Staf ®
Contents
Page
Technical characteristics Staf ® . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
09.02
Staf ® 6 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
09.03
Staf ® 14 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
09.04
Staf ® 20 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
09.05
Staf ® 40 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
09.06
Staf
09
01
Staf®
Features
Features
• Degree of protection for hoods/housings for coupled
connector: IP 44
Specifications
Approvals
DIN EN 60 664-1
DIN EN 61 984
Inserts
Number of contacts
6, 14, 20, 40 (2x20)
Electrical data acc. to EN 61 984
Rated current
Rated voltage
10 A
∼ 25 V / − 60 V
Rated voltage
acc. to UL/CSA
50 V
Insulation resistance
≥ 1010 Ω
Material polyamide
Limiting temperatures
-40 °C ... +100 °C
Flammability acc. to UL 94
HB
Mechanical working life
- mating cycles
≥ 500
Staf
Contacts
Current carrying capacity
The current carrying capacity of the connectors is limited by the
thermal load capability of the contact element material including
the connections and the insulating parts. The derating curve
is therefore valid for currents which flow constantly (non-intermittent) through each contact element of the connector evenly,
without exceeding the allowed maximum temperature.
Measuring and testing techniques according to
DIN EN 60 512-5
Material
Surface
- hard-silver plated
Contact resistance
3 µm Ag
≤ 2 mΩ
Screw terminal
- Wire gauge1)
- AWG
- Tightening/test torque
1.5 mm²
16
0.25 Nm
Solder terminal
- Wire gauge1)
- AWG
2.5 mm²
14
In accordance with the appropriate regulations a wire-end sleeve
has to be used at clamps without wire protection (see „Screw
terminal“, chapter 00).
Operating current
Hoods/Housings
Accessories
Cable clamps
Coding of hoods/housings
Label acc. to CSA-approval
Ambient temperature
➀ Staf® 6
➁ Staf® 14
➂ Staf® 20
09
02
1)
geometric wire gauge
copper alloy
see chapter 30 / 31
chapter 40
chapter 40
chapter 40
Staf® 6
Size 3 A
∼ 25 / − 60 V 10 A
Number of contacts
6
Part number
Identification
Series
Screw terminal
Staf®
Female Insert (M)
Male insert (F)
Drawing
Dimensions in mm
Contact arrangement (view from termination side)
09 70 006 2813
09 70 006 2616
Staf
Solder terminal
Staf®
09 70 006 2812
09 70 006 2615
Mounting example
Stock items in bold type
09
03
Staf® 14
Size 10 A
∼ 25 / − 60 V 10 A
Number of contacts
14
Part number
Identification
Series
Screw terminal
Staf®
Female Insert (M)
Male insert (F)
09 70 014 2811
09 70 014 2614
Drawing
1)
Dimensions in mm
Distance for contact max. 24 mm
Staf
Solder terminal
Staf®
09 70 014 2810
09
04
09 70 014 2613
Panel cut out for inserts
for use without hoods/housings
Staf® 20
Size 16 A
∼ 25 / − 60 V 10 A
Number of contacts
Part number
Identification
Series
Screw terminal
Staf®
Female Insert (M)
Male insert (F)
09 70 020 2817
09 70 020 2622
Drawing
1)
Dimensions in mm
Staf
Solder terminal
Staf®
09 70 020 2816
09 70 020 2621
09
05
Staf® 40
Size 32 A
∼ 50 / − 60 V 10 A
Number of contacts
40
Part number
Identification
Series
Screw terminal
Staf®
1-20
1-20
Female Insert (M)
Male insert (F)
09 70 020 2817
09 70 020 2817
09 70 020 2622
09 70 020 2622
Drawing
1)
Dimensions in mm
Staf
Solder terminal
Staf®
1-20
1-20
09 70 020 2816
09 70 020 2816
09 70 020 2621
09 70 020 2621
09
06
很抱歉,暂时无法提供与“09 70 014 2613”相匹配的价格&库存,您可以联系我们找货
