02050002512
02050002512
    HARTING(浩亭)
    CONN FEMALE 28-20AWG CRIMP
02050002512 数据手册
Directory chapter 02 Page VMEbus systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 02.02 System description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 02.03 Technical characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 02.10 Male connectors . . . . . . . . . . . . . . . . . . . . . . . . . . 02.11 Female connectors . . . . . . . . . . . . . . . . . . . . . . . . 02.12 Pin shrouds . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 02.16 Application examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 02.17 har-bus 64 02 . 01 VMEbus systems har-bus 64 The past 20 years the VMEbus has reached a dominant position for industrial busses with a number of suppliers. Despite numerous new bus systems based on the rapid changes in chip technology, VMEbus systems offer significant advantages such as their robustness, reliability and increased availability of processor, memory and I/O cards. Additional advantages appear under real-time conditions, where unforeseen events have to be managed. This is realised with the program interrupt concept and variable control that closely monitors the bus system. With the increase in processing speeds and data transmission rates, 3 row DIN 41 612 connectors have reached their limit, so the VME standard needs to be enhanced further. When VME architecture was increased from 8-bit to 64-bit and data transmission rates up to 160 Mbyte/s (VME 64x), HARTING introduced with 160 pins. This Eurocard connector is 100 % backwards compatible to existing 3 row connectors with 96 contacts, therefore old can plug into new. To offer the best design possible from the start, HARTING developed spice models that were later certified via signal integrity measurements of the connector. 02 . 02 High precision slot structure with VME pinning for connector characterisation. har-bus 64 System description Backward compatibility The design of female connectors allows mating of any combinations of the 5 or 3 row versions without mechanical interference, thus making it possible for users to upgrade and maintain existing systems at lower costs. It is also possible to mate 5 row male connectors with 3 row female connectors. The feature of backward compatibility allows a gradual upgrade of existing Eurocard based systems without the additional cost of a complete system redesign. It is not necessary to replace conventional 96 pin based boards as they remain pluggable into the 160 pin based systems. Not only VMEbus, but also existing proprietary bus systems for which 3 row 96 pin connectors are no longer performance sufficient, provides the opportunity to adapt the system economically without a complete redesign to a new bus architecture. – five rows – 160 poles Two additional rows of contacts in the connector offer new system features: ● Additional contacts for I/O and system up- ● Improved signal/ground ratio for reliable grade signal data transfer at rates up to 320 MByte/s ● New voltage supplies for 3.3 V and 48 V ● Live Insertion for replacing processor or system components memory cards without closing down the system ● Identifying locations of system components ● User defined pins for test and maintenance and the bus length. “Plug & Play“ bus lines 02 . 03 System description The advantages of in detail User-defined pins in the outer rows can be used for application specific functions such as additional I/O. Configured as a shield to provide larger ground return paths, they assure for data transfer rates up to 320 MByte/s. har-bus 64 Proprietary bus systems can utilise the new contact rows to optimise signal-to-ground ratios and improve system speed. 02 . 