HLE-112-02-G-DV-BE-P 数据手册
F-219 (Rev 03MAR20)
HLE–130–02–F–DV
HLE–110–02–L–DV
HLE–116–02–L–DV–K
(2.54 mm) .100"
HLE SERIES
COST-EFFECTIVE RELIABLE SOCKET
Mates With:
TSW, MTSW, DW,
EW, ZW, TLW, TSM,
MTLW, HW
NO. PINS
1 PER
ROW
HLE
PLATING
OPTION
02
DV
TAIL
OPTION
OTHER
OPTION
SPECIFICATIONS
For complete specifications
and recommended PCB layouts
see www.samtec.com?HLE
–F
Leave blank for
Surface Mount
(Requires –BE for
Bottom Entry)
= Gold flash on contact,
Matte Tin on tail
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
BeCu
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (HLE/TSM):
4.1 A per pin
(2 pins powered)
Voltage Rating:
400 VAC
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
(1.78 mm) .070" to
(3.43 mm) .135", pass-through,
or (2.59 mm) .102" min
plus board thickness for
bottom entry
RoHS Compliant:
Yes
–L
–TE
= 10 µ" (0.25 µm) Gold on contact,
Matte Tin on tail
= Through-hole
Top Entry
–A
–PE
= Through-hole
Pass-through Entry
(Requires –BE for
Bottom Entry)
= Locking Clip
(2 positions min.)
(Not available
with –A)
(Manual placement
required)
02 thru 50
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-20)
(0.15 mm) .006" max (21-50)*
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
–K
No. of Positions x (2.54) .100
(2.54)
.100
RECOGNITIONS
= (6.50 mm) .256"
DIA Polyimide
Film Pick &
Place Pad
(3 positions min.)
Not available
with –TE or
–PE tail option
02
(5.08)
.200
(2.54)
.100
For complete scope
of recognitions see
www.samtec.com/quality
01
–P
FILE NO. E111594
ALSO AVAILABLE
(0.51)
.020
(6.60)
.260
(3.05)
.120
–PE
–TE
(1.27)
.050
(1.27)
.050
–LC
(2.30)
.090
(7.62)
.300
–PE
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
–TR
= Tape & Reel
Packaging
(29 positions
max.)
–FR
(3.86)
.152
–P
(1.42)
.056
–A
(2.54)
.100
–TE
(7.11) .280
x
(5.71) .225
(1.60)
.063
DIA
= Metal Pick &
Place Pad
(3 positions min.)
(3.51)
.138
(3.66)
.144
• Other platings
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
= Alignment Pin
(4 positions min.)
Metal or plastic at
Samtec discretion
(Not available with
–TE, –PE & –LC)
–LC
PROCESSING
(MOQ Required)
–BE
= Bottom Entry
(Not available
with –TE)
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
= Full Reel
Tape & Reel
Packaging
(Must order max.
quantities per reel.
Contact Samtec
for parts per reel)
HLE-112-02-G-DV-BE-P 价格&库存
很抱歉,暂时无法提供与“HLE-112-02-G-DV-BE-P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 19+43.38252
- 38+40.20259
- 57+37.37329
- 国内价格 香港价格
- 19+43.8045919+5.67005
