20703053943
20703053943
    HARTING(浩亭)
    ETHERNETSWITCHHARTINGECON705
20703053943 数据手册
Ha-VIS eCon 7000 - Introduction and features Ethernet Switch Ha-VIS eCon 7000 Ethernet Switches, unmanaged, for use in harsh industrial environments General description Features The Ethernet Switches of the product family Ha-VIS eCon 7000 allow, according to type, the connection of up to 10 end units in industrial networks. • Ethernet Switch acc. to IEEE 802.3 Through their use, a reduction of cabling costs in the construction of industrial networks will be achieved. The Ethernet Switches facilitate any kind of network configuration. All connections are plugged, which ensures that assembly and disassembly is fast and reliable. • 5 / 10 ports ­unmanaged • Auto-crossing, Auto-negotiation, Auto-polarity • Diagnostic LEDs (Link status, Data, Power, Error) eCon 7000 Protection class, temperature range and mechanical stability meet the highest demands. These Ethernet Switches can therefore be used directly in industrial environments. • Ethernet (10 Mbit/s), Fast Ethernet (100 Mbit/s) and Gigabit Ethernet (1000 Mbit/s) • Store and Forward Switching Mode, non-blocking Advantages Application fields • High degree of protection IP 65 / IP 67 • Industrial automation • Robust metal housing • Railway applications • Can be used directly in industrial environments • Automotive industry • EMC, temperature range and mechanical stability meet the toughest demands • Wind power • PROFINET compatible A·1 39 Ha-VIS eCon 7000 Technical characteristics Ha-VIS eCon 7050-A1, eCon 7100-AA eCon 7000 Ethernet interface – RJ45 Number of ports 5x / 8x 10/100Base-T(X) 2x 10/100/1000-Base-T(X) Cable types according to IEEE 802.3 Shielded Twisted Pair (STP) or Unshielded Twisted Pair (UTP), Category 5 Data rate 10 Mbit/s, 100 Mbit/s or 1000 Mbit/s (​for Ha-VIS eCon 7100-AA only) (Han® 3 A RJ45 ) Maximum cable length 100 m (Twisted