2.54mm Pitch Board to Board Connector
HIF3H Series
■Features
1. Product Variation
Afford to connect the board to board horizontally or vertically.
2. Compatibility
Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Achieve combination with other HIF3H series.
■Applications
Computers, termination equipment, various kinds of electronic equipment, Office Automation machines and so on
■Product Specifications
Rating
Current rating: 3A
Operating Temperature Range: -55 to +85ç (Note 1)
Voltage rating: 300V AC Operating Humidity Range: 40 to 80%
Item
Storage Temperature Range: -10 to +60ç(Note 2)
Operating Humidity Range: 40 to 70% (Note 2)
Specification
Condition
1. Insulation Resistance
1000M ohms
500V DC
2. Withstanding Voltage
No flashover or insulation breakdown.
1000V AC/1 minute.
3. Contact Resistance
15m ohms max.
Measured at 0.1A
4. Vibration
No electrical discontinuity of 1μs or more
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
5. Humidity (Steady state) Insulation resistance: 1000 ohms min.
6. Temperature Cycle
96 hours at temperature of 40ç and humidity of 90% to 95%
( -55ç: 30 minutes→15 to 35ç: 5 minutes max.→
(125ç: 30 minutes→15 to 35ç: 5 minutes max.) 5 cycles
No damage, cracks, or parts looseness.
7. Durability (Mating/un-mating) Contact resistance: 15 m ohms max.
500 cycles
8. Resistance to Soldering heat No deformation of components affecting performance.
Solder bath: 260ç for 10 seconds
Manual soldering: 360ç for 5 seconds
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3. Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for
a specific part number shown.
■Material
Parts
Insulator
Receptacle Contact
DS
Material
Finish
Remarks
PBT
Black
UL94V-0
Phosphor bronze
Selective gold plated
DSA
Pin header
Brass or phosphor bronze
B53
HIF3H Series●2.54mm Pitch Board to Board Connector
■Ordering Information
●Pin Header
HIF3H - * P B - 2.54 DSA
q
w
q Series Name
e
r
t
: HIF3H
w Number of contacts : 4, 6, 10, 12, 14, 16, 20, 24, 26,
30, 34, 40, 50, 60, 70, 130
e
P
: Pin header
r Contact material A: Phosphor bronze (DS: brass)
B: Brass
t Contact pitch
: 2.54mm
y Contact type
DS : Right angle type
DSA : Straight type
W : Wrapping type
●Socket
HIF3H
q
A - * D A - 2.54 DSA
w
q Series Name
e
r
t
y
u
: HIF3H
w No symbol : Standard
A
: With mis-insertion preventive guide
B
: Similarly, guide position center 1 point type for 50, 60 and 64 contacts
e Number of contacts : 4, 6, 8, 10, 12, 14, 16, 18, 20, 24, 25,
26, 30, 34, 40, 50, 60, 64, 70, 130
r Contact alignment: D: double rows
S: single row
t
A
: Straight selective gold plated
B
: Right angle selective gold plated
y Contact pitch
: 2.54mm
u Contact type
DS: Right angle type
DSA: Straight type
B54
y
■Receptacle Straight Through hole Type
Unit:mm
Part Number
CL No.
Number of Contacts
HIF3HA- 6DA-2.54DSA(71) 618-0139-8-71
HIF3HA-10DA-2.54DSA(71) 618-0101-5-71
HIF3HA-10DA-2.54DSA(71) 618-0121-2-71
HIF3HA-12DA-2.54DSA(71) 618-0102-8-71
HIF3HA-16DA-2.54DSA(71) 618-0103-0-71
HIF3HA-16DA-2.54DSA(71) 618-0123-8-71
HIF3HA-18DA-2.54DSA(71) 618-0111-9-71
HIF3HA-20DA-2.54DSA(71) 618-0104-3-71
HIF3HA-20DA-2.54DSA(71) 618-0124-0-71
HIF3HA-24DA-2.54DSA(71) 618-0113-4-71
HIF3HA-26DA-2.54DSA(71) 618-0105-6-71
HIF3HA-26DA-2.54DSA(71) 618-0125-3-71
6
A
B
Part Number
RoHS
10
13.7 10.16
12
16.24 12.7
16
21.32 17.78
18
23.86 20.32
24
31.46 27.94
26
34.02 30.48
CL No.
HIF3HA-30DA-2.54DSA(71) 618-0106-9-71
8.62 5.08
HIF3HA-30DA-2.54DSA(71) 618-0126-6-71
HIF3HA-34DA-2.54DSA(71) 618-0107-1-71
HIF3HA-34DA-2.54DSA(71) 618-0127-9-71
HIF3HA-40DA-2.54DSA(71) 618-0108-4-71
YES
HIF3HA-40DA-2.54DSA(71) 618-0128-1-71
Number of Contacts
A
B
RoHS
30
39.1 35.56
34
44.18 40.64
40
51.8 48.26
50
64.5 60.96 YES
60
77.2 73.66
64
82.28 78.74
HIF3HA-50DA-2.54DSA(71) 618-0109-7-71
HIF3HA-50DA-2.54DSA(71) 618-0129-4-71
HIF3HB-50DA-2.54DSA(71) 618-0131-6-71
HIF3HA-60DA-2.54DSA(71) 618-0110-6-71
HIF3HA-60DA-2.54DSA(71) 618-0130-3-71
HIF3HB-60DA-2.54DSA(71) 618-0132-9-71
HIF3HA-64DA-2.54DSA(71) 618-0112-1-71
HIF3HA-64DA-2.54DSA(71) 618-0134-4-71
HIF3HB-64DA-2.54DSA(71) 618-0133-1-71
Part Number
CL No.
