2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces
DF62 Series / DF62W Series
(UL, C-UL Listed)
May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Non-waterproof type
(DF62B, DF62C,
DF62P)
■Features
Waterproof type
(DF62W)
Compact shape due to 2 × 2.2 grid layout of pins
*Both are 7 contacts with 3A current rating
1. The slim, sleek design and smooth contour combine
to complete connections in tight spaces.
These connectors were designed to take full advantage
of small/narrow spaces. The contacts are arranged in a
grid pattern which shortens the diagonal distances and
the body was slimmed down by creating smooth outer
surfaces. This design helps to save precious space and
makes these connectors virtually tangle free. There is
no visible or exposed metal which would eliminate the
possibility of electrical arcing between the connector
and the inside of a metal conduit. (Please refer to Fig. 1
and 2)
16
16
Existing
products
DF62
Fig.1
Grid Arrangement
Smooth external
shape
No exposed metal
2. Secure lock mechanism
The locking structure emits a clear tactile click upon
lock completion. After completion, a second indicator
can be utilized. The socket lock can be visually
checked through the plug window after mating. These
indicators function together to prevent incomplete
mating. (Please refer to Fig. 3)
3. Reliable contact structure
The structure utilizes two contact points to provide
a reliable contact that resists damage from vibration
and rough operation.
4. Robust contact structure
The unique structure provides protection to the
contacts and lance areas, it prevents any bending
or deformity that might occur during mating, the
assembly procedure or while in transportation.
(Please refer to Fig. 4)
Fig.2
Visual check
for complete
mating
1.Visual check area
2. Locking is confirmed
by an audible click.
Image of the outward
appearance of the contact
Fig.3
(Water-resistant type (DF62W))
Robust box-shaped contact structure
(For non-water-proof type)
5. Multiple variations available
There are several different wire counts available,
giving the designer the variety needed to complete
the application. Protected lock type, panel mount
type and pin header type are also available.
6. Applicator sharing
The applicators for the DF11 and DF59 series (existing
products) can be adapted to accommodate the DF62
series applicators. *Some modifications are required.
Please contact Hirose for additional details.
7. Condensation prevention measure
(Water-resistant type DF62W)
(Non-water-resistant type (DF62) contacts)
Designed for easy
contact insertion.
Fig.4
(IP67 level Water-resistance)
Housing seal
Wire seal
Wire seal
IP67 level water-resistance in mated condition.
(Fig. 5)
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
Fig.5
2019.5⑤
1
DF62 Series / DF62W Series●2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces (UL, C-UL Listed)
■Product Specifications
DF62
22 AWG : 4A/pin (2 pos.)
3A/pin (3 to 13 pos.)
Current
2.5A/pin (24 pos.)
Rating
(Note 1) 24 AWG : 2A/pin
26 to 30 AWG : 1A/pin
Operating Temperature Range
-35 to 105ç (Note 2)
UL/C-UL -35 to 75ç(Note 2)
Operating Humidity Range
20 ∼ 80% (Note 3)
20 AWG : 5A (2 pos.), 3.5A/pin (3 to 9 pos) Operating Temperature Range
Current
22 AWG : 4A (2 pos.), 3A/pin (3 to 9 pos)
Ratings DF62W Rating
24 AWG : 3.5A (2 pos.), 2A/pin (3 to 9 pos)
(Note 1)
26 AWG : 3A (2 pos.), 1A/pin (3 to 9 pos) Operating Humidity Range
Common
Voltage
Rating
Specifications AC/DC 250V
Storage Temperature Range
UL File name
UL:E52653
C-UL : E52653 Storage Humidity Range
UL/C-UL AC/DC 29.9V
Items
Specifications
-40 to 105ç(Note 2)
UL/C-UL -40 to 75ç(Note 2)
20 to 80%(Note 3)
-10 to 60ç (Note 4)
40 to 70% (Note 4)
Conditions
1. Insulation Resistance
Minimum of 1,000Mø
Measured with DC 500V
2. Withstanding Voltage
No flashover or breakdown
Apply AC 650V for 1minute
3. Contact
Resistance
Maximum of 30mø
Measured at a maximum of 20mV and 100mA (DC or 1000Hz)
4. Vibration
Resistance
No electrical discontinuity of 1µs or longer
10 cycles in each of three directions at frequency 10-55Hz,
half amplitude 0.75mm
5. Shock
Resistance
Acceleration : 490m/s2, 11ms, Semi-sinusoidal 3 axle
direction 3 times each.
