OPP-07-01-T-S-E-AD
OPP-07-01-T-S-E-AD
    SAMTEC(申泰)
OPP-07-01-T-S-E-AD 数据手册
F-215 SUPPLEMENT (Rev 23JUN16) OPP–03–01–T–S–E–AD OPP–07–01–T–S–AD OPP–10–01–T–S–E–AD (2.54 mm) .100" OPP SERIES ONE-PIECE POWER INTERFACE SPECIFICATIONS Thread insert option For complete specifications and recommended PCB layouts see www.samtec.com?OPP Insulator Material: Black Liquid Crystal Polymer Contact Material: BeCu Plating: Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +105 °C Current Rating: 9.6 A per pin (1 pin powered) Voltage Rating: 280 VAC RoHS Compliant: Yes (2.54 mm) .100" pitch Processing: Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.15 mm) .006" max RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality OPP NO. PINS PER ROW 01 PLATING OPTION INSERT OPTION S FILE NO. E111594 –03, –07, –10 Leave blank for no Screw Inserts –T = Matte Tin –E ALSO AVAILABLE = #2-56 x 1/16" screw thread (MOQ Required) • Alternative alignment pin available Contact Samtec. –M No. of positions x (2.54) .100 + (0.76) .030 = 2.00 mm x 0.40 mm screw thread (6.60) .260 (9.32) .367 01 (1.27) .050 (2.54) .100 (0.25) .010 (3.00) .118 (0.61) .024 No. of positions x (2.54) .100 + (13.46) .530 (1.02) .040 (3.30) .130 No. of positions x (2.54) .100 + (5.08) .200 (1.02) .040 –AD OPTION Note: Some sizes, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. AD – AD = Alignment Pin Dual Side
OPP-07-01-T-S-E-AD 价格&库存
很抱歉,暂时无法提供与“OPP-07-01-T-S-E-AD”相匹配的价格&库存,您可以联系我们找货
OPP-07-01-T-S-E-AD
  • 18+38.5541018+4.94534
