FH26J-55S-0.3SHW(97)
    HRS(广濑)
    SMD,P=0.3mm,卧贴
    FPC/FFC连接器 间距:0.30mm 55Pin 翻盖式 卧贴
FH26J-55S-0.3SHW(97) 数据手册
0.3mm Pitch, 1.0mm Height FPC Connector FH26 Series 1.0mm ●Space saving(51 pos. shown) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.2mm 16.8mm Metal fittings do no protrude outside of the connector body ■Features ●Can be mounted over conductive traces. 1. Low-profile 0.3mm pitch FPC connector Ultra-thin design, 1.0mm height, 3.2mm width all add up to a compact, space saving form factor. *30% reduction in PCB footprint *40% reduction in weight (Compared to our 0.3mm pitch FH23 Series 51 position connector.) 2. Easy PCB Mounting The leads are double sided and have a 0.6mm mounting lead pitch to simplify mounting. No exposed contacts on the bottom of the connector 3. Fully molded structure aids PCB layout The bottom of this connector is enclosed by a fully molded structure that protects the contacts and removes any restrictions from PCB patterning and design. 4. Rotating one-touch ZIF mechanism ●Operation (1) (1) Actuator Actuator open open (2) (2) Insert Insert FPC FPC The one-touch rotating ZIF mechanism is easier to operate and works with a light force, and a clear tactile click is delivered upon the successful completion of the mating process. Actuator q 5. Easy FPC insertion The metal FPC insertion guides helps to make this the FPC insertion process easier. w 6. FPC. Accepts standard 0.2mm thick FPC This connector accepts standard 0.2mm thick FPC. (The proper FPC stiffener thickness will prevent FPC deformation and ease insertion and mating.) FPC 7. Supports automatic pick-n-place mounting Offered in tape and reel packaging that is compatible with automatic machine mounting. (5,000 pieces per reel) (3) (3) Close Close the the actuator actuator (4) (4) FPC FPC connected connected 8. Halogen-free All materials and substances used to produce this product comply with Halogen-free standards. * Defined according to IEC61249-2-21 Br : 900ppm max, Cl : 900ppm max, Br+Cl : 1,500ppm max. e 9. Multiple packing options The standard packaging is 5,000 pieces per reel, but it is also offered in a 500 piece reel. (The outer diameter of the reel will be Ø180mm in this case.) r 2017.5③ 1 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors ■Product Specifications Rating Storage temperature range -10ç to +50ç (Note 3) Storage humidity range Relative humidity 90% max. Thickness : = 0.2±0.03mm gold plated Recommended FPC : Item Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating temperature range -55 ç to +85ç (Note 2) Operating humidity range Relative humidity 90% max. (No condensation) Current rating 0.2A DC (Note 1) Voltage rating 30V AC Specification Conditions 1. Insulation resistance 50Mø min. 100V DC 2. Withstanding voltage No flashover or insulation breakdown. 90V AC /1 minute 3. Contact resistance 100mø max. * Including FPC conductor resistance 1mA 4. Durability (Insertion/ withdrawal) Contact resistance : 100mø max. No damage, cracks, or parts dislocation. 10 cycles 5. Vibration No electrical discontinuity of 1μs or more. Contact resistance : 100mø max. No damage, cracks, or parts dislocation. Frequency : 10 to 55 Hz, single amplitude of 0.75mm, 10 cycles, 3 directions. 6. Shock No electrical discontinuity of 1μs. min. Contact resistance : 100mø max. No damage, cracks, or parts dislocation. Acceleration of 981 m/s2, 6 ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis 7. Humidity (Steady state) Contact resistance : 100mø max. Insulation resistance : 50Mø min. No affect on appearance or performance. 96 hours at temperature of 40±2ç and humidity of 90% to 95%. 