6. Humidity
Resistance
Contact Resistance Maximum of 30mø
Insulation Resistance : Minimum of 1,000Mø
Left at temperature 40 ±2ç, humidity 90 to 95%, 96 hours
7. Temperature
Cycles
Contact Resistance : Maximum of 30mø
-55ç : 30 minutes → 5 to 35ç : 2 to 3 minutes → 85ç :
30 minutes → 5 to 35ç : 2 to 3 minutes, 5 cycles
8. Durability
9. Solder heat
resistnace
There should be no melting of the resin
part which will influence the performance.
Mating/unmating : 30 mating cycles
Flow : 260ç, 10sec
Hand soldering :
temperature of soldering iron at 300ç for 3sec.
Note 1 : This is the maximum current rating while all pins are powered or used as all power lines. When isolating power lines into multiple
circuits, current ratings may go above the stated current ratings. Please consult Hirose for specific details before doing this.
Note 2 : Includes the temperature rise of power lines
Note 3 : The connector should be completely dry (no condensation present)
Note 4 : The term “storage” refers to the long-term storage condition of unused products before PCB mounting. The operating
temperature and humidity ranges are applied while in a non-energized state, while in transport or after PCB mounting.
■Materials / Finish
Item
Socket crimping
contact
Plug crimping
contact
Crimping socket
Crimping plug
Crimping socket *
Crimping plug *
Component
Material
Finish
UL Flammability rating
Contact
Phosphorous bronze
Gold plating or tin plating
Contact
Phosphorous bronze
Insulator
Insulator
PBT
PBT
White
Black
UL94V-0
UL94V-0
Seal
Silicone rubber
Bengala
Insulator
Header
DF62W
Contact
Metal fitting
Seal *
*Waterproof type (DF62W) only
2
DF62
Straight pin header : Polyamide
Right angle pin header : PBT
Black
PBT
Copper alloy
Brass
Silicone rubber
Tin plating
Bengala
UL94V-0
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
Note : The water-proof type and a non-water-proof type are not intermateable.
◆Non-water-resistant type
●Connector
DF 62B - * S - 2.2 C (**)
❶
❷
❸ ❹
❺
❻
❼
❶Series Name:DF
❻Connection part shape
C : Crimping housing
❷Series No. : 62B (regular type)
62C (Protected lock type )
62P (Panel mount type )
❼Color
Socket
None : White
11 : Black
18 : Red
❸No. of Contacts : 2, 3, 4, 5, 6, 7, 13, 24
❹Connector type
S : Socket, EP : Extension plug
❺Contact pitch : 2.2mm
Extension plug
None : Black
10 : White
18 : Red
●Contact
DF 62 - EP 2428 PCF A
❶
❷
❸
❹
❺
❶Series Name:DF
❻
❺Contact type /packaging type
SCF : Socket crimping contact, reel
SC : Socket crimping contact, pieces
PCF : Plug crimping contact, reel
PC : Plug crimping contact, pieces
❷Series No. : 62
❸Terminal type
EP : Extension plug
❹Applicable wire size
22 :22 AWG
2428:24 to 28 AWG
30 :30 AWG
❻Plating type
A : Gold plating
None : Tin plating
●Connector
DF 62 - * P - 2.2 DSA (**)
❶
❷
❸ ❹
❶Series Name:DF
❷Series No. : 62
❸No. of Contacts : 13, 24
❹Connector type
P : Header
❺
❻
❼
DSA : Straight pin header
DS : Right angle pin header
❼Plating type
None : Tin plating
01
: Gold plating
3
◆IP67 Water-resistant type
●Connector
DF 62W - * S - 2.2 C
❶
❷
❸ ❹
❺
❻
❶Series Name:DF
❷Series No. : 62W
❸No. of Contacts : 2, 3, 4, 6, 9
❹Connector type
●Contact
DF 62W - EP 2226 PCF A
❶
❷
❸
❹
❺
❻
❶Series Name:DF
❸Terminal type
EP : Extension plug
2022:20 to 22 AWG
2226:22 to 26 AWG
❻Plating type
A : Gold plating
None : Tin plating
❷Series No. : 62W
●Water-proof pin
DF 62W - WP
❶
❷
❸
❶Series Name:DF
❸For each use type
WP : ◆IP67 Water-resistant type
❷Series No. : 62W
●Connector
DF 62WZ - * P - 2.2 DSA (**)
❶
❷
❸ ❹
❶Series Name:DF
❷Series No. : 62WZ
❸No. of Contacts : 9
❹Connector type
P : Header
4
❺
❻
❼
❼Plating type
20 : Tin plating
50 : Gold plating
■Socket (standard type)
9.55
A
*7 pos. shown
as an example.
