MB1-150-01-F-S-02-SL 数据手册
F-224 SUPPLEMENT
MB1–130–01–F–S–01–SL–N
(1.00 mm) .0394"
MB1 SERIES
MINI EDGE CARD SOCKET WITH GUIDES
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?MB1
Choice of two
card thicknesses
Mates with:
(0.80 mm) .031" PCB,
(1.60 mm) .062" PCB
Insulator Material:
Black LCP
Contact Material:
BeCu
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating:
2.2 A per pin
(6 pins powered)
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
(5.26 mm) .207" to
(6.10 mm) .240"
RoHS Compliant:
Yes
(5.44 mm)
.214"
(1.00 mm)
.03937" pitch
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (20-30)
(0.15 mm) .006" max (40-50)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
MB1
1
NO. OF
PINS
01
PLATING
OPTION
CARD
SLOT
S
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
= Gold flash on contact,
Matte Tin on tail
(No. of Positions + 2)
x (1.00) .03937 + (4.06) .160
FILE NO. E111594
–L
(3.81)
.150
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
ALSO AVAILABLE
(MOQ Required)
CARD
SLOT
• Other platings
A
(0.97)
–01
–02
.038
(1.83)
.072
= No Card
Guides
MATES WITH
BOARD THICKNESS
(0.80) .031
(1.60) .062
(25.5)
1.004
(7.24)
.285
(7.24)
.285
01
(1.00)
.03937
–N OPTION
50
(0.36)
.014
(1.27)
.050
x (1.00) .03937
(1.52)
.060
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
(5.44)
.214
(1.27)
.050
DIA
OTHER
OPTION
–N
Specify
CARD
SLOT
from
chart
–F
20, 30, 40, 50
SL
A
(0.15)
.006
(0.69)
.027
(1.27)
.050
(2.36)
.093
Important Note: Samtec recommends that pads on the mating board be Gold plated.
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MB1-150-01-F-S-02-SL 价格&库存
很抱歉,暂时无法提供与“MB1-150-01-F-S-02-SL”相匹配的价格&库存,您可以联系我们找货
