17051332203
17051332203
    HARTING(浩亭)
    板对板连接器
17051332203 数据手册
Recommended configuration of plated through holes har-bus® HM male connector CompactPCI In addition to the hot-air-level (HAL), other PCB surfaces are getting more important. Due to their different properties - such as mechanical strength and coefficient of friction - we recommend the following configuration of PCB through holes. Drilled hole Ø Tin plated PCB (HAL) acc. to EN 60352-5 General information Design Chemical tin plated PCB IEC 61076-4-101 0,7±0,02 mm Cu min. 25µm Sn max. 15µm plated hole Ø 0,60 – 0,65mm Drilled hole Ø 0,7±0,02 mm Cu min. 25µm Sn min. 0,8µm No. of contacts 55 - 220 signal (77 - 308 fully shielded); or customised plated hole Ø 0,60 – 0,65mm Contact spacing 2,0mm Drilled hole Ø 0,7±0,02 mm Test voltage 750V AC Cu min. 25µm Contact resistance 20 mOhm max. Insulation resistance Gold /Nickel plated PCB 10 Ni 3-7µm Au 0,05-0,12µm Working current 10 Ohm min. 1 A@70°C (see derating diagram) plated hole Ø 0,60 – 0,65mm Temperature range -55°C … +125°C Drilled hole Ø 0,7±0,02 mm Termination technology compliant press-in Clearance & creepage distance 0,8 mm each for fixed connector Insertion and withdrawal force Mating cycles Silver plated PCB Cu min. 25µm Ag 0,1 – 0,3µm insertion force per contact: 0,75N max. plated hole Ø 0,60 – 0,65mm withdrawal force per contact: 0,15N min. Drilled hole Ø 0,7±0,02 mm - PL1 acc. to IEC 61076-4-101 => 500 mating cycles - PL2 acc. to IEC 61076-4-101 => 250 mating cycles UL file E102079 RoHS - compliant Yes Leadfree Yes Copper plated PCB (OSP) Cu min. 25µm plated hole Ø 0,60 – 0,65mm Circuit density Insulator material Material PC (Polycarbonate, glass fiber reinforcement 20%) Color RAL 7032 (grey) UL classification UL 94-V0 Material group acc. IEC 60664-1 IIIa (175 < CTI < 400) NFF classification I2, F1 When using the specified diameter of the finished through hole according to IEC 61 076-4-101 (0.6 ± 0.05 mm) with an appropriate annular ring, the remaining distance between the rings is about 1 mm. Under the condition that the width of the track and the space between should be equal, two tracks of 0.2 mm width or three tracks of 0.14 mm width can be placed between two rings. Typical designs are shown in the drawing on the right side. Contact material Copper alloy Treatment contact zone Bellcore recommended lubricant (PPE) Plating press-in zone Ni Plating contact zone - PL1 acc. to IEC 61076-4-101 => Au over PdNi over Ni - PL2 acc. to IEC 61076-4-101 => Au over PdNi over Ni - "S4" acc. to HARTING internal PL => min. 0,06µm Au / 0,7µm PdNi / 1,3µm Ni Derating diagram acc. to IEC 60512-5 (Current carrying capacity) The current carrying capacity is limited by maximum temperature of materials for inserts and contacts including terminals. The current capacity curve is valid for continuous, non interrupted current loaded contacts of connectors when simultaneous power on all contacts is given, without exceeding the maximum temperature. Control and test procedures according to DIN IEC 60512-5 Electrical load [A] Released / Freigegeben 2012-05-31-09:53:39:571 UTC Contact material Curve 1 shows raise in temperature Curve 2 shows nominal derating Date Curve 3 shows reduced values as per IEC512 Temperature [°C] EC01567 Mod. Subject to change without prior notice, all rights reserved Name Detail. 22/05/12 mte Inspec. 22/05/12 TD Stand. Date Name HARTING Electronics GmbH & Co. KG Technical data sheet har-bus® HM male connector DS 17 00 110 0101 Page 1 of 1
17051332203 价格&库存
很抱歉,暂时无法提供与“17051332203”相匹配的价格&库存,您可以联系我们找货
  • 1+68.85629
  • 4+67.33587
  • 7+65.87794
库存:2
17051332203
    • 13+57.01528
    • 26+54.87122
    • 52+52.82298
    • 104+50.67892
    • 260+47.79222
