HIGH POWER SYSTEMS
20-60 A
p er bla de
FEATURES & BENEFITS
• Current Rating: 23 A - 58.7 A per power blade
• 3.81 mm, 5.00 mm and 6.35 mm pitch
• Dual blade contact system
• Power only or power/signal combinations available
• Right-angle and vertical orientations
• Rugged screw down and locking clip options
• Discrete wire cable assemblies with 10-16 AWG wire
(see pages 246-248)
• “Hinged” for unique mating in any orientation
from 0° to 90° and space confined applications
CREEPAGE & CLEARANCE
Hermaphroditic options
samtec.com?MPPT and
samtec.com?UPPT
Hinging options available
samtec.com?FMPT and
samtec.com?FMPS
PITCH
CREEPAGE
CLEARANCE
UPT/UPS/UPPT
5.50 mm
1.51 mm
MPT/MPS/MPTC/MPSC
2.95 mm
2.71 mm
PET/PES/PETC/PESC
3.66 mm
3.31 mm
Selectively loading contacts achieves customer specific
creepage and clearance requirements.
KEY SPECIFICATIONS
SERIES
SERIES
INSULATOR CONTACT
MATERIAL MATERIAL
PLATING
OPERATING
TEMP RANGE
CURRENT RATING
VOLTAGE
RATING
LEAD-FREE
SOLDERABLE
UPT/UPS
(3.81 mm)
.150"
Black LCP
BeCu
Sn or Au over
-55 ºC to +105 ºC (Sn)
50 µ" (1.27 µm) Ni -55 ºC to +125 ºC (Au)
23 A
(1 pin powered)
438 VAC
Yes
UPPT
(3.81 mm)
.150"
Black LCP
Copper Alloy
Sn or Au over
21.4 A
(1 pin powered)
425 VAC
Yes
MPT/MPS
(5.00 mm)
.1969"
Black LCP
Copper Alloy
Sn or Au over
28.8 A
(1 pin powered)
575 VAC
Yes
(5.00 mm)
.197" (pwr)
MPTC/MPSC (2.00 mm)
.079" (sig)
Black LCP
Signal:
Phosphor
Sn or Au over
Bronze
Terminal:
Copper Alloy
28.8 A
(pwr - 1 pin powered)
5A
(sig - 4 pins powered)
250 VAC
Yes
PET/PES
(6.35 mm)
.250"
Black LCP
Copper Alloy
Sn or Au over
58.7 A
(1 pin powered)
450 VAC
Yes
PETC/PESC
(6.35 mm)
.250" (pwr)
(2.54 mm)
.100" (sig)
Black LCP
Copper Alloy
Sn or Au over
31.4 A
5.7 A
650 VAC (pwr)
450 VAC (sig)
Yes
F-224
samtec.com/PowerStrip
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(6.35 mm) .250" PITCH • 40 A HIGH-POWER SYSTEM
PET
NO. PINS
PER ROW
–02, –04,
–06, –08
LEAD
STYLE
–01
PLATING
OPTION
–L
= Use with
(1.60 mm) .062"
Thick PCB
–02
OTHER
OPTION
–VT
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–SD
= Vertical
= Screw Down
(Right-angle only)
– RA
= Right-angle
(Screw Down
option required)
–T
= Use with
(3.18 mm) .125"
Thick PCB
TAIL
OPTION
= Matte Tin
PET
Board Mates:
PES
Cable Mates:
PESS
TAIL
LENGTH
A
–01
(2.35) .093
–02
(3.95) .156
1RRISRVLWLRQV[
-RA-SD
-VT
Note: Some lengths, styles
and options are non-standard,
non-returnable
PES
NO. PINS
PER ROW
–02, –04,
–06, –08
View complete specifications at: samtec.com?PET
LEAD
STYLE
–01
PLATING
OPTION
–L
= Use with
(1.60 mm) .062"
Thick PCB
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–02
–T
= Use with
(3.18 mm) .125"
Thick PCB
= Matte Tin
PES
Board Mates:
PET
TAIL
OPTION
OTHER
OPTION
–VT
–SD
= Vertical
= Screw Down
(Right-angle only)
– RA
= Right-angle
(Screw Down
option required)
TAIL
LENGTH
A
B
–01
(2.47) .097
(2.35) .093
–02
(4.07) .160
(3.95) .156
1RRISRVLWLRQV[
-VT
non-returnable
-RA-SD
View complete specifications at: samtec.com?PES
F-224
很抱歉,暂时无法提供与“PET-02-01-S-RA-SD”相匹配的价格&库存,您可以联系我们找货
