MEC8-170-02-L-DV-A-K-TR
    SAMTEC(申泰)
    SMD,P=0.8mm
    CONN EDGE DUAL FMALE 140P 0.031
MEC8-170-02-L-DV-A-K-TR 数据手册
MICRO EDGE CARD SYSTEMS 0.50 mm, 0.635 mm, 0.80 mm, 1.00 mm, 1.27 mm, 2.00 mm PITCH FEATURES & BENEFITS • Up to 56 Gbps PAM4 • PCI Express® 4.0 (MEC5 Series) • Solutions for (1.60 mm) .062" and (2.36 mm) .093" thick cards • Choice of pitch: 0.50 mm, 0.635 mm, 0.80 mm, 1.00 mm, 1.27 mm, 2.00 mm Staggered press-fit tails (MEC8-VP) • Vertical, right-angle and edge mount orientations • Available in surface mount and through-hole Justification beam ensures card and body are flush (MEC5) KEY SPECIFICATIONS SERIES PITCH TOTAL POSITIONS INSULATOR MATERIAL CONTACT MATERIAL OPERATING TEMP RANGE CURRENT RATING VOLTAGE RATING LEAD-FREE SOLDERABLE MEC5 0.50 mm 60-200 Black LCP Phosphor Bronze -55 ℃ to +125 ℃ 1.5 A (2 pins) 125 VAC Yes MEC6 0.635 mm 20-140 Black LCP Phosphor Bronze -55 ℃ to +125 ℃ 2.4 A (2 pins) 185 VAC Yes MEC8 0.80 mm 20-140 Black LCP Phosphor Bronze -55 ℃ to +125 ℃ 2.3 A (2 pins) 180 VAC Yes MEC1 1.00 mm 20-140 Black LCP Phosphor Bronze -55 ℃ to +125 ℃ 2.2 A (2 pins) 250 VAC Yes MECF 1.27 mm 10-100 Black/Natural LCP BeCu -55 ℃ to +125 ℃ 3.5 A (2 pins) 280 VAC Yes MEC2 2.00 mm 10-100 Black/Natural LCP BeCu -55 ℃ to +125 ℃ 3.5 A (2 pins) 235 VAC Yes F-224 samtec.com/EdgeCard Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (0.80 mm) .0315" PITCH • VERTICAL AND PRESS-FIT EDGE CARD SOCKET MEC8 - - 02 - POSITIONS PER ROW 1 10, 20, 30, 40, 50, 60, 70 - PLATING OPTION DV - –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail MEC8-DV Card Mates: (1.60 mm) .062" thick card - OTHER OPTIONS “X”R = Alignment Pin –A Leave blank for Tray Packaging –K = Tape & Reel –TR = (5.50 mm) 2.17" DIA Polyimide Pick & Place Pad POSITIONS PER ROW A B 40 (18.90) .744 (36.60) 1.441 50 (22.90) .902 (44.60) 1.756 60 (26.90) 1.059 (52.60) 2.071 70 (30.90) 1.217 (60.60) 2.386 –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) 25 1RRI3RVLWLRQV[       G b p s 1RRI3RVLWLRQV[     10, 20, & 30 POSITIONS 1RRI3RVLWLRQV[     % $       40, 50, 60 & 70 POSITIONS View complete specifications at: samtec.com?MEC8-DV MEC8 - 1 POSITIONS PER ROW 10, 20, 30, 40 MEC8-VP - CARD THICKNESS - –02 - PLATING OPTION –L = (1.60 mm) .062" thick card = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail TAIL –VP = Press-fit 1RRI3RVLWLRQV[     Card Mates: (1.60 mm) .062" thick card   14 G b p s 1RRI3RVLWLRQV[       10, 20 & 30 POSITIONS   Note: Some sizes, styles and options are non-standard, non-returnable. 40 POSITIONS     View complete specifications at: samtec.com?MEC8-VP samtec.com/EdgeCard Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
MEC8-170-02-L-DV-A-K-TR 价格&库存
很抱歉,暂时无法提供与“MEC8-170-02-L-DV-A-K-TR”相匹配的价格&库存,您可以联系我们找货
