PESS-06-10-L-20.00-SR
    SAMTEC(申泰)
    PESS CABLE ASSEMBLY
PESS-06-10-L-20.00-SR 数据手册
(6.35 mm) .250" PITCH • 40 A CABLE ASSEMBLY/COMPONENTS PESS - - NO. OF POSITIONS WIRE GAUGE –02, –04, –06, –08 - –10 - PLATING OPTION –L - –"XX.XX" = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –12 ASSEMBLED LENGTH = Wire length in inches (152.4 mm) 06.00" min. - END 1 OPTION END 2 OPTION –SR (Available with -DR only) –DR = Notch up, straight (Available with -DR only) = Single End –NUS = Double End –T –NDS = Matte Tin on tail PESS Board Mates: PET = Notch down, straight (9.50) .374 NO. OF POSITIONS SPECIFICATIONS Insulator Material: Nylon Black Contact Material: Copper Alloy Plating: Sn or Au over 50 µ" (1.27 µm) Ni Operating Temp Range: -30 °C to +105 °C Voltage Rating: 600 VAC 846 VDC Wire: 10 or 12 AWG –02 (43.9) 1.73 –04 (56.6) 2.23 –06 (69.3) 2.73 –08 (82.0) 3.23 No. of positions x (6.35) .250 + (23.31) .918 A A WIRE GAUGE 10 AWG 12 AWG PESS/PET CURRENT RATING (PER PIN) 34.5 A 29.7 A 1 PIN POWERED Assembled Length ± (3.2) .13 View complete specifications at: samtec.com?PESS IPS6 - POSITIONS PER ROW - 01 –02, –04, –06, –08 - SERIES LATCH –L CC10R = Latch = Contact, Full Reel - WIRE GAUGE –1012 = 10 to 12 AWG CC10L PLATING OPTION –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –T = Contact, Loose = Matte Tin on tail (12.00) .472 No. of positions x (6.35) .250 + (23.31) .918 - (32.50) 1.280 (27.00) 1.063 TOOLING Hand Tool: CAT-HT-310-1012-14 Note: Some lengths, styles and options are non-standard, non-returnable F-224 Mini Applicator: CAT-MC-310-1012-XX-02 View complete specifications at: samtec.com?IPS6, samtec.com?CC10L & samtec.com?CC10R samtec.com/PowerStrip Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
PESS-06-10-L-20.00-SR 价格&库存
很抱歉,暂时无法提供与“PESS-06-10-L-20.00-SR”相匹配的价格&库存,您可以联系我们找货
