MW-40-03-G-D-095-085-P-TR 数据手册
SMT MICRO
BOARD HEADER
(1.00 mm) .0394" PITCH • MW SERIES
MW
Mates:
CLM, MLE
MW
- 03 -
NO. PINS
PER ROW
02 thru 50
SPECIFICATIONS
Insulator Material:
Top: Black LCP
Bottom: Natural LCP
Terminal Material:
Phosphor Bronze
Plating:
Au over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C
PLATING
OPTION
-D-
STACKER
HEIGHT
–G
= 10 µ"
(0.25 µm)
Gold
–“XXX”
–“XXX”
(2.41 mm)
.095" to
(6.22 mm)
.245"
(1.65 mm)
.065"
minimum
= Stacker
Height
(in inches)
Example:
–245
= (6.22 mm)
.245"
PROCESSING
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-30)
(0.15 mm) .006" max (31-50)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
POST
HEIGHT
= Post
Height
(in inches)
Example:
–065
= (1.65 mm)
.065"
OPTION
–A
= Alignment
Pin
(5 positions
minimum)
Metal or
plastic at
Samtec’s
discretion
–P
= Pick &
Place Pad
(7 positions
minimum)
–TR
= Tape & Reel
–FR
= Full Reel
Tape & Reel
(must order
maximum
quantity per
reel; contact
Samtec for
quantity
breaks)
1RRISRVLWLRQV[
3267
+(,*+7
0,1
ALSO AVAILABLE
0$;
29(5$//
/(1*7+
MOQ Required
End shrouds
End shrouds with
guide posts
67$&.(5
+(,*+7
WR
APPLICATION
–P OPTION
EXAMPLES
Notes:
For added mechanical
stability, Samtec recommends
mechanical board spacers be
used in applications with gold or
selective gold plated connectors.
Contact ipg@samtec.com for
more information.
This Series is non-standard,
non-returnable.
LEAD STYLE
MW
–163-065
–233-065
CLM
–02
MATED
HEIGHT*
(6.35 mm) .250"
(8.13 mm) .320"
*Processing conditions
will affect mated height.
MATED
HEIGHT
CLM
MW
(2.21)
.087
samtec.com?MW
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
MW-40-03-G-D-095-085-P-TR 价格&库存
很抱歉,暂时无法提供与“MW-40-03-G-D-095-085-P-TR”相匹配的价格&库存,您可以联系我们找货
