FFTP-08-D-03.85-01-N-R 数据手册
TIGER
IDC
EYE
TWISTED PAIR
IDC CABLES
(1.27 mm) .050" PITCH • FFTP/FMTP SERIES
FFTP
Mates:
FTS, FTSH, EHF, SHF
FFTP
FMTP
–05, –08,
–10, –13,
–17, –20, –25
Mates:
FLE*, SFMC*
–D
ASSEMBLY
LENGTH
01
–03.85
= Double
End
N
–N
= (97.79 mm)
3.85"
–R
= Notch
Polarization
(Standard)
–08.77
OPTION
= Reverse
Connector
= (222.76 mm)
8.77"
ASSEMBLY LENGTH
Insulator Material:
PBT
Contact:
FFTP=BeCu
Terminal:
FMPT=Phosphor Bronze
Plating (FFTP):
FFTP=10 µ" (0.25 µm)
Au over 50 µ" (1.27 µm)
Ni on contact area; Sn over
50 µ" (1.27 µm) Ni
FMTP=Sn over 50 µ"
(1.27 µm) Ni on balance
Wire:
30 AWG 7/38, Tinned,
Twisted Pair with PVC insulator
Operating Temp Range:
-40 °C to +105 °C
Lead Size Accepted:
(0.41 mm) .016" SQ
Insertion Depth (FFTP):
FFTP=(2.64 mm) .104" to
(3.17 mm) .125"
MOQ Required
END
ASSEMBLY
(Standard sizes)
SPECIFICATIONS
ALSO AVAILABLE
NO. PINS
PER ROW
–18.00
No. of
positions
x
(1.27)
.050
(4.19)
.165
= (457.20 mm)
18.00"
(Standard
lengths)
(3.05)
.120
(5.08)
.200
–D
FMTP
Other sizes
NO. PINS
PER ROW
–05, –08,
–10, –13,
–17, –20, –25
(Standard sizes)
END
ASSEMBLY
–D
–R
ASSEMBLY
LENGTH
01
–03.85
= Double
End
–T
TRANSFER
OPTION
Leave blank
for –D End
Assembly.
For –T End
Assembly
Specify “–N”
(Sockethas notch
polarization)
= (97.79 mm)
3.85"
–08.77
= Transfer
End
= (222.76 mm)
8.77"
–18.00
OPTION
–R
= Reverse
Connector
= (457.20 mm)
18.00"
(Standard
lengths)
ASSEMBLY LENGTH
No. of
positions
x
(1.27)
.050
(4.19)
.165
*Note: Standard FMTP callout
will not mate with FLE, SFMC.
Must use gold plated callouts.
(See drawing on web.)
When mated with a socket,
Wire 1 mates with Pin 2;
Wire 2 mates wth Pin 1, etc.
Note:
This Series is non-standard,
non-returnable.
–R
(3.05)
.120
(5.08)
.200
–D
–T
samtec.com?FFTP or samtec.com?FMTP
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
FFTP-08-D-03.85-01-N-R 价格&库存
很抱歉,暂时无法提供与“FFTP-08-D-03.85-01-N-R”相匹配的价格&库存,您可以联系我们找货