04 Four preleading contacts (1.5 mm) serve to pre-load the transmit and receive logic so that the bus will not experience glitches during live insertion of new cards into the backplane. Backplane connector terminations are designed in solderless press-in technology. The connector can be installed without any special tooling using economical flat dies for high speed insertion. har-bus 64 The insulator, made of LCP, has an inherent flammability rating of UL 94-V0 and therefore provides an environment friendly connector. In addition, the heat deformation stability of LCP makes the connector surface-mount compatible (see chapter 00). Partially gold plated terminations with precisely formed tips serve as contact area for rear transition boards. system description rear side female connector har·bus® 64 17 mm press-in pins front side male connector har·bus® 64 female connector for crimp contacts 02 05 000 000x daughtercard female connector type C right angled female connector for har·bus® 64 male connector male connector har·bus® 64 male connector har·bus® 64 rear I/O shroud additional daughtercard transition connector right angled female test adapter female connector har·bus® 64 with switches female connector har·bus® 64 daughtercard backplane 02 . 05 System description with switches As a typical multiprocessor bus, VME has to distribute processor information continuously according to the right priorities. This is done through the well known daisy-chain lines. har-bus 64 The VME protocol requests 5 ­daisy-chains on position 1 of ­every backplane. These lines are defined to go ­through every daughter card. Therefore, in case of unloaded card slots the signal have to be ­bridged across the connector. Bridging variants: 1. The empty card slots may be assembled with dummy cards, that bridge the ­daisy-chain lines. 2. Bridging can be achieved by inserting 5 ­jumpers on the back­plane manually. 3. Bridging by using IC's with internal integration OR the ­function may accept automatic daisy­chaining. 02 . 06 4. The new 5-row connector with ­switches allows an automatic switching. In the case of an unmated daughter card the ­connector bridges the signals at positions a21-22, b4-5, b6-7, b8-9 and b10-11. The ­switch elements open automatically when the daughter card is mated, so that the ­daughter card accepts the ongoing signal daisy-chain. daughtercard male connector female connector IN OUT OR-gates 5-row connector with switches har-bus 64 Integrated switching element Status: daughter card unmated Advantages: l  Passive backplane; no active components assembled l  No additional space required, due to ­integrated switching function inside the ­connector l  No jumpers on the backplane l  User friendly regarding maintenance and ­repairing l  Automatically daisy-chaining through ­mating/unmating the daughter card l  High MTBF value l  No additional, manual bridging necessary l  Less assembly cost, no special tooling required 02 . 07 Technical characteristics Number of contacts 160 Contact spacing (mm) 2.54 Working current 1 A at 70 °C and all contacts are loaded according to IEC 61076-4-113 Current carrying capacity chart The current carrying capacity is limited by maximum temperature of materials for inserts and contacts including terminals. The current capacity curve is valid for continuous, non interrupted current loaded contacts of connectors when simultaneous power on all contacts is given, without exceeding the maximum temperature. Control and test procedures according to DIN IEC 60 512 see current carrying capacity chart Clearance and creepage distances har-bus 64 between two rows between two contacts (in a row) clearance creepage clearance creepage distance in mm rows rows female a, b, c z, d angled 1.2 1.2 0.6 1.2 1.2 0.6 1.2 1.0 0.8 1.2 1.0 0.8 Working voltage The working voltage also depends according to the safety regulations of the equipment on the clearance and creepage Explanations see chapter 00 dimensions of the pcb itself and the associated wiring Test voltage Ur.m.s. Contact resistance rows a, b, c rows z, d 1 kV Ambient temperature ≤ 20 mΩ ≤ 30 mΩ Insulation resistance ≥ 1010 Ω acc. to IEC 60 512-2 Temperature range – 55 °C … + 125 °C – 40 °C … + 105 °C acc. to IEC 60 512-11 max. + 240 °C for 20 s for SMC connectors for press-in termination During reflow soldering The higher temperature limit includes the local ambient and heating effects of the contacts under load Electrical termination pcb thickness Recommended pcb holes for press-in technology Solder pins for pcb termination Ø 1.0 ± 0.1 mm according to IEC 60 326-3 Crimp terminal 0.09 - 0.50 mm² Compliant press-in terminations ≥ 1.6 mm See recommendation page 00.25 in acc. to EN 60 352-5 Insertion and withdrawal force ≤ 160 N Materials ● Liquid Cristal Polymer (LCP), Mouldings for male connectors, straight female connectors, UL 94-V0 ● Thermoplastic resin glass-fibre filled, UL 94-V0 Contacts Copper alloy 02 . 