GHDR-30V-S-1(F)
GHDR-30V-S-1(F)
    JST
    P=1.25mm
    2X15P 1.25MM
GHDR-30V-S-1(F) 数据手册
GHD CONNECTOR/GOLD-PLATED PRODUCT Emboss Tape 1.25mm pitch/Disconnectable Crimp style connectors ・ Secure lock device ・ Low insertion force ・ Prevention of contact deformation ・ Suction area for picking up GHD CONNECTOR/GOLD-PLATED PRODUCT Specifications To meet the requirement of the high density mounting on PC board of flat panel TV, AV equipments etc., this connector is designed to the double-row type of 1.25 mm pitch. Its operability is very well, in spite of the small size. ・ Current rating: 1.0 A AC, DC (AWG #26) ・ Voltage rating: 50 V AC, DC ・ Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) ・ Contact resistance: Initial value/Top entry type: 30 mΩ max. Side entry type: 50 mΩ max After environmental tests/Top entry type: 50 mΩ max. Side entry type: 70 mΩ max ・ Insulation resistance: 100 MΩ min. ・ Withstanding voltage: 500 VAC/minute ・ Applicable wire: Conductor size/ AWG #32 to #26 Insulation O.D./ 0.4 to 1.0 mm *In using the products,refer to "Handling Precaution for Terminal and Connector" described on our website (Technical documents of Product information page) * Contact JST for details. * RoHS2 compliance. Standards Recognized E60389 PC board layout and Assembly layout Side entry type 1.35 ±0.1 1±0.1 Circuit No.N-1 A ±0.1 0.6 ±0.05 1.25±0.05 Circuit No.1 Circuit No.N Circuit No.2 1.7 ±0.05 Connector outline 1.7 ±0.05 2.8 ±0.1 0.3 Circuit No.1 1.7 ±0.05 1.25 ±0.05 Circuit No.N-1 0.3 ±0.05 7.25 ±0.1 Circuit No.N A±0.1 0.6±0.05 1.7 ±0.05 Circuit No.2 Connector outline 7.55 ±0.05 Top entry type (Mating side faces to this side) (8.6) (8.05) (10.1) 1 Note: 1. The above figure is the figure viewed from the connector mounting side 2. Tolerance for the centers of pattern on PCB is ±0.05, and shall be not cumulative more than ±0.1. The dimensions above should serve as a guideline. Contact JST for details. (8.55) (8.5) (9.35) GHD CONNECTOR/GOLD-PLATED PRODUCT Contact Applicable wire AWG# mm2 Model No. SGHD-002GA-P0.2 SGHD-003GA-P0.2 0.05 ~ 0.13 Insulation O.D. (mm) Q'ty/reel 0.76~1.0 20,000 30~26 0.032~0.08 0.4 ~0.8 32~28 28,000 GHD CONNECTOR/GOLD-PLATED PRODUCT 1 Material and Finish Phosphor bronze, nickel-undercoated, selective gold-plated RoHS2 compliance 5.8 Contact SGHD-002GA-P0.2 Crimping machine Crimp applicator MKS-L-10-3 — AP-K2N MKS-L-10-3 SGHD-003GA-P0.2 — Applicator Dies Crimp applicator with dies MK/SSHL-002-02 APLMK SSHL002-02 — — MK/SGHD-003-02 APLMK SGHD003-02 — — Note: Contact JST for fully automatic crimping applicator. Housing No. of circuits 10 8.05 B 12 14 Circuit No.1 mark 16 6.6 18 20 22 24 1.25 26 A 28 30 32 36 38 B 40 8.05 Model No. GHDR-10V-S-1 (F) GHDR-12V-S-1 (F) GHDR-14V-S-1 (F) GHDR-16V-S-1 (F) GHDR-18V-S-1 (F) GHDR-20V-S-1 (F) GHDR-22V-S-1 (F) GHDR-24V-S-1 (F) GHDR-26V-S-1 (F) GHDR-28V-S-1 (F) GHDR-30V-S-1 (F) GHDR-32V-S-1 (F) GHDR-36V-S-1 (F) GHDR-38V-S-1 (F) GHDR-40V-S-1 (F) 5.00 9.50 1,000 6.25 10.75 1,000 7.50 12.00 1,000 8.75 13.25 1,000 10.00 14.50 1,000 11.25 15.75 1,000 12.50 17.00 1,000 13.75 18.25 1,000 15.00 19.50 1,000 16.25 20.75 1,000 17.50 22.00 1,000 18.75 23.25 1,000 21.25 25.75 1,000 22.50 27.00 1,000 