8. Temperature cycle Contact resistance : 100mø max. Insulation resistance : 50Mø min. No damage, cracks, or parts looseness. Temperature : -55 ç/+15ç to +35ç/+85ç/+15ç to +35ç Time : 30 / 2 to 3 / 30 / 2 to 3 (Minutes) 5 cycles 9. Resistance to soldering heat No deformation of components affecting performance. Reflow : At the recommended temperature profile Manual soldering: 350ç +/-10ç for 5±1 seconds Note 1 : When passing the current through all of the contacts, use 70% of the rated current. Note 2 : Includes temperature rise caused by current flow. Note 3 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non- conducting condition of installed connectors in storage, shipment or during transportation. ■Materials / Finish Part Material Insulator Contacts Metalfittings Finish Remarks LCP Color : Black UL94V-0 PA FH26W series : Light brown UL94HB Gold plating --------------- Pure tin reflow plating --------------- Phosphor bronze ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. FH 26W - 51S - 0.3 SHW (05) 1 2 2 3 4 5 6 1 Series name : FH 5 Termination type SHW : SMT horizontal staggered mounting type 2 Series No. : 26W 6 Specifications 3 Number of Contacts : 13 to 71 (60)…Gold plating with nickel barrier, 5,000pcs/reel 4 Contact pitch : 0.3mm (97)…Gold plating with nickel barrier, 500pcs/reel FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors ■Connector Dimensions 0.3 A B Number of contacts indicator (0.12) C 1 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.6 (0.3) 3.2 (1.25) (0.12) 0.6 0.5 0.3 3.2 (D : FPC insertion slot dimension) 0.1 1 0.1 1 E Notes 1 The coplanarity of each terminal lead within specified dimension is 0.1mm Max. 2 Packaged on tape and reel only. Check packaging specification. 3 Slight variations in color of the plastic compounds do not affect form, fit or function of the connector. 4 After reflow, the terminal plating may change color, however this does not represent a quality issue. All dimensions : mm Part No. HRS No. No. of Contacts A FH26W-13S-0.3SHW(**) 580-2401-1 ** 13 FH26W-15S-0.3SHW(**) 580-2402-4 ** 15 FH26W-17S-0.3SHW(**) 580-2403-7 ** FH26W-19S-0.3SHW(**) 580-2437-9 ** FH26W-21S-0.3SHW(**) FH26W-23S-0.3SHW(**) B C D E 5.4 3 3.6 4.23 4.9 6.0 3.6 4.2 4.83 5.5 17 6.6 4.2 4.8 5.43 6.1 19 7.2 4.8 5.4 6.03 6.7 580-2404-0 ** 21 7.8 5.4 6.0 6.63 7.3 580-2405-2 ** 23 8.4 6.0 6.6 7.23 7.9 FH26W-25S-0.3SHW(**) 580-2406-5 ** 25 9.0 6.6 7.2 7.83 8.5 FH26W-27S-0.3SHW(**) 580-2400-9 ** 27 9.6 7.2 7.8 8.43 9.1 FH26W-29S-0.3SHW(**) 580-2407-8 ** 29 10.2 7.8 8.4 9.03 9.7 FH26W-31S-0.3SHW(**) 580-2408-0 ** 31 10.8 8.4 9.0 9.63 10.3 FH26W-33S-0.3SHW(**) 580-2409-3 ** 33 11.4 9.0 9.6 10.23 10.9 FH26W-35S-0.3SHW(**) 580-2410-2 ** 35 12.0 9.6 10.2 10.83 11.5 FH26W-37S-0.3SHW(**) 580-2411-5 ** 37 12.6 10.2 10.8 11.43 12.1 FH26W-39S-0.3SHW(**) 580-2412-8 ** 39 13.2 10.8 11.4 12.03 12.7 FH26W-41S-0.3SHW(**) 580-2413-0 ** 41 13.8 11.4 12.0 12.63 13.3 FH26W-45S-0.3SHW(**) 580-2414-3 ** 45 15.0 12.6 13.2 13.83 14.5 FH26W-51S-0.3SHW(**) 580-2415-6 ** 51 16.8 14.4 15.0 15.63 16.3 FH26W-57S-0.3SHW(**) 580-2417-1 ** 57 18.6 16.2 16.8 17.43 18.1 FH26W-61S-0.3SHW(**) 580-2418-4 ** 61 19.8 17.4 18.0 18.63 19.3 FH26W-71S-0.3SHW(**) 580-2419-7 ** 71 22.8 20.4 21.0 21.63 22.3 Note 1 : Embossed tape reel packaging (5,000pcs/reel, 500pcs/reel). Order by number of reels. 