S1SD-10-28-GF-05.91-L1 数据手册
TM
MICRO
(1.00 mm) .0394" PITCH • DOUBLE ROW DISCRETE WIRE SOCKET
SERIES
S1SD
= Double Row PVC Cable
S1SDT
= Double Row
Blue *Teflon™
Fluoropolymer Cable
PINS PER ROW
–02, –03
–04, –05,
–10, –15, –20
WIRE
GAUGE
–28
= 28 AWG
–30
= 30 AWG
(Standard sizes)
PLATING
OPTION
–GF
ASSEMBLED
LENGTH
–“XX.XX”
= 3 µ" (0.07 µm)
Gold on contact
and tail
WIRING
OPTION
Double Ended Assemblies
–L1
= Assembled
Length in Inches
(45.72 mm)
01.80" min.
= Pin 1 to Pin 1
–L2
= Pin 1 to Pin 2
–L3
= Pin 1 to Pin N
–L4
= Pin 1 to Pin N-1
S1SD(T)
Single Ended Assembly
Board Mates:
T1M
Cable Mates:
T1SD(T), T1PD(T)
–L
= Latching
SPECIFICATIONS
Insulator Material:
White Nylon
Contact Material:
Phosphor Bronze
Plating:
Au over 50 µ" (1.27 µm) Ni
Operating Temp Range
(S1SD(T)/T1M):
-10 °C to +85 °C (PVC)
-40 °C to +125 °C
(*Teflon™ Fluoropolymer)
Current Rating (28 AWG):
2.3 A per pin
(2 pins powered)
Voltage Rating:
250 VAC/353 VDC
Wire:
28 or 30 AWG
SERIES
ISD1
= Double Row Body
No. of positions x
(1.00) .03937 + (4.30) .169
(5.55)
.219
(7.00)
.276
Assembled
Length
±(3.18)
.125
*Teflon™ is a trademark of
The Chemours Company
FC, LLC used under
license by Samtec.
Note:
cable is intended for
crimp only. Contact
Samtec for solderable
cable applications.
View complete specifications at: samtec.com?S1SD & samtec.com?S1SDT
SERIES
NO. OF POSITIONS
–02, –03, –04, –05, –10, –15, –20
01
CC09R
(Per Row)
PLATING
–GF
= Contact, Full Reel
(25,000 Parts per Reel)
= 3 µ" (0.07 µm) Gold
contact and tail
CC09M
No. of positions
x (1.00) .03937
+ (7.30) .287
= Contact, Mini Reel
(5,000 Parts per Reel)
(9.01)
.355
(3.81)
.150
No. of positions
x (1.00) .03937
+ (5.30) .209
TOOLING
Hand Tool: CAT-HT-309-2830-12
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
Clamp for mounting hand tool: CAT-HT-MNT-01
Mini Applicator: CAT-MC-309-2830-XX-01
View complete specifications at: samtec.com?ISD1, samtec.com?CC09R & samtec.com?CC09M
samtec.com/MicroMate
F-224 (Rev 08DEC23)
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
S1SD-10-28-GF-05.91-L1 价格&库存
很抱歉,暂时无法提供与“S1SD-10-28-GF-05.91-L1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+94.212421+12.18890