23.75 28.25 1,000 PBT, UL94V-0, natural (white) 6.6 A Q'ty/ bag Material Circuit No.1 mark 1.25 Dimensions (mm) A B RoHS2 compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. GHDR-20V-S-1 (F)S...natural (white) LE...light blue MG...moss green DPK...dark pink 2 GHD CONNECTOR/GOLD-PLATED PRODUCT Header No. of circuits Top entry type Model No. BM10B-GHDS-G-TF BM12B-GHDS-G-TF BM14B-GHDS-G-TF BM16B-GHDS-G-TF BM18B-GHDS-G-TF BM20B-GHDS-G-TF BM22B-GHDS-G-TF BM24B-GHDS-G-TF BM26B-GHDS-G-TF BM28B-GHDS-G-TF BM30B-GHDS-G-TF BM32B-GHDS-G-TF BM36B-GHDS-G-TF BM38B-GHDS-G-TF BM40B-GHDS-G-TF 10 12 B 6.8 14 0.55 16 Circuit No.1 mark 18 5 20 22 24 6.85 1.25 26 A 28 30 32 B 6.8 36 0.55 38 Circuit No.1 mark 40 Dimensions (mm) A B Q'ty/ reel 5.00 9.50 1,250 6.25 10.75 1,250 7.50 12.00 1,250 8.75 13.25 1,250 10.00 14.50 1,250 11.25 15.75 1,250 12.50 17.00 1,250 13.75 18.25 1,250 15.00 19.50 1,250 16.25 20.75 1,250 17.50 22.00 1,250 18.75 23.25 1,250 21.25 25.75 1,250 22.50 27.00 1,250 23.75 28.25 1,250 5 Material and Finish Contact: Phosphor bronze, nickel-undercoated, gold-plated Housing: PA 9T, UL94V-0, natural (ivory) Reinforcement: Brass, copper-undercoated, tin-plated (reflow treatment) 6.85 1.25 RoHS2 compliance This product displays (LF)(SN) on a label. A As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 6.8 B 0.55 ex. BM20B-GHDS-G-TF- Circuit No.1 mark 5 S...natural (white) LE...light blue MG...moss green DPK...dark pink 0.25 B 5.85 1番極表示 1.25 0.75 6.85 6.1 A PA 9T type No. of circuits 1.25 Side entry type A Model No. SM10B-GHDS-A-GAN-TF SM12B-GHDS-A-GAN-TF SM14B-GHDS-A-GAN-TF SM16B-GHDS-A-GAN-TF SM18B-GHDS-A-GAN-TF SM20B-GHDS-A-GAN-TF SM22B-GHDS-A-GAN-TF SM24B-GHDS-A-GAN-TF SM26B-GHDS-A-GAN-TF SM28B-GHDS-A-GAN-TF SM30B-GHDS-A-GAN-TF SM36B-GHDS-A-GAN-TF SM38B-GHDS-A-GAN-TF SM40B-GHDS-A-GAN-TF 10 12 14 B 0.25 5.85 16 0.75 18 Circuit No.1 mark 20 22 6.1 24 26 28 30 1.25 36 A 38 40 Dimensions (mm) A B Q'ty/ reel 5.00 9.50 900 6.25 10.75 900 7.50 12.00 900 8.75 13.25 900 10.00 14.50 900 11.25 15.75 900 12.50 17.00 900 13.75 18.25 900 15.00 19.50 900 16.25 20.75 900 17.50 22.00 900 21.25 25.75 900 22.50 27.00 900 23.75 28.25 900 Material and Finish B 0.25 5.85 Contact: Phosphor bronze, nickel-undercoated, selective gold-plated Housing: PA 9T, UL94V-0, natural (ivory) 0.75 Circuit No.1 mark RoHS2 compliance 6.1 LCP type No. of circuits 12 1.25 A 20 22 30 Model No. SM12B-GHDS-GAN-TF SM20B-GHDS-GAN-TF SM22B-GHDS-GAN-TF SM30B-GHDS-GAN-TF Dimensions (mm) A B 6.25 10.75 900 11.25 15.75 900 12.50 17.00 900 17.50 22.00 900 Material and Finish Contact: Phosphor bronze, nickel-undercoated, selective gold-plated Housing: LCP, UL94V-0, natural (ivory) 3 RoHS2 compliance Q'ty/ reel
GHDR-30V-S-1(F) 价格&库存
很抱歉,暂时无法提供与“GHDR-30V-S-1(F)”相匹配的价格&库存,您可以联系我们找货
GHDR-30V-S-1(F)
    库存:4360
    GHDR-30V-S-1(F)
      • 1+1.910741+0.24798
      • 100+1.68741100+0.21900
      • 300+1.34827300+0.17498
      • 500+1.27383500+0.16532
      • 1000+1.224201000+0.15888
      • 4000+1.182844000+0.15351
      • 5000+1.182845000+0.15351
      库存:3078
      GHDR-30V-S-1(F)
        • 5+1.63815
        • 50+1.29633
        • 150+1.14988
        • 1000+0.96704
        • 2000+0.88571
        库存:4626