3 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors (0.55 : Metal mask) Recommended metal mask thickness : t=0.1 0.95±0.05 2.15±0.05 (0.7 : Metal mask) (0.2) 0.6±0.05 (0.3 : Metal mask) 0.4±0.05 0.2±0.05 Outline of the connector 0.6±0.05 0.3±0.03 (0.23 : Metal mask) C±0.05 0.5±0.05 BRecommended FPC Dimensions Detail H (Lead plated 0.1 MAX) F±0.05 0.3±0.07 (0.15) 0.2±0.03 1 M 2.25±0.1 (2.5) (0.5) 2.5±0.3 B A 2.1±0.1 AX 1.1±0.1 0.3+0.04 -0.03 0.3±0.02 H M 0.3±0.1 .2 1±0.1 0.6±0.02 R0 0.3+0.04 -0.03 0.1±0.02 (0.2) (0.2) (0.07) 0.6±0.07 (0.05) B±0.03 1 (0.15) 0.6±0.07 Dimention M must be 0.5mm minimum when the stiffener is shorter than 3.5 min. All dimensions : mm Part No. FH26W-13S-0.3SHW(**) FH26W-15S-0.3SHW(**) FH26W-17S-0.3SHW(**) FH26W-19S-0.3SHW(**) FH26W-21S-0.3SHW(**) FH26W-23S-0.3SHW(**) FH26W-25S-0.3SHW(**) FH26W-27S-0.3SHW(**) FH26W-29S-0.3SHW(**) FH26W-31S-0.3SHW(**) FH26W-33S-0.3SHW(**) FH26W-35S-0.3SHW(**) FH26W-37S-0.3SHW(**) FH26W-39S-0.3SHW(**) FH26W-41S-0.3SHW(**) FH26W-45S-0.3SHW(**) FH26W-51S-0.3SHW(**) FH26W-57S-0.3SHW(**) FH26W-61S-0.3SHW(**) FH26W-71S-0.3SHW(**) 4 HRS No. 580-2401-1 ** 580-2402-4 ** 580-2403-7 ** 580-2437-9 ** 580-2404-0 ** 580-2405-2 ** 580-2406-5 ** 580-2400-9 ** 580-2407-8 ** 580-2408-0 ** 580-2409-3 ** 580-2410-2 ** 580-2411-5 ** 580-2412-8 ** 580-2413-0 ** 580-2414-3 ** 580-2415-6 ** 580-2417-1 ** 580-2418-4 ** 580-2419-7 ** No. of Contacts 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 45 51 57 61 71 B 3.0 3.6 4.2 4.8 5.4 6.0 6.6 7.2 7.8 8.4 9.0 9.6 10.2 10.8 11.4 12.6 14.4 16.2 17.4 20.4 0±0.03 1.1±0.1 1±0.1 C±0.03 3.5 MIN.(Stiffener) 0.3±0.07 C 3.6 4.2 4.8 5.4 6.0 6.6 7.2 7.8 8.4 9.0 9.6 10.2 10.8 11.4 12.0 13.2 15.0 16.8 18.0 21.0 F 4.2 4.8 5.4 6.0 6.6 7.2 7.8 8.4 9.0 9.6 10.2 10.8 11.4 12.0 12.6 13.8 15.6 17.4 18.6 21.6 πRELATIVE POSITIONS OF POINT-A dnd B 0.3±0.03 (0.23 : Metal mask) (0.45) B±0.05 0.3±0.05 (0.65 : Metal mask) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.8±0.05 (3.6) 0.65±0.05 BRecommended PCB mounting pattern and metal mask dimensions FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors BRecommended FPC Construction ●Contact FPC manufacturer for specific details. 1. Using Single-sided FPC Connecting side Material Name Covering film layer. Material Polyimide 1 mil thick. Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Cover adhesive Thickness (μm) 25 25 Surface treatment 1μm to 5μm Nickel underplated 0.2μm Gold plated Copper foil Cu Base adhesive Thermosetting adhesive 25 Base film Polyimide 1 mil thick 25 Reinforcement material adhesive Thermosetting adhesive 40 Stiffener Polyimide 75 1oz 3 mil thick Total 3 35 203 Back side 2. Using Double-sided FPC Connecting side Material Material Name Covering layer film Polyimide 1 mil thick 25 25 Cover adhesive Surface treatment 1μm to 5μm Nickel underplated 0.2μm Gold plated Through-hole copper Cu Copper foil Cu Base adhesive Thermosetting adhesive 18 Base film Polyimide 1 mil thick 25 Base adhesive Thermosetting adhesive 18 Copper foil Cu 18 Cover adhesive Thermosetting adhesive 25 Covering layer film Polyimide 1 mil thick 25 Reinforcement material adhesive Thermosetting adhesive 25 Stiffener Back side Thickness (μm) Polyimide 3 15 1/2oz 1/2oz 1 mil thick Total 18 25 197 ●To prevent release of the FPC due to it's bending, use of double sided FPC with copper foil on the back side is NOT RECOMMENDED. 3. Precautions 1. This specification is a recommendation for the construction of the FH26 Series FPC (t=0.2 ± 0.03). 2. For details about the construction, please contact the FPC manufacturers. 5 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors BPackaging Specification ●Embossed Carrier Tape Dimensions ●Embossed Carrier Tape Dimensions (3.05) (4.55) + 0 0 .1 G±0.3 (K) J±0.1 H±0.1 (0.3) Flat surface, for placement with automatic equipment (1.25) Unreeling direction (3.05) (4.55) 1.5+0.1 0 1.7 +0.15 0 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unreeling direction Ø1 .5 (1.6) (K) J±0.1 (0.3) 1.75±0.1 + 0 0 . 