THROUGH-HOLE
.025" SQ POST HEADER
(2.54 mm) .100" PITCH • TSW/HTSW SERIES
TSW/HTSW
SERIES
Board Mates:
SSW, SSQ, SSM, ESW, ESQ,
BCS, BSW, CES, SLW
Cable Mates:
IDSD, IDSS
= Standard Strip
SPECIFICATIONS
= Hi-Temp Strip
Insulator Material:
TSW: PBT
HTSW: Natural LCP
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Voltage Rating:
550 VAC mated with SSW;
500 VAC mated with BCS;
515 VAC mated with ESQ;
450 VAC -RA/-RE mated
with BCS or SSM;
400 VAC mated with CES
Lead–Free Solderable:
HTSW: Yes
TSW: No, Lead Wave Only
PIN CENTERS
TSW
–1
Specify
LEAD STYLE
from chart
= .100" (2.54 mm)
Center Version
–2
02 thru 25
= .200" (5.08 mm) Centers,
(Every other position filled)
= .200" (5.08 mm)
Center Version
(2.54) .100 x No. of Positions
–S
LEAD STYLE
01 thru 50
= .100" (2.54 mm) Centers,
(All positions filled)
HTSW
NO. PINS PER ROW
A
(2.48)
.098
(2.54)
.100
C
B
A
–D
(5.08)
.200
(5.02)
.198
C
B
A
–T
(7.56)
.298
(7.62)
.300
CURRENT RATING
(PER PIN)
TSW mated with
C
B
A
ESW SSW SLW SSQ SSM BCS SNT
5.2 A 5.7 A 5.2 A 6.3 A 5.2 A 4.6 A 4.3 A
–Q
2 POSITIONS POWERED
(7.56)
.298
(7.62)
.300
TSW
ALSO AVAILABLE
C
HTSW
MOQ Required
B
Straight Pin Versions
Other Platings
OTHER SOLUTIONS
Elevated Right-angle option
Shunts
LEAD
STYLE
B
C
STRAIGHT PIN VERSIONS
A
*–05
(8.51) .335
(3.30) .130
(2.67) .105
*–19
(26.16) 1.030
(7.62) .300
(2.41) .095
(2.67) .105
*– 20
(31.24) 1.230
B
(2.79) .110
*– 07
(10.92) .430
(2.54) .100
*– 21
(36.32) 1.430
(2.79) .110
*– 08
(13.46) .530
(5.08) .200
*– 22
(16.00) .630
(7.62) .300
– 09
(18.54) .730
(10.16) .400
*– 23
(11.30) .445
–10
(21.08) .830
(12.70) .500
*– 24
(12.15) .480
–11
(23.62) .930
(15.24) .600
*– 25
(16.00) .630
–12
(26.16) 1.030
(17.78) .700
▲ – 26
(11.58) .456
(3.20) .126
–13
(31.24) 1.230
(22.86) .900
– 27
(33.78) 1.330
(25.40) 1.000
–14
(13.46) .530
– 28
(28.70) 1.130
(20.32) .800
*–16
F-224
A
LEAD
STYLE
*– 06
*–15
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(18.54) .730
*–17
(21.08) .830
*–18
(23.62) .930
(2.79) .110
(7.87) .310
(2.79) .110
(5.84) .230
(8.13) .320
(2.92) .115
(5.33) .210
(13.21) .520
– 29
(33.78) 1.330
(23.11) .910
(8.13) .320
– 30
(28.70) 1.130
(18.03) .710
C
(20.83) .820
(25.91) 1.020
(30.99) 1.220
(5.84) .230
(6.73) .265
(8.13) .320
(5.84) .230
(8.13) .320
(15.74) .620
+– 41
(9.27) .365
(0.89) .035
(5.84) .230
(18.29) .720
+– 42
(11.94) .470
(1.27) .050
(8.13) .320
* Available with –LL (Locking Lead) Option
Specify -07 for best mate with IDXX Series IDC Cable
+ Style –41 & –42 available with HTSW only.
▲ Except: Style –26 (0.46) .018 DIA Tail
samtec.com?TSW or samtec.com?HTSW
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
PLATING OPTION
–F
– RA or –RE
= Single Row
–L
= Right-angle
–D
= 10 µ" (0.25 µm) Gold on post, Matte Tin on tail
–NA
= Double Row
–G
= Right-angle
(Using straight body for coplanar
mating with SSW-RA series)
–T
= 10 µ" (0.25 µm) Gold on post, Gold flash on balance
= Triple Row
–T
–Q
= Matte Tin
–LL
= Locking Lead
See charts for available styles.
Not available with single row
1 or 2 positions.
Recommended hole size
(1.02 mm ± 0.03 mm) .040" ± .001)
= Double Row
(5.08 mm).200"row space
C
–S
OTHER OPTION
–S
= Gold flash on post, Matte Tin on tail
(3.02)
.119
ROW OPTION
D
–LC
(3.09)
.122
= Locking Clip
(Styles –08 thru –13 & –22 only)
(Requires 4 pin minimum)
(Not available with T, –Q, –RA or–RE)
E
C
–D
–LA
= –RA Option with –LL Option
(6.10)
.240
(5.56)
.219
–“XXX”
= Polarized Position
E
C
–T
(8.12)
.320
(8.10)
.319
E
C
–Q
(8.12)
.320
RIGHT-ANGLE VERSIONS
(8.10)
.319
TSW
HTSW
-RA
LEAD
STYLE
E
D
– RA
(1.52) .060
– RE
(4.06) .160
-RE
LEAD
STYLE
– 09
–10
–11
–12
–13
–16
– 21
– 22
– 27
– 28
C
– 08
Right-Angle Versions
LEAD
STYLE
SINGLE (–S)
C
(5.84) .230
(8.13) .320
(5.84) .230
SINGLE
E
(4.83) .190
(7.37) .290
(9.91) .390
(12.45) .490
(17.53) .690
(2.54) .100
(22.61) .890
(2.29) .090
(20.07) .790
(14.99) .590
E
(2.29) .090
DOUBLE
(–D)
TRIPLE
(–T & –Q)
E
E
(2.29) .090
(2.29) .090
– 09
(7.37) .290
(7.37) .290
(7.37) .290
–10
(9.91) .390
(9.91) .390
(9.91) .390
–11
(5.84) .230
–12
–13
*–16
– 21
*– 22
*– 25
– 27
– 28
– 29
(8.13) .320
(5.84) .230
(8.13) .320
(5.84) .230
(8.13) .320
(12.45) .490
(12.45) .490
(12.45) .490
(14.99) .590
(14.99) .590
(14.99) .590
(20.07) .790
(20.07) .790
N/A
(5.08) .200
(5.08) .200
(5.08) .200
(25.15) .990
N/A
N/A
(4.83) .190
(4.83) .190
(4.83) .190
(2.54) .100
(2.54) .100
(2.54) .100
(22.61) .890
N/A
(17.53) .690
(17.53) .690
(20.32) .800
N/A
N/A
– 30
(15.24) .600
(15.24) .600
* Available with –LA (Locking Lead) Option
F-224
HTSW-113-08-LM-T-RA 价格&库存
很抱歉,暂时无法提供与“HTSW-113-08-LM-T-RA”相匹配的价格&库存,您可以联系我们找货