Cavity No.
P=2
B
[Specification No.] **
None : White
(11) : Black
(18) : Red
P=2.2
Contact No. marking
Unit : mm
No. of
Contacts
Part No.
HRS No.
A
B
Part No.
HRS No.
DF62B-2S-2.2C(**)
544-0551-0 **
2
5.08
DF62B-6S-2.2C(**)
544-0555-0 **
DF62B-3S-2.2C(**)
544-0552-2 **
3
4.9
DF62B-7S-2.2C(**)
544-0556-3 **
DF62B-4S-2.2C(**)
544-0553-5 **
4
7.08
DF62B-13S-2.2C(**)
544-0557-6 **
DF62B-5S-2.2C(**)
544-0554-8 **
5
7.1
DF62B-24S-2.2C(**)
544-0539-4 **
Note 1 : This product is sold per pack (100pcs/pack), please place orders in full pack increments.
6
7
13
24
■Socket (Protected lock type)
A
7.1
9.3
12.3
B
7.08
9.08
11.08
13.08
A
*7 pos. shown
as an example.
Cavity No.
P=2
B
None : White
(11) : Black
(18) : Red
P=2.2
Contact No. marking
Unit : mm
No. of
Part No.
HRS No.
A
B
Part No.
HRS No.
Contacts
DF62C-2S-2.2C(**)
544-0565-4 **
2
5.65
DF62C-6S-2.2C(**)
544-0569-5 **
DF62C-3S-2.2C(**)
544-0566-7 **
3
4.9
DF62C-7S-2.2C(**)
544-0570-4 **
DF62C-4S-2.2C(**)
544-0567-0 **
4
7.65
DF62C-13S-2.2C(**) 544-0571-7 **
DF62C-5S-2.2C(**)
544-0568-2 **
5
7.1
DF62C-24S-2.2C(**) 544-0541-6 **
No. of
Contacts
6
7
13
24
Contact No.
■Socket (Water proof type)
A
7.1
9.3
12.3
B
7.65
9.65
11.65
13.65
*9 pos. shown
as an example.
A
Cavity No.
B
14.05
P=2.2
No. of
Contacts
HRS No.
544-1002-7
544-1004-2
544-1006-8
Part No.
DF62W-2S-2.2C
DF62W-3S-2.2C
DF62W-4S-2.2C
A
2
3
4
7.5
B
7.55
P=2.2
No. of
Contacts
Unit : mm
HRS No.
544-1008-3
544-1010-5
Part No.
DF62W-6S-2.2C
DF62W-9S-2.2C
9.75
No. of
Contacts
A
6
9
9.7
B
9.75
11.95
Note 2 : The Water-proof type and a non-water-proof type are not intermateable.
Pin configuration of the contact numbers. (Shown from the mating side.)
2 pos.
3 pos.
1
2
4 pos.
1
2
3
Ø9.2mm
Ø10.4mm
Ø10.8mm
Note : Applicable jacket outer diameter : Ø1.4 to 1.6mm
6 pos.
9 pos.
1
2
1
2
3
1
2
3
3
4
4
5
6
4
5
6
7
8
9
Ø11.6mm
Ø13.3mm
5
A
■Plug (standard type)
*7 pos. shown
as an example.
16.05
Cavity No.
P=2
B
None : Black
(10) : White
(18) : Red
P=2.2
Contact No. marking
Unit : mm
No. of
Contacts
No. of
Contacts
Part No.
HRS No.
A
B
Part No.
HRS No.
DF62B-2EP-2.2C(**)
544-0558-9 **
2
5.3
DF62B-6EP-2.2C(**)
544-0562-6 **
DF62B-3EP-2.2C(**)
544-0559-1 **
3
6.0
DF62B-7EP-2.2C(**)
544-0563-9 **
DF62B-4EP-2.2C(**)
544-0560-0 **
4
7.3
DF62B-13EP-2.2C(**) 544-0564-1 **
DF62B-5EP-2.2C(**)
544-0561-3 **
5
8.2
DF62B-24EP-2.2C(**) 544-0540-3 **
6
7
13
24
A
8.2
10.4
13.4
B
7.3
9.3
11.3
13.3
A
■Plug (Panel mount type )
16.05
Cavity No.