HIF3H-6SA-2.54DSA(71)
Number of Contacts
A
B
Unit:mm
RoHS
562-0713-1-71
6
16.24 12.7
HIF3H-10SA-2.54DSA(71) 562-0719-8-71
10
26.4
HIF3H-12SA-2.54DSA(71) 562-0723-5-71
12
31.48 27.94
HIF3H-14SA-2.54DSA(71) 562-0655-7-71
14
36.56 33.02
HIF3H-20SA-2.54DSA(71) 562-0704-0-71
48.26
HIF3H-25SA-2.54DSA(71) 562-0705-3-71
25
64.5
60.96
22.86
YES
B55
■Receptacle Right Angle Through hole Type
B56
Part Number
CL No.
Number of Contacts
RoHS
HIF3H- 4DB-2.54DS(71)
618-0150-0-71
4
HIF3H- 8DB-2.54DS(71)
618-0153-9-71
8
HIF3H-10DB-2.54DS(71)
618-0141-0-71
10
13.7 10.16
HIF3H-12DB-2.54DS(71)
618-0152-6-71
12
16.24 12.70
B
6.0
2.54
HIF3H-18DB-2.54DS(71) 618-0165-8-71
18
23.86 20.32
11.16 7.62
HIF3H-20DB-2.54DS(71) 618-0143-5-71
HIF3H-24DB-2.54DS(71) 618-0216-7-71
24
31.48 27.94
HIF3H-26DB-2.54DS(71) 618-0144-8-71
26
34.02 30.48
HIF3H-14DB-2.54DS(71)
618-0154-1-71
14
18.78 15.24
HIF3H-30DB-2.54DS(71) 618-0145-0-71
30
39.1 35.56 YES
HIF3H-16DB-2.54DS(71)
618-0142-2-71
16
21.32 17.78
HIF3H-34DB-2.54DS(71) 618-0146-3-71
34
44.18 40.64
HIF3H-40DB-2.54DS(71) 618-0147-6-71
40
51.8 48.26
HIF3H-50DB-2.54DS(71) 618-0148-9-71
50
64.5 60.96
HIF3H-60DB-2.54DS(71) 618-0149-1-71
60
77.2 73.66
YES
Part Number
CL No.
Number of Contacts
■Receptacle Right Angle Through hole Type 70 · 130 contacts
Part Number
CL No.
HIF3H-070DB-2.54DS(71)
618-0155-4-71
70
HIF3H-130DB-2.54DS(71)
618-0151-3-71
130
Number of Contacts
A
B
Unit:mm
RoHS
94.8 086.36
171
162.56
YES
A
Unit:mm
B RoHS
A
■Pin Header Through hole Type
Part Number
CL No.
Number of Contacts
A
B
RoHS
Part Number
CL No.
HIF3H-04PA-2.54DS(71)
618-0073-1-71
4
6
HIF3H-30PB-2.54DSA(71)
618-0207-6-71
HIF3H-06PB-2.54DSA(71)
618-0215-4-71
6
8.62 5.08
HIF3H-30P0-2.54W
618-0186-8
HIF3H-10PB-2.54DSA(71)
618-0201-0-71
HIF3H-10P0-2.54W
618-0185-5
10
13.7 10.16
HIF3H-34PB-2.54DSA(71)
618-0208-9-71
HIF3H-34P0-2.54W
618-0181-4
HIF3H-12PB-2.54DSA(71)
618-0202-2-71
12
HIF3H-14PB-2.54DSA(71)
618-0213-9-71
14
16.24 12.7
HIF3H-40PB-2.54DSA(71)
618-0209-1-71
18.78 15.24
HIF3H-40P0-2.54W
618-0182-7
HIF3H-16PB-2.54DSA(71)
618-0203-5-71
HIF3H-16PA-2.54DS(71)
618-0065-3-71
16
21.3 17.78 YES
HIF3H-50PB-2.54DSA(71)
618-0210-0-71
HIF3H-60PB-2.54DSA(71)
618-0211-3-71
HIF3H-20PB-2.54DSA(71)
618-0204-8-71
HIF3H-60P0-2.54W
618-0187-0
HIF3H-20P0-2.54W
618-0183-0
HIF3H-24PB-2.54DSA(71)
618-0205-0-71
HIF3H-24PA-2.54DS(71)
618-0067-9-71
HIF3H-26PB-2.54DSA(71)
618-0206-3-71
HIF3H-26P0-2.54W
618-0184-2
2.54
24
31.46 27.94
26
34.02 30.48
Number of Contacts
A
Unit:mm
B RoHS
30
39.1 35.56
34
44.18 40.64
40
51.8 48.26
50
64.5 60.96
60
77.2 73.66
YES
Note 1: The stitch line area is divided in two for 50 and 60
contacts.
Note 2: *indicates the number of contacts.
Note 3: Wrapping is 6.0.
Note 4: Wrapping is 16.0.
■Pin Header Through hole Type 70 · 130 contacts
Part Number
CL No.
Number of Contacts
HIF3H-070PB-2.54DSA(71) 618-0214-1-71
70
HIF3H-130PB-2.54DSA(71) 618-0212-6-71
130
A
B
Unit:mm
RoHS
97.8 086.36
174
162.56
YES
B57
BPCB mounting pattern
●Pin Header Straight and Right Angle Type
Size A List
B58
Powered by TCPDF (www.tcpdf.org)
●Receptacle Right Angle Type
●Receptacle Straight Type
Number of Contacts
A
4
2.54
6
5.08
8
7.62
10
10.16
12
12.7
14
15.24
16
17.78
18
20.32
24
27.94
26
30.48
30
35.56
34
40.64
40
48.26
50
60.96
60
73.66
64
78.74
70
86.36
130
162.56