8±0.1 Ø1 .5 4±0.1 2±0.15 (1.6) (1.25) (Ø1 3) ●Reel Dimensions Unreeling direction (Ø80) (Ø380) (L : INSIDE) (M : OUTSIDE) End section Mounting section Lead section (400mm min.) Connectors Blank section (10 pockets min.) 6 Embossed carrier tape Blank section (10 pockets min.) Top cover tape G±0.3 1.75±0.1 (Tape width of 32mm min.) 1 (Tape width of 24mm max.) Flat surface, for placement with automatic equipment FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors HRS No. No. of Contacts G H J K L M FH26W-13S-0.3SHW(**) 580-2401-1 ** 13 16 −− 7.5 5.6 17.4 21.4 FH26W-15S-0.3SHW(**) 580-2402-4 ** 15 16 −− 7.5 6.2 17.4 21.4 FH26W-17S-0.3SHW(**) 580-2403-7 ** 17 16 −− 7.5 6.8 17.4 21.4 FH26W-19S-0.3SHW(**) 580-2437-9 ** 19 16 −− 7.5 7.4 17.4 21.4 FH26W-21S-0.3SHW(**) 580-2404-0 ** 21 16 −− 7.5 8.0 17.4 21.4 FH26W-23S-0.3SHW(**) 580-2405-2 ** 23 16 −− 7.5 8.6 17.4 21.4 FH26W-25S-0.3SHW(**) 580-2406-5 ** 25 16 −− 7.5 9.2 17.4 21.4 FH26W-27S-0.3SHW(**) 580-2400-9 ** 27 16 −− 7.5 9.8 17.4 21.4 FH26W-29S-0.3SHW(**) 580-2407-8 ** 29 24 −− 11.5 10.4 25.4 29.4 FH26W-31S-0.3SHW(**) 580-2408-0 ** 31 24 −− 11.5 11.0 25.4 29.4 FH26W-33S-0.3SHW(**) 580-2409-3 ** 33 24 −− 11.5 11.6 25.4 29.4 FH26W-35S-0.3SHW(**) 580-2410-2 ** 35 24 −− 11.5 12.2 25.4 29.4 −− 11.5 12.8 25.4 29.4 FH26W-37S-0.3SHW(**) 580-2411-5 ** 37 24 FH26W-39S-0.3SHW(**) 580-2412-8 ** 39 24 −− 11.5 13.4 25.4 29.4 FH26W-41S-0.3SHW(**) 580-2413-0 ** 41 24 −− 11.5 14.0 25.4 29.4 FH26W-45S-0.3SHW(**) 580-2414-3 ** 45 24 −− 11.5 15.2 25.4 29.4 FH26W-51S-0.3SHW(**) 580-2415-6 ** 51 24 −− 11.5 17.0 25.4 29.4 FH26W-57S-0.3SHW(**) 580-2417-1 ** 57 32 28.4 14.2 18.8 33.4 37.4 FH26W-61S-0.3SHW(**) 580-2418-4 ** 61 32 28.4 14.2 20.0 33.4 37.4 FH26W-71S-0.3SHW(**) 580-2419-7 ** 71 44 40.4 20.2 23.0 45.4 49.4 BRecommended Temperature Profile MAX 250ç 250 230ç Temperature Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. All dimensions : mm Part No. 200 200ç 150 150ç (ç) 100 50 25ç (60sec.) 90 sec. to 120 sec. 0 Start 60 Preheating 120 Time (Seconds) (60sec.) Soldering HRS test conditions Solder method : Reflow, IR/hot air Environment : Room air Solder composition : Paste, 96.5%Sn/3.0%Ag/0.5%Cu (Senju Metal Industry, Co., Ltd.'s Part Number: M705221CM5-32-10.5) Test board : Glass epoxy 25mm∞50mm∞0.8mm thick Land dimensions : 0.3mm∞0.65mm, 0.3mm∞0.8mm Metal mask : 0.23∞0.55∞0.1mm thick, 0.23∞0.65∞0.1mm thick The temperature profiles are based on the above conditions. In individual applications the actual temperature may vary, depending on solder paste type, volume/thickness and board size/thickness. Consult your solder paste and equipment manufacturer for specific recommendations. 7 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors BOperation and Precautions Operation 1.FPC insertion procedure. Connector installed on the board. Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 Lift up the actuator. Use thumb or index finger. 2 Fully insert the FPC in the connector par- allel to mounting surface, with the exposed conductive traces facing down. FPC conductor surface (Bottom side) 3 Rotate down the actuator until firmly closed. It is critical that the inserted FPC is not moved and remains fully inserted. 2.FPC removal 1 Lift up the actuator. Carefully withdraw the FPC. 8 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors Precautions This connector needs to be handled with care due to its thin design and miniature stature. [ Precautions when mounting to PCB ] The PCB distortion should be kept to a minimum. The maximum coplanarity of this connector is 0.1 mm, but excessive distortion can create solder failure. SFPC specifications Stiffeners can be used to improve the rigidity of the FPC. We recommend using a glass epoxy with the thickness of 0.3mm or more. SLoad to the connector Do not apply any excessive force or mate/unmate these connectors until they are mounted, failure to follow this precaution can lead to deformation or damage to these connectors. Inserting the FPC prior to mounting is not recommended either. [ Precautions