IPD1-15-S-K-M
IPD1-15-S-K-M
    SAMTEC(申泰)
    MINI-POWER CONNECTOR
IPD1-15-S-K-M 数据手册
(2.54 mm) .100" PITCH • DISCRETE WIRE CABLE & COMPONENTS - SERIES MMSD = Double Row PVC Cable MMSDT = Double Row Blue *Teflon Fluoropolymer Cable (20, 24, 28, 30 AWG only) ™ MMSS = Single Row PVC Cable MMSST - PINS PER ROW –02, –03, –04, –05, –06, –08, –10, –12, –15, –16, –20, –25 WIRE GAUGE - = Color Coded Cable (MMSD & MMSS only) –22, –24 = Color Coded Cable (MMSD & MMSS only) = Single Row Blue *Teflon Fluoropolymer Cable (20, 24, 28, 30 AWG) –26, –28 MMSD, MMSDT, MMSS, MMSST –28C = Color Coded Cable (MMSD & MMSS only) Board Mates: IPL1 (Does not mate with IPT1) Cable Mates: MMTD(T), MMTS(T) –30 SPECIFICATIONS PIN COLOR 1 2 3 4 5 6 7 8 9 10 ETC BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GRAY WHITE BLACK REPEAT No. of positions x (2.54) .100 *Teflon™ is a trademark of The + (1.40) .055 Chemours Company FC, LLC used under license by Samtec. Insulator Material: Nylon 66 Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Voltage Rating: 300 VAC = Assembly Length in Inches (82.55 mm) 03.25" min. –20C, –24C, –28C CABLE COLOR CODING –24C - ASSEMBLY LENGTH –“XX.XX” = 10 µ" (0.25 µm) Gold on contact, Tin on tail –20C ™ - –L –20 (Standard sizes) PLATING OPTION END OPTION - –S - K –K = Single Ended = Keyed Polarization –D (Metal latches for more rugged environments; –02, –05 & –10 positions only) –M = Single Ended, Metal Latches (Leave blank for plastic) = Double Ended (Latch Required) Double Ended (–D) Crossed requires MMSD/MMSDT –LUS = Plastic Latch up, straight –LDS = Plastic Latch down, straight –LUX = Plastic Latch up, crossed –LDX Assembly Length ± (3.18) .125 = Plastic Latch down, crossed Assembly –MUS ±Length (3.18) = Metal Latch up, straight .125 –MDS = Metal Latch down, straight No. of positions x (2.54) .100 + (1.40) .055 ™ (8.97) Teflon Fluoropolymer cable .353 is intended for crimp only. Contact Samtec for solderable cable applications. LATCH OPTION –MUX = Metal Latch up, crossed –MDX (8.97) .353 = Metal Latch down, crossed View complete specifications at: samtec.com?MMSD, samtec.com?MMSDT, samtec.com?MMSS & samtec.com?MMSST IPD1 - POSITIONS PER ROW –02, –03, –04, –05, –06, –08, –10, –12, –15, –16, –20, –25 (Standard sizes) - ROW OPTION –S = Single Row - - K –K = Keyed Polarization –D = Double Row LATCH OPTION SERIES –M CC79L = Metal Latch (Metal for more rugged environments) (–02, –05 & –10 positions only) = Contact, Loose CC79R = Contact, Full Reel (12,000 Parts per Reel) (Leave blank for plastic latch) WIRE GAUGE –D - 01 –2630 PLATING OPTION –L = 26 to 30 AWG = 10 µ" (0.25 µm) Gold on contact, Tin on tail –2024 = 20 to 24 AWG   (12.83) .505 –S -   –M TOOLING Hand Tool: CAT-HT-179-2030-13 (20-30 AWG) Not: Some lengths, styles and options are non-standard, non-returnable. F-224 (Rev 10NOV23) Mini Applicator: CAT-MC-179-2024-XX-01 (20-24 AWG) Mini Applicator: CAT-MC-179-2630 XX-01 (26-30 AWG) Extraction Tool: CAT-EX-179-01 View complete specifications at: samtec.com?IPD1, samtec.com?CC79L & samtec.com?CC79R samtec.com/MiniMate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
IPD1-15-S-K-M 价格&库存
很抱歉,暂时无法提供与“IPD1-15-S-K-M”相匹配的价格&库存,您可以联系我们找货