P=2
B
None : Black
(10) : White
(18) : Red
P=2.2
Contact No. marking
Unit : mm
No. of
Part No.
HRS No.
A
B
Part No.
HRS No.
Contacts
DF62P-2EP-2.2C(**)
544-0543-1 **
2
5.3
DF62P-6EP-2.2C(**)
544-0547-2 **
DF62P-3EP-2.2C(**)
544-0544-4 **
3
11.3
DF62P-7EP-2.2C(**)
544-0548-5 **
DF62P-4EP-2.2C(**)
544-0545-7 **
4
7.3
DF62P-13EP-2.2C(**) 544-0549-8 **
DF62P-5EP-2.2C(**)
544-0546-0 **
5
13.5
DF62P-24EP-2.2C(**) 544-0550-7 **
No. of
Contacts
6
7
13
24
P=2.2
13.5
15.7
18.7
B
7.3
9.3
11.3
13.3
*9 pos. shown
as an example.
P=2.2
■Plug (Water proof type)
A
B
23.05
A
Cavity No.
Contact No.
Unit : mm
Part No.
DF62W-2EP-2.2C
DF62W-3EP-2.2C
DF62W-4EP-2.2C
HRS No.
544-1003-0
544-1005-5
544-1007-0
No. of
Contacts
A
7.5
8.0
9.1
2
3
4
B
6.7
Part No.
DF62W-6EP-2.2C
DF62W-9EP-2.2C
9.15
HRS No.
544-1009-6
544-1011-8
No. of
Contacts
A
6
9
11.3
B
9.15
11.35
2 pos.
3 pos.
2
1
4 pos.
2
1
3
Ø8.5mm
Ø9.7mm
Ø10.2mm
6
6 pos.
9 pos.
2
1
3
2
1
3
2
1
4
3
6
5
4
6
5
4
9
8
7
Ø11.5mm
Ø12.8mm
BSocket contact No. Summary diagram (from the mating section side)
2 pos.
1
2
3 pos.
2
1
3
4 pos.
1
3
2
4
5 pos.
2
1
4
6 pos.
3
5
1
4
2
5
7 pos.
3
6
2
1
4
3
6
13 pos.
1
5
7
4
8
2 3
5 6 7
9 10 11
12 13
24 pos.
1 2 3 4 5
6 7 8 9 10
11 12 13 14 15
16 17 18 19 20
21 22 23 24
BPlug contact No. Summary diagram (from the mating section side)
2 pos.
3 pos.
4 pos.
2 1
2 1
3
2 1
4 3
5 pos.
3
5
2 1
4
6 pos.
3
6
2 1
5 4
5
7 pos.
13 pos.
24 pos.
2 1
4 3
7 6
3 2 1
7 6 5 4
11 10 9 8
13 12
5 4 3 2 1
10 9 8 7 6
15 14 13 12 11
20 19 18 17 16
24 23 22 21
BContact No. diagram
No.1
No.2
No.3
No.4
No.5
No.6
No.8
No.10
No.11
No.12
No.13
No.15
No.16
No.20
No.21
No.22
No.23
No.24
No.7
7
(11.15)
■Socket crimping contact
3
1.83
1.5
7.45
●Reel Contact (1Reel, 15,000 reel contacts) *Applicable tool : Applicator
Part No.
DF62-22SCF
DF62-22SCFA
DF62-2428SCF
DF62-2428SCFA
HRS No.
Finish
UL
544-0520-6 Tin plated
1061
544-0506-5 Gold plated
544-0521-9 Tin plated
1007
544-0500-9 Gold plated
Applicable wire (tin plated annealed copper) (Note 1)
Wire size Stranded wire structure Calculated cross-section Jacket Diameter
22 AWG
24 AWG
26 AWG
28 AWG
17/0.16mm
0.342mm2
11/0.16mm
7/0.16mm
7/0.127mm
2
0.221mm
0.141mm2
0.089mm2
Ø1.2 to Ø1.45mm
Ø0.9 to Ø1.45mm
DF62-30SCF
544-0522-1 Tin plated
Ø0.75 to Ø1.2mm
1007 30 AWG
7/0.1mm
0.055mm2
DF62-30SCFA
544-0508-0 Gold plated
Note 1 : When using wires that are not recommended by Hirose, please contact one of our sales representatives for clarification.