10 Contact surface Contact zone 1) Working current minimal clearance and creepage distance Plated acc. to performance level1) Explanation performance levels see chapter 00 With selective loading higher currents can be transmitted. The requirements according to VITA 1.7 are fulfilled. with switches Deviating technical characteristics for the switching elements. minimal clearance and creepage distance clearance between two rows creepage clearance between two contacts (in a row) creepage distance in mm switching positions 0.5 0.7 0.5 0.7 Contact resistance Switching elements ≤ 60 mΩ Insertion and withdrawal force Complete connector ≤ 180 N · IEC 61 076 - 4 - 113 Number of contacts 160 Male connectors, angled, SMC compatible Identification Number of contacts Contact arrangement Part No. Performance levels according to IEC 61 076-4-113 Explanation chapter 00 2 1 Male connector* 160 z, a, b, c, d 02 01 160 2101 without retention clip 02 01 160 1101 02 01 160 11052) with retention clip 160 z, a, b, c, d 02 01 160 2102 02 01 160 1102 02 01 160 11062) Dimensions har-bus 64 mounting hole centre line row position without clip with clip Board drillings Mounting side all holes position row Cross section of solder terminations Row z: A = 0.21 - 0.25 mm² A = cross area of contacts Rows a, b, c: A = 0.29 - 0.33 mm² Row d: A = 0.29 - 0.32 mm² Dimensions in mm * Pre-leading contacts at positions d1, d2, d31 and d32 1) Recommendation for variants with clip: Drillings can be enlarged up to 3.1 mm ø to reduce standard mounting force (see chapter 00) 2) Special variant with min. 1.27 µm (50 µinch) Au and SnPb on termination 02 . 11 · IEC 61 076 - 4 - 113 Number of contacts 160 Female connectors Identification Number of contacts Contact arrangement Part No. Performance levels according to IEC 61 076-4-113 Explanation chapter 00 2 1 Female connectors, straight2) har-bus 64 with press-in terminations 3.7 mm** with fixing flange 4.5 / 5 mm** 17 mm* 160 160 160 z, a, b, c, d z, a, b, c, d 02 02 160 2201 z, a, b, c, d 02 02 160 2301 02 02 160 1601 02 02 160 1201 02 02 160 1301 without 5 mm** fixing flange 17 mm* 160 160 z, a, b, c, d z, a, b, c, d 02 02 160 1202 02 02 160 1302 02 02 160 2202 02 02 160 2302 Dimensions row position Dimension “X” for row Part number z a b c d   02 02 160 1601 3.7   3.7   3.7   3.7   3.7   02 02 160 2201 / 02 02 160 1201 5.0   4.5   4.5   4.5   5.0 02 02 160 2301 / 02 02 160 1301 17.0 17.0 17.0 17.0 17.0   02 02 160 2202 / 02 02 160 1202 5.0   5.0   5.0   5.0   5.0 02 02 160 2302 / 02 02 160 1302 17.0 17.0 17.0 17.0 17.0 Board drillings Mounting side position all holes row 02 . 12 Dimensions in mm Tooling see chapter 30 1) Press-in technology and refer to recommended configuration of pcb holes, see page 00.25 * selectively gold-plated · complementary to IEC 61 076 - 4 - 113 Number of contacts 160 Female connectors Identification Number of contacts Contact arrangement Part No. Performance level 2 according to IEC 61 076-4-113 Explanation chapter 00 160 z, a, b, c, d 02 03 160 2201 har-bus 64 Female connectors, straight with switches2) with press-in terminations 4.5 / 5 mm with flange Dimensions row position Board drillings Mounting side position all holes row Dimensions in mm Tooling see chapter 30 1) Press-in technology see page 00.25 2) Switching elements at positions a21-22, b4-5, b6-7, b8-9 and b10-11 02 . 