SEAM8-40-S05.0-S-10-2-K
    SAMTEC(申泰)
    CONN HD ARRAY PLUG 400P SMD GOLD
SEAM8-40-S05.0-S-10-2-K 数据手册
ULTRA HIGH-DENSITY, HIGH-SPEED OPEN-PIN-FIELD ARRAYS (0.80 mm) .0315" PITCH FEATURES & BENEFITS (17.68) .696 (13.84) .545 • 0.80 mm (.0315") pitch grid (9.60) .378 (6.30) .248 • 50% board space savings versus .050" (1.27 mm) pitch arrays • Performance up to 28 Gbps NRZ/56 Gbps PAM4 0.80 mm pitch vs. 1.27 mm pitch (60 pins shown) • Rugged Edge Rate contact system ® • Up to 500 I/Os MAXIMUM GROUNDING & ROUTING FLEXIBILITY • 7 mm and 10 mm stack heights • Solder charge terminations for ease of processing • Lower insertion/withdrawal forces Differential Pair KEY SPECIFICATIONS Single-Ended Power PITCH STACK HEIGHTS TOTAL PINS INSULATOR MATERIAL CONTACT MATERIAL PLATING CURRENT RATING LEAD-FREE SOLDERABLE 0.80 mm 7 mm & 10 mm up to 500 I/Os Black LCP Copper Alloy Au or Sn over 50 µ" (1.27 µm) Ni 1.3 A per pin (10 adjacent pins powered) Yes Due to technical progress, all designs, specifications and components are subject to change without notice. A-221 samtec.com/Automotive Samtec shall only comply with IATF-16949 on products it certifies as Automotive Custom Design “ACD” or on those designated with “A-” Samtec part # prefix. “A-” products are designed to Samtec’s specifications not customers’ specifications. Contact autosalesgroup@samtec.com with questions. ACD IATF16949 AUTOMOTIVE CERTIFIED DESIGN CERTIFIED (0.80 mm) .0315" PITCH • ULTRA HIGH-DENSITY ARRAYS - SERIES A-SEAM8 - NO. PINS PER ROW –10, –20, –30, –40, –50 Terminal A-SEAF8 - LEAD STYLE –S02.0 = 2 mm Body Height (A-SEAM8 only) –S05.0 Socket = 5 mm Body Height (A-SEAM8 only) - PLATING OPTION –S = 30 µ" (0.76 µm) Gold on contact area, Matte Tin on solder tail NO. OF ROWS –04 –06 - SOLDER TYPE - –2 = Lead-Free Solder Crimp OPTION –GP = =Guide Post (A-SEAM8 only) –08 - K –K = Polyimide film Pick & Place Pad –05.0 = 5 mm Body Height (A-SEAF8 only) A-SEAM8 Board Mates: A-SEAF8 NO. OF ROWS No. of positions x (0.80) .0315 + (5.84) .230 A B MATED HEIGHTS* No. of positions x (0.80) .0315 + (2.56) .101 A –04 (4.30) .169 –06 (6.30) .248 –08 (8.30) .327 LEAD STYLE B -S02.0 (4.54) .179 -S05.0 (7.54) .297 A-SEAM8 LEAD STYLE A-SEAF8 LEAD STYLE –S02.0 –S05.0 –05.0 (7.00) .276 (10.00) .394 *Processing conditions will affect mated height. A-SEAF8 Board Mates: A-SEAM8 No. of positions x (0.80) .0315 + (5.84) .230 A (4.57) .180 No. of positions x (0.80) .0315 + (2.56) .101 Due to technical progress, all designs, specifications and components are subject to change without notice. samtec.com/Automotive Samtec shall only comply with IATF-16949 on products it certifies as Automotive Custom Design “ACD” or on those designated with “A-” Samtec part # prefix. “A-” products are designed to Samtec’s specifications not customers’ specifications. Contact autosalesgroup@samtec.com with questions. A-221
SEAM8-40-S05.0-S-10-2-K 价格&库存
很抱歉,暂时无法提供与“SEAM8-40-S05.0-S-10-2-K”相匹配的价格&库存,您可以联系我们找货