●Loose piece (1pack, 100) *Applicable tool : hand crimping tool
Part No.
DF62-22SC
DF62-22SCA
DF62-2428SC
DF62-2428SCA
HRS No.
Finish
UL
544-0572-0 Tin plated
1061
544-0526-2 Gold plated
544-0573-2 Tin plated
1007
544-0527-5 Gold plated
Applicable wire (tin plated annealed copper) (Note 2)
22 AWG
24 AWG
26 AWG
28 AWG
17/0.16mm
0.342mm2
Ø1.26mm
11/0.16mm
7/0.16mm
7/0.127mm
2
0.221mm
0.141mm2
0.089mm2
Ø1.42mm
Ø1.28mm
Ø1.18mm
7/0.1mm
0.055mm2
Ø0.82mm
DF62-30SC
544-0574-5 Tin plated
1007 30 AWG
DF62-30SCA
544-0528-8 Gold plated
Note 2 : The applicable cables include only those listed above.
■Socket crimp contact (for water-proof version)
(11.5)
3
1.37
1.6
7.8
20 AWG
7/0.32mm
0.563mm2
DF62W-2022SCF
DF62W-2022SCFA
22 AWG
17/0.16mm
0.342mm2
22 AWG
17/0.16mm
0.342mm2
Ø1.4 to Ø1.6mm
1007
0.221mm2
24 AWG
11/0.16mm
DF62W-2226SCF
544-1000-1 Tin plated
DF62W-2226SCFA
544-1025-0 Gold plated
24 AWG
11/0.16mm
0.221mm2
1430
0.141mm2
26 AWG
7/0.16mm
Note 2 : In case of hard to insert crimped contact to socket as like using low stiffness wire which consists of thinner stranded
conductor or insulation with soft material, please contact to Hirose representative.
Note 3 : The Water-proof type and non-water-proof type are a not intermateable.
Part No.
HRS No.
Finish
UL
544-1015-9 Tin plated 3443
544-1027-0 Gold plated 1007
Part No.
DF62W-2022SC
DF62W-2022SCA
HRS No.
Finish
UL
544-1017-4 Tin plated 3443
544-1045-0 Gold plated 1007
544-1012-0 Tin plated 1007
544-1044-0 Gold plated
1430
Note 4 : The applicable cables include only those listed above.
DF62W-2226SC
DF62W-2226SCA
8
Applicable wire (tin plated annealed copper) (Note 4)
Ø1.53mm
20 AWG
7/0.32mm
0.563mm2
Ø1.58mm
22 AWG
17/0.16mm
0.342mm2
Ø1.58mm
22 AWG
17/0.16mm
0.342mm2
Ø1.42mm
0.221mm2
24 AWG
11/0.16mm
Ø1.48mm
26 AWG
7/0.16mm
0.141mm2
■Plug crimping contact
Part No.
DF62-EP2428PCF
DF62-EP2428PCFA
Finish
UL
544-0523-4 Tin plated
1061
544-0507-8 Gold plated
544-0524-7 Tin plated
1007
544-0501-1 Gold plated
22 AWG
24 AWG
26 AWG
28 AWG
17/0.16mm
0.342mm2
11/0.16mm
7/0.16mm
7/0.127mm
2
Ø1.2 to Ø1.45mm
0.221mm
0.141mm2
0.089mm2
Ø0.9 to Ø1.45mm
DF62-EP30PCF
544-0525-0 Tin plated
Ø0.75 to Ø1.2mm
1007 30 AWG
7/0.1mm
0.055mm2
DF62-EP30PCFA
544-0509-3 Gold plated
Part No.
DF62-EP22PC
DF62-EP22PCA
DF62-EP2428PC
DF62-EP2428PCA
HRS No.
544-0575-8
544-0529-0
544-0576-0
544-0530-0
Finish
UL
Tin plated
1061
Gold plated
Tin plated
1007
Gold plated
22 AWG
24 AWG
26 AWG
28 AWG
DF62-EP30PC
544-0577-3
Tin plated
1007 30 AWG
DF62-EP30PCA
544-0529-0 Gold plated
17/0.16mm
0.342mm2
Ø1.26mm
11/0.16mm
7/0.16mm
7/0.127mm
2
0.221mm
0.141mm2
0.089mm2
Ø1.42mm
Ø1.28mm
Ø1.18mm
7/0.1mm
0.055mm2
Ø0.82mm
■Plug crimping contact (for water-proof version)
(15.3)
3
1.6
11.6
1.37
DF62-EP22PCF
DF62-EP22PCFA
HRS No.