in handling PCB after mounting ] SApplied force to the PCB Do not place any excessive force on the PCB after the connector has been mounted, this type of action may damage the connectors. (e.g., When separating the PCB into multiple boards or installing fastening screws onto the PCB) SPCB bending For PCB with a width of 100mm, it should not be bent more than a maximum of 0.5 mm. (Please refer to the diagrams below.) PCB bending places an extra load onto the connector and will lead to damage or malfunction. Connector PCB 100 0.5MAX Connector 0.5MAX Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. SAcceptable amount of PCB distortion 100 PCB Precautions When Inserting or Coupling FPC Pay attention to the following points when inserting FPC. SActuator operation 1 Do not apply excessive force when opening the actuator prior to FPC insertion. When opening make sure that the force is applied only to the actuator itself, avoiding touching of the contacts. Actuator Damage to the contacts Damage Axis of rotation 2 Axis of rotation Assure free rotation of the actuator 9 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors Precautions 3 The actuator will rotate 135 degrees 135˚ maximum. Do not apply force to rotate further. (1N max.) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4 When operating the actuator, do so at the center portion. 5 As illustrated, do not attempt removal or re- positioning of the actuator. SFPC Insertionq The FPC should be aligned parallel with the board surface and perpendicular with the connector (as shown), then completely inserted. Perpendicular with the connector To assure correct electrical and mechanical connection do not insert FPC at angle. It must be fully inserted. Make sure that the FPC is NOT MOVED during the closing of the actuator. 10 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors Precautions SFPC Insertionw Do not insert the FPC at any angle from above. Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. As illustrated, angle insertion may cause electrical discontinuity when the FPC is deflected in use. *To avert insertion of the FPC on an angle, consideration should be given to securing FPC insertion space at the time of board layout. Insertion will be difficult when the FPC is too short. *Contact the FPC manufacturer for information about the bending specifications. SVerification of the fully closed actuator. The actuator should be fully closed (as illustrated) and the FPC held firmly in the connector. Do not press against the actuator when is fully closed. Max force applied to the fully closed actuator should not exceed 1 N. Routing the FPC (FPC fully inserted/ actuator closed) SFPC Load Do not apply force in excess of 0.05N/pin max. in the upward direction (as illustrated). Do not bend the FPC too close to the actuator. Load : 0.05N/pin max. 11 FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors Precautions Removing the FPC Rotate the actuator to the open position (maximum open angle of 135). Carefully withdraw the FPC. Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 135˚ Powered by TCPDF (www.tcpdf.org) Other Precautions SHand Soldering Precautions When hand soldering: 1 Do not perform reflow or hand soldering with the FPC inserted in the connector. 2 Do not apply excessive heat or touch the soldering iron anywhere other than the connector leads. 3 Do not use excessive amount of solder or flux compounds. Operation of the actuator and contacts may be affected by excessive amounts of solder or flux compounds. 12 The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 05/2017. Contents are subject to change without notice for the purpose of improvements.
FH26J-55S-0.3SHW(97) 价格&库存
很抱歉,暂时无法提供与“FH26J-55S-0.3SHW(97)”相匹配的价格&库存,您可以联系我们找货
