F-211-1
QTH–090–01–C–D–A
QTH–030–01–L–D–A–RT1
(0,50mm) .0197"
QTH–060–07–F–D–A
QTH SERIES
HIGH SPEED GROUND PLANE HEADER
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?QTH
Insulator Material:
Liquid Crystal
Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over 50µ" (1,27µm) Ni
Current Rating:
Contact: 1.0A @ 30°C
Temperature Rise
Ground Plane: 7.8A @ 30°C
Temperature Rise
Operating Temp Range:
-55°C to +125°C
Voltage Rating:
125 VAC (5mm Stack Height)
Max Cycles:
100
Unmating Force (-RT1 option):
-RT1 option increases
unmating force up to 50%
RoHS Compliant:
Yes
Processing:
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0,10mm) .004" max (030-060)
(0,15mm) .006" max (090-120)
Board Stacking:
For applications requiring
more than two connectors
per board or 4 banks or more,
contact ipg@samtec.com
APPLICATION
SPECIFIC OPTION
• 14mm, 15mm, 22mm and
30mm stack height
(Caution: Some automatic
placement/inspection
machines may have
component height
restrictions. Please consult
machinery specifications.)
• 30µ" (0,76µm) Gold
(Specify -H plating
for Data Rate cable mating
applications.)
• Edge Mount & Guide Posts
• 150 positions per row
Call Samtec.
Integral metal plane for
power or ground
Board Mates:
QSH
Cable Mates:
HFHM2, HQCD,
HQDP
(See Application
Specific note)
Note: Some lengths, styles
and options are non-standard,
non-returnable.
fina
sport™
Hypertran
XAUI ®
s
E
I
PC xpres
SATA
Infiniband
EXTENDED LIFE PRODUCT
10 year Mixed Flowing Gas with 50µ" Gold
Call Samtec for maximum cycles mated with QSH
5mm Stack Height
Type
Rated @ 3dB Insertion Loss
Single-Ended Signaling
–D
9 GHz / 18 Gbps
Differential Pair Signaling
–D
8 GHz / 16 Gbps
Differential Pair Signaling –DP
9.5 GHz / 19 Gbps
Performance data for other stack heights and complete
test data available at www.samtec.com?QTH or contact
sig@samtec.com
PINS PER ROW
NO. OF PAIRS
QTH
–030, –060, –090, –120
(60 total pins per bank = –D)
–020, –040, –060, –080
Polarized
notes at
Download app ppnote
/a
m
co
c.
www.samte
mtec.com
sa
IG
S
t
Contac
protocols
on
s
on
for questi
ALSO AVAILABLE
Board Spacing Standoffs.
See SO Series.
LEAD
STYLE
PLATING
OPTION
Specify
LEAD
STYLE
from
chart
–F
–D
= Gold Flash on
Signal Pins and
Ground Plane,
Matte Tin on tails
= Single-Ended
(20 pairs per bank = –D–DP)
A
TYPE
–D–DP
= Differential Pair
(–01 only)
= 10µ" (0,25µm)
Gold on Signal Pins
and Ground Plane,
Matte Tin on tails
–DP = (No. of Pairs per Row/20) x (20,00) .7875
(20,00) .7875
01
02
(0,50)
.0197
(0,20)
.008
A
A
–01 & –02
–03 thru –07
(3,30) .130
(1,57)
.062
(1,57)
.062
DIA –RT1
= Electro-Polished
Selective
50µ" (1,27µm) min Au
over 150µ" (3,81µm)
Ni on Signal Pins
in contact area,
10µ" (0,25µm) min Au
over 50µ" (1,27µm)
Ni on Ground Plane
in contact area,
Matte Tin over 50µ"
(1,27µm) min Ni
on all solder tails
–TR
–RT1
QTH
LEAD
STYLE
–01
–02
–03
–04
–05
(0,64)
.025
–L
WWW.SAMTEC.COM
= (7,00mm)
.275" DIA
Polyimide film
Pick &
Place Pad
(N/A with -05 &
-07 lead style)
= Tape & Reel
(–090 positions
maximum)
–C*
(7,11)
.280
OTHER
OPTION
–K
–L
–D = (No. of Pins per Row/30) x (20,00) .7875
(0,89)
.035
DIA
• Retention pin
option
s
ocol
Prot orted
Supp
l i nch.com
TM
(0,76)
.030
*Note: –C Plating passes
10 year MFG testing
Standard
Stack
Heights
from 5mm
to 25mm
–07
A
HEIGHT
WITH
QSH*
(4,27)
.168
(7,26)
.286
(10,27)
.404
(15,25)
.600
(18,26)
.718
(24,24)
.954
(5,00)
.197
(8,00)
.315
(11,00)
.433
(16,00)
.630
(19,00)
.748
(25,00)
.984
*Processing conditions
will affect mated height.
= Retention
Option
(–01 lead style
only & –090
positions
maximum)
–L
= Latching
Option
(–01 lead
style only)
(N/A on –090
& –120 or
–RT1 option)