20 AWG
7/0.32mm
0.563mm2
DF62W-EP2022PCF
DF62W-EP2022PCFA
22 AWG
17/0.16mm
0.342mm2
22 AWG
17/0.16mm
0.342mm2
Ø1.4 to Ø1.6mm
1007
0.221mm2
24 AWG
11/0.16mm
DF62W-EP2226PCF
544-1001-4 Tin plated
DF62W-EP2226PCFA
544-1026-0 Gold plated
24 AWG
11/0.16mm
0.221mm2
1430
0.141mm2
26 AWG
7/0.16mm
Part No.
HRS No.
Finish
UL
544-1016-1 Tin plated 3443
544-1028-0 Gold plated 1007
Part No.
DF62W-EP2022PC
DF62W-EP2022PCA
HRS No.
Finish
UL
544-1018-7 Tin plated 3443
544-1043-0 Gold plated 1007
544-1013-3 Tin plated 1007
544-1042-0 Gold plated
1430
DF62W-EP2226PC
DF62W-EP2226PCA
Ø1.53mm
20 AWG
7/0.32mm
0.563mm2
Ø1.58mm
22 AWG
17/0.16mm
0.342mm2
Ø1.58mm
22 AWG
17/0.16mm
0.342mm2
Ø1.42mm
0.221mm2
24 AWG
11/0.16mm
Ø1.48mm
26 AWG
7/0.16mm
0.141mm2
9
BApplicable Crimping Tool
●DF62
Type
Applicator
Press body
Hand tool
Extraction tool
Part No.
HRS No.
AP105-DF62-22
901-4626-3
AP105-DF62-2428
901-4625-0
AP105-DF62-30
901-4627-6
CM-105C
901-0001-0
HT801/DF62-22(10) (Note 3)
550-0401-9 10
HT801/DF62-2428(10) (Note 4)
550-0400-6 10
HT801/DF62-30(10) (Note 5)
550-0402-1 10
DF62/RE-MD
902-4645-4
Applicable Contact
DF62-22SCFA/SCF
DF62-EP22PCFA/PCF
DF62-2428SCFA/SCF
DF62-EP2428PCFA/PCF
DF62-30SCFA/SCF
DF62-EP30PCFA/PCF
DF62-22SCA/SC
DF62-EP22PCA/PC
DF62-2428SCA/SC
DF62-EP2428PCA/PC
DF62-30SCA/SC
DF62-EP30PCA/PC
DF62-**SCFA/SCF/SCA/SC
DF62-EP**PCFA/PCF/PCA/PC
Note 1 : Hirose does not warranty problems that arise from the use of unapproved tools on Hirose products.
Note 2 : Please conduct crimping work according to the "Crimping quality control statement of standards (ETAD-H0642,
ETAD-H0643)" and "Crimping condition table".
Note 3 : The compatible wire is limited to UL1061 (22 AWG).
Note 4 : The compatible wire is limited to UL1007 (24 to 28 AWG).
Note 5 : The compatible wire is limited to UL1061 (30 AWG).
●DF62W
Type
Applicator
Press body
Part No.
HRS No.
AP105-DF62W-2022
EHS899800H-UP (Note 2)
AP105-DF62W-2226
EHS888400H-UP (Note 2)
CM-105C
901-4500-0
901-4637-0
901-0001-0
HT802/DF62W-2022 (Note 4)
550-0431-0
HT802/DF62W-2226 (Note 5)
550-0416-6
DF62W/RE-MD
902-4666-4
Hand tool
Extraction tool
Applicable Contact
DF62W-2022SCF(A)
DF62W-EP2022PCF(A)
DF62W-2226SCF(A)
DF62W-EP2226PCF(A)
DF62W-2022SC(A)
DF62W-EP2022PC(A)
DF62W-2226SC(A)
DF62W-EP2226PC(A)
DF62W-2022SC(F)(A)
DF62W-EP2022PC(F)(A)
DF62W-2226SC(F)(A)
DF62W-EP2226PC(F)(A)
Note 2 : Applicator manufactured by JAPAN AUTOMATIC MACHINE(J.A.M.). Please access to HP of J.A.M., if you make
inquiries about the applicator or crimp defect. (URL : http://www.jam-net.co.jp)
Note 3 : Please conduct crimping work according to the "Crimping quality control statement of standards (ETAD-H0762-00,
ETAD-H0763-00)" and "Crimping condition table".
