MEC1-130-02-S-D-RA1-SL 数据手册
F-215
MEC1–120–02–F–D–A
MEC1–130–02–F–D–A
MEC1–140–02–L–D
(1,00 mm) .0394"
MEC1 SERIES
MINI EDGE CARD SOCKET
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?MEC1
Insulator Material:
Black LCP
Contact Material:
BeCu
Plating:
Sn or Au over 50µ"
(1,27 µm) Ni
Operating Temp Range:
-55°C to +125°C
Current Rating:
2.2 A per pin
(2 adjacent pins powered)
Voltage Rating:
300 VAC
Insertion Depth:
(5,84 mm) .230" to
(8,13 mm) .320"
RoHS Compliant:
Yes
Processing:
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max (05-20)
(0,15 mm) .006" max (30-70)
Mates with
(1,60 mm)
.062" card
Mates with:
(1,60 mm) .062" card
APPLICATION
MEC1
Rated @ 3dB Insertion Loss*
9,04 mm Stack Height
Single-Ended Signaling
5.5 GHz / 11 Gbps
Differential Pair Signaling
6.5 GHz / 13 Gbps
*Performance data includes effects of a non-optimized PCB.
Complete test data available at www.samtec.com?MEC1 or
contact sig@samtec.com
1
MEC1
POSITIONS
PER ROW
Optional
Alignment pin
PLATING
OPTION
02
D
NP
OTHER
OPTION
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
–A
05, 08, 20, 30, 40, 50, 60, 70
–F
–NP
= Gold flash
on contact,
Matte tin on tail
–L
= No
Polarization
(05, 08, 20 &
30 positions
only)
= 10µ" (0,25 µm)
Gold on contact,
Matte Tin on tail
Leave
Blank for
polarization
ALSO AVAILABLE
(MOQ Required)
• Locking Clip
(Manual placement required)
• Other platings
Contact Samtec.
(No. of Positions + 2) x
(1,00) .03937 + (2,54) .100
02
140
(6,99)
.275
01
Note: While optimized for
50Ω applications, this
connector with alternative
signal/ground patterns may
also perform well in certain
75Ω applications. Contact
Samtec for further information.
Important Note:
Samtec recommends that
pads on the mating board be
Gold plated.
139
(0,36)
(1,00)
.014
.03937
x (1,00) .03937
(8,89)
.350
(1,83)
.072
(9,04)
.356
POSITIONS
PER ROW
POLARIZED
POSITIONS
(No Contact)
05
08
40
50
60
70
3, 4
5, 6
15, 16
21, 22
31, 32
41, 42
31, 32, 63 & 64
53, 54, 115 & 116
(0,15)
.006
(1,40)
.055
(8,51)
.335
(0,89)
.035
DIA
–A
OPTION
Note: Some sizes, styles and
options are non-standard,
non-returnable.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
= Alignment
Pin metal or
plastic at
Samtec
discretion.
–K
= (7,87 mm)
.310" DIA
Polyimide film
Pick &
Place Pad
–TR
= Tape & Reel
