact SPH-002T-P0.5S SPH-004T-P0.5S Crimp applicator MKS-L(-10) with safety cover without safety cover Compact crimp applicator MKS-LS with safety cover without safety cover Strip-crimp applicator MKS-SC with safety cover APLMK SPH002-05S APLNC SPH002-05S APLMKLS SPH002-05S APLLSNC SPH002-05S APLSC SPH002-05S APLMK SPH004-05S APLNC SPH004-05S – – APLSC SPH004-05S 27
BPH-002T-P0.5S 价格&库存
很抱歉,暂时无法提供与“BPH-002T-P0.5S”相匹配的价格&库存,您可以联系我们找货
BPH-002T-P0.5S
    库存:8000
    BPH-002T-P0.5S
      • 1+0.214781+0.02791
      • 1000+0.181741000+0.02362
      • 4000+0.148704000+0.01933
      • 5000+0.140445000+0.01825
      • 10000+0.1404410000+0.01825
      • 30000+0.1321830000+0.01718
      库存:48000