Note 4 : The compatible wire is limited to UL3443 (20 AWG) or UL1007 (22 AWG).
Note 5 : The compatible wire is limited to UL1007 (22 to 24 AWG) or UL1430 (24 to 26 AWG).
10
BCrimping
■Items required prior to start crimping
The work-related documents shown below are required before starting the harness connections.
(The ● mark shows the document required.)
When the documents shown below are not available, ask our sales personnel to provide them.
Document Title
Description
Automatic
Hand
Crimping Crimping
Machine
Tool
Remarks
When purchasing main press
machine unit,
it is bundled.
(1) Main unit of crimping machine Explanation of main press
instruction manual
machine unit
(2) Applicator Spare Parts
Identification
Explanation for Applicator
installation
(3) Crimp Conditions
Standard values of :
Crimp height ;
Tensile strength
(4) Crimp Quality Standards
Various standards for
crimping conditions
(5) Operating lnstructions for
Hand Tool
Inspection items of :
Crimp height ;
Tensile strength ; and others
When purchasing Hand Tool,
it is bundled.
Ask our sales personal to provide
them.
(6) Harness Procedure Manual
DF62 series : ETAD-H0593 Harness procedure
DF62W series : ETAD-H0760
When purchasing Applicator,
it is bundled.
■Tools
When crimping work is applied to our contacts, the tool designated by Hirose should be used.
Crimping work by using tools other than as designated must not be done because it may result in contact
failure, disconnection of cable, etc.
*The operating instructions manual is available for the crimping machine and the applicator. Be sure to
carefully read the operating instructions manual befor implementing the work.
■Applicable electric wires
Check that the electric wire to be used is in the range of application.
If you intend to use an electric wire other than the recommended one, ask our sales personnel.
[Precautions]
・Electric wires that are applicable for crimping connectors shall, principally, be the tin-plated stranded softcopper wire.
・Crimping of electric wires wherein single wires, polyester yarns, etc., exist and crimping of tin-coated wires
should be avoided.
・Avoid crimping two electric wires together.
・The setting values of crimp height (Note 1) may vary between tin-plated and gold-plated terminals even if the
same electric wires are used.
・The setting values of crimp height (Note 1) may vary depending on the difference in the core wire configuration
even if the computed cross-sectional area is the same.
Note 1 : The crimp height is an important item that determines crimping quality. We execute crimping tests for
each electric wire to ensure the optimal value for the crimp height with high precision, thereby ensuring
optimal setup values.
11
■Straight pin Header
B
2.6
A
□0.5
*13 pos. shown as an example.
Cavity No.
C
P=2
Contact No.1 marking
Contact No. marking
P=2.2
Unit : mm
Part No.
HRS No.
No. of
Contacts
A
B
13
24
11.5
14.5
8.8
10.8
DF62-13P-2.2DSA(**) 544-0582-0 **
DF62-24P-2.2DSA(**) 544-0584-0 **
None : Tin plating
(01) : Gold plating
C
Tin plating Gold plating
11.8
13.8
Note 1 : This product is sold per tray (13pos : 100pcs/tray, 24pos : 80pcs/tray), please place orders by tray unit.
Note 2 : Please contact to Hirose representative if you have request for Gold plating type of unreleased pin-pos.
●Recommended PCB layout
(Recommended thickness t=1.6mm)
[13 pos]
[24 pos]
4.4±0.05
8.8±0.05
P=2.2±0.05
13
0.8
+0
− 0 .1
P=2.2±0.05
24
∞Ø
P=2±0.05
P=2±0.05
∞Ø
P=2.2±0.05
Outline of the connector
8±0.05
6±0.05
6.6±0.05
0.8
+0
− 0 .1
P=2.2±0.05
6.6±0.05
■Right Angle pin Header
C
A
Cavity No.
P=2.2
t=0.47
2.4
3.6
B
P=2
Contact No. marking
□0.5
Unit : mm
Part No.
DF62-13P-2.2DS(**)
DF62-24P-2.2DS(**)
HRS No.
No. of
Contacts
A
B
544-0581-0 **
544-0583-0 **
13
24
11.5
15.4
12.9
14.9
C
19.5
23.5
None : Tin plating
(01) : Gold plating
Note 1 : This product is sold per tray (100pcs/tray), please place orders by tray unit.
