LOW PROFILE
.025" SQ POST HEADERS
(2.54 mm) .100" PITCH • TLW/MTLW SERIES
TLW/MTLW
Board Mates:
BSW, CES, SLW, HLE
TLW
-1
01 thru 40
FEATURES
These headers provide
the ultimate low profile
(0.64 mm) .025" square
post board stacking
system. The high quality
Phosphor Bronze
terminals are available
with a standard short post
height (TLW Series) for
mating with low profile
sockets, or the post
height can be Modified
(MTLW Series) to
accommodate IDC
assemblies and other
applications.
NO. PINS
PER ROW
LEAD
STYLE
01 thru 36
= Double Row
PROCESSING
Lead–Free Solderable:
Yes
–G
= 10 µ"
(0.25 µm)
Gold on post,
Gold flash
on tail
(2.48)
.098
F-224
–S
–RA
= Single
Row
= Right-angle
(–01 Lead Style only)
–D
–“XX”
= Double
Row
(5.03)
.198
(3.05)
.120
(1.52)
.060
B
= Polarized Position
Specify position for
omitted pin.
—01
—05 & —06
MTLW
-1
NO. PINS
PER ROW
01 thru 40
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
= Single Row
01 thru 36
= Double Row
PLATING
OPTION
–F
= Gold flash
on post,
Matte Tin on tail
–L
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
–G
= 10 µ" (0.25 µm)
Gold on post,
Gold flash on tail
(2.48)
.098
–T
= Matte Tin
(5.03)
.198
POST
(0.00) .000
MIN
(OAL)
LEAD
STYLE
A
B
–01
N/A
(5.84)
.230
–05
(4.32)
.170
–06
(3.43)
.135
ROW
OPTION
B
(1.52)
.060
A
(1.52)
.060
Note:
Some lengths, styles and
options are non-standard,
non-returnable. MTLW Series
is non-standard, nonreturnable.
OTHER
OPTION
–T
MOQ Required
Other platings
Notch option
ROW
OPTION
= Matte Tin
(2.54) .100 x No. of Positions
ALSO AVAILABLE
= Gold flash
on post,
Matte Tin
on tail
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (TLW/SLW):
5.2 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +105 °C with Tin
-55 °C to +125 °C with Gold
–F
Specify
LEAD
STYLE
from
chart
= Single Row
PLATING
OPTION
TAIL
(0.00) .000
MIN
–S
= Single
Row
–D
(2.67)
.105
POST
HEIGHT
–“XXX”
= Post Height
Dimension
(In inches)
= Double
Row
LEAD
STYLE
OAL
–05
(8.51) .335
–06
(7.62) .300
–07
(10.92) .430
–08
(13.46) .530
–09
(18.54) .730
–10
(21.08) .830
–22
(16.00) .630
–23
(11.30) .445
–24
(12.19) .480
samtec.com?TLW or samtec.com?MTLW
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MTLW-103-05-T-D-135 价格&库存
很抱歉,暂时无法提供与“MTLW-103-05-T-D-135”相匹配的价格&库存,您可以联系我们找货
