F-219
MMS–112–02–F–SH
MMS–112–01–L–DH
MMS–116–02–L–DV
MMS–108–01–L–SV
(2.00 mm) .0787"
MMS SERIES
TIGER CLAW SOCKET STRIP
Board Mates:
TMMH, TMM,
MTMM, MMT, TW,
LTMM, ZLTMM, TSH
MMS
NO. PINS
PER ROW
1
ROW
OPTION
PLATING
OPTION
01
Cable Mates:
TCMD
02 thru 40
SPECIFICATIONS
For complete specifications
see www.samtec.com?MMS
(2.00)
.0787
Insulator Material:
Black LCP
Contact Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating (MMS/TMM):
3.9 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Insertion Depth:
DH = (2.13 mm) .084" to
(2.79 mm) .110",
SH = (2.13 mm) .084"
minimum or pass-through
Top Entry DV/SV = (2.13 mm)
.084" to (4.32 mm) .170"
Bottom Entry DV/SV =
(4.27 mm) .168" minimum
(Plus board)
RoHS Compliant:
Yes
01
–SV
–SH
80
= Single Horizontal
–SH
–DV
= Double Vertical
–DH
(2.00)
.0787
–DV
= Polarized
Position
= Double Horizontal
01
–DH
No. of positions x
(2.00) .0787 + (0.56) .022
(4.45)
.175
–DH
–SH
MMS
(4.70)
.185
(2.92)
.115
–SV
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.15 mm) .006" max*
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
1
–SV
–DV
NO. PINS
PER ROW
For complete scope
of recognitions see
www.samtec.com/quality
01
FILE NO. E111594
–SH
80
ALSO AVAILABLE
• Alignment Pin (–DV only)
• Locking clips and Throughhole pass-through options
• Other platings
–S Row
(3.81) .150
x
(7.62) .300
02
(2.00) (4.17)
.0787 .164
79
(1.22)
.048
–P
= Single
Vertical
–SH
= Single
Horizontal
= 10 µ" (0.25 µm)
Gold contact,
Matte Tin on tail
–DV
= Double
Vertical
–DH
= Double
Horizontal
(5.08)
.200
x
(5.71)
.225
–DH
No. of positions x
–SV
–D Row
(5.71) .225
x
(10.01).394
01
–DV
ROW
OPTION
–L
–M
(1.39) .055
–SV
–SH
–“XX”
= Polarized Position
–K
= (5.50 mm) .217" DIA
Polyimide Film
Pick & Place Pad
(–SV & –DV only)
(–SV= 3 positions min.)
(–DV= 4 positions min.)
–M
= Metal Pick & Place Pad
(4 positions min.)
(–DV only)
= Plastic Pick & Place Pad
(4 pos. min., –SV only)
(5 pos. min., –DV only)
= Tape & Reel Packaging
–DV
–DH
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
OTHER
OPTION
–TR
(1.39)
.055
(4.50)
.177
(3.05)
.120
–P
(4.70)
.185
(1.22) .048
(4.70)
.185
–DH
–DV
= Gold flash
on contact,
Matte Tin on tail
40
(4.00)
.157
(2.00)
.079
–F
(2.16)
.085
–SV
(2.92)
.115
PLATING
OPTION
02
(2.00)
.0787
(2.00)
.0787
(3.05)
.120
–SH
02 thru 40
RECOGNITIONS
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
–L
02
79
–“XX”
= Single Vertical
= 10 µ" (0.25 µm) Gold contact,
Matte Tin on tail
40
(4.00)
.157
PROCESSING
(MOQ Required)
–SV
–F
= Gold flash on contact,
Matte Tin on tail
(2.00) .0787
OTHER
OPTION
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
很抱歉,暂时无法提供与“MMS-117-01-L-DV”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 16+47.40882
- 32+43.38252
- 64+39.34413
- 112+37.55466
- 512+34.12081
- 1008+30.00987
- 2512+24.08528
- 5008+19.45443