13 · complementary to IEC 61 076 - 4 - 113 Number of contacts 160 Female connectors Identification Number of contacts Contact arrangement Part No. Performance level 1 according to IEC 61 076-4-113 Explanation chapter 00 for rear access 160 z, a, b, c, d 02 04 160 1101 for har-bus® 64 male connector 160 z, a, b, c, d 02 07 160 1101 Female connectors, angled har-bus 64 with solder pins Dimensions 02 04 160 1101 position mounting hole centre line row pcb surface Dimensions 02 07 160 1101 02 02 160 x203 intermediate plate screwed 02 04 160 1101 mounting hole centre line row centering plate position pcb surface Board drillings Mounting side row 02 . 14 position all holes Dimensions in mm · complementary to IEC 61 076 - 4 - 113 Number of contacts max. 160 Identification Female connector for crimp contacts order contacts separately fits into shell housing C see chapter 20 Number of contacts Contactarrangement Suitable for Part No. 160 har-bus® 64 shroud 02 05 000 0004 160 Male connector type R with 5 rows 02 05 000 0005 160 Male connector type C with 5 rows 02 05 000 0003 har-bus 64 Female connectors Dimensions Part No. Performance levels according to IEC 61076-4-113. Explanation chapter 00 2 1 02 05 000 2511 02 05 000 1511 Bandoliered contacts (approx. 500 pieces) 02 05 000 2512 02 05 000 1512 Individual contacts1) 02 05 000 2513 02 05 000 1513 Identification Female crimp contacts har-bus® 64 Bandoliered contacts (approx. 5 ,000 pieces) Wire gauge mm² AWG 0.09 - 0.5 28 - 20 Insulation ø mm 0.7 - 1.5 3.5 + 0.5 mm of insulation is stripped For the fabrication in line with the specification please use exclusively crimp tools approved by HARTING (see DIN EN 60 352-2) Insertion, removal and crimping tools see chapter 30 1) Packaging unit 1,000 pieces Bandoliered contacts Individual contacts 02 . 15 · complementary to IEC 61 076 - 4 - 113 III Number of contacts 160 II I Pin shrouds Identification pcb-thickness ± 0.3 Dimension X - 0.1 Part No. Pin shrouds1) har-bus 64 2.8 6.6 I 3.4 6.0 4.0 5.4 4.6 4.8 5.2 4.2 5.8 3.6 6.4 3.0 02 44 000 0007 02 44 000 0001 02 44 000 0002 02 44 000 0003 02 44 000 0004 02 44 000 0005 02 44 000 0006 II Fixing brackets for 02 44 000 0009 shell housing C2) III Shroud insert for 3 row female connectors 02 44 000 0008 Dimensions row position area for friction fit to interface pins row position 02 . 16 Dimensions in mm 1) 2) Insert block (02 09 000 0012) for assembly see chapter 30 order 2 pieces per connector · Application examples Application 1* Backplane Pin shroud 02 44 000 0007 Fixing brackets 02 44 000 0009 Female connector with crimp contacts 02 05 000 0004 Application 2* Female connector 02 02 160 2301 Shell housing C 09 05 048 0501 Locking lever left 09 02 000 9902 right 09 02 000 9903 Backplane Pin shroud 02 44 000 0007 Locking lever 09 03 000 9913 Female connector for crimp contacts 02 05 000 0004 Backplane Pin shroud 02 44 000 0007 Shroud insert 02 44 000 0008 Female connector 09 73 296 6801 har-bus 64 Female connector 02 02 160 2301 Application 3 Female connector 02 02 160 2301 02 . 17 * Only for applications without rear P0-connector · Application examples Application 4 har-bus 64 Female connector 02 02 160 2301 02 . 18 Backplane Pin shroud 02 44 000 0007 Screw M 2.5 x 30 Female connector for crimp contacts 02 05 000 0004
02050002512 价格&库存
很抱歉,暂时无法提供与“02050002512”相匹配的价格&库存,您可以联系我们找货
    • 1+2109.917681+274.28247
    • 2+2084.186072+270.93745
    • 3+2075.614383+269.82316
    • 4+2071.320274+269.26494
    • 5+2068.752065+268.93108
    • 7+2065.812257+268.54891
    • 10+2063.6073910+268.26229
    库存:1
    02050002512
      • 500+5.39114500+0.70083
      • 1000+5.133741000+0.66737
      • 1500+4.988941500+0.64855
      • 2500+4.812362500+0.62559
      • 3500+4.699463500+0.61092
      • 5000+4.582745000+0.59574
      库存:18127
      02050002512
        • 1+8.387071+1.09030
        • 10+7.1119410+0.92453
        • 25+6.6639925+0.86630
        • 50+6.3445150+0.82477
        • 100+6.04008100+0.78519
        • 250+5.66185250+0.73603
        库存:18127
        02050002512
          • 1+7.92720
          • 10+7.75440
          • 30+7.63560
          库存:24