[13 pos]
[24 pos]
4.4±0.05
8.8±0.05
P=2.2±0.05
4.145±0.05
1.945±0.05
P=2.2±0.05
P=2.2±0.05
3.045±0.05
6.6±0.05
Ø3±
0.05
24∞
Ø0.9 +0.1
−0
P=2±0.05
−0
8±0.05
Ø0.9 +0.1
9.45±0.05
13∞
P=2±0.05
7.45±0.05 6±0.05
Ø3±
0.05
12
P=2.2±0.05
3.045±0.05
6.6±0.05
P=2.2
■Straight pin Header (Water proof type)
Cavity No.
*9 pos. shown as an example.
P=2.2
Contact No1. marking
B
2.85
15.5
A
□0.5
Unit : mm Unit : pcs
HRS No.
544-1050-0 **
No. of
Contacts
9
B Tray packaging Tin plating Gold plating
12.1
200
A
12
Note 1 : Please place orders by tray unit.
(20) : Tin plating
(50) : Gold plating
[9 pos]
Ø1.
8 −+00.1
.1
+0
−0
0.8
Ø
9∞
P=2.2±0.05
P=2.2±0.05
P=2.2±0.05
P=2.2±0.05
5.05±0.05
4.5±0.05
■Waterproof pin
Ø17
CAV No.
Ø16.5
Part No.
HRS No.
DF62W-WP
544-1014-6
29
(Waterproof surface)
30
Ø16.5
30
Part No.
DF62WZ-9P-2.2DSA(**)
HRS Logo
Note 1 : This product is sold per pack (100pcs/pack), please place orders in full pack.
Note 2 : In case of using without inserting crimp contact, fill the terminal hole of socket and plug with a waterproof pin.
13
Precautions
14
1. Recommended soldering
conditions
■ Soldering profile when using an automatic soldering device
Soldering temperature : 260℃ ; Soldering time: no more than 10 seconds
■ Hand soldering conditions
Temperature of soldering iron : 300℃ , soldering time : no more than 3 seconds
2. Cleaning Conditions
Please refer to the "Wire-to-Board Connector Guide".
Cleaning with IPA is allowed. (Other cleaning agents are not recommended due to the fact
that it may change the push/pull feeling. Please contact us when you use other cleaning
agents. )
3. Important notes
1. Caution is required for mating and un-mating the connector without it being mounting
on a PCB. Doing so can damage or deform the contacts.
2. During hand soldering, do not apply excess amounts flux which can migrate on to the
connector.
3. This product may have a slight differences in color depending on the production lot.
This difference does not have any influence on the performance.
4. Please refer to “DF62 Series mating and unmating Procedure Document (ETAD-H0599)”
and “DF62W Series mating and unmating Procedure Document (ETAD-H0761)” for
points in handling regarding mating operations.
4. Handling instructions
Please refer to the “Wire-to-Board Connector Guide”.
MEMO :
15
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE
2300 Warrenville Road, Suite 150,
Downers Grove, IL 60515
Phone : +1-630-282-6700
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
2841 Junction Ave, Suite 200
San Jose, CA. 95134
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253,
Livonia, MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
USA:
HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE
300 Brickstone Square Suite 201,
Andover, MA 01810
Phone : +1-978-662-5255
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Schoenbergstr. 20, 73760 ostfildern
Phone : +49-711-456002-1
Fax : +49-711-456002-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE
Neumeyerstrasse 22-26, 90411 Nurnberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
130 Avenue Joseph Kessel, Bat E, 78960
Voisins le Bretonneux, France
Phone : +33-1-85764886
Fax : +33-1-85764823
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS)
18, Enterprise Center Tower 2, 209# Gong He
Road, Jing’an District, Shanghai, CHINA 200070
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7355
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO.,LTD.
143, Gongdan 1-daero, Siheung-si,
Gyeonggi-do, 15084, Korea
Phone : +82-31-496-7000
Fax : +82-31-496-7100
http://www.hirose.co.kr/
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C,
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
Singapore 079909
Phone : +91-12-660-8018
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +65-6324-6123
http://www.hirose.com/sg/
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
MALAYSIA:
THAILAND:
PENANG REPRESENTATIVE OFFICE
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Lepas Penang, 11950, Malaysia
Phone : +66-2-686-1255
Phone : +604-648-5536
Fax : +66-2-686-3433
16
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 05/2019. Contents are subject to change without notice for the purpose of improvements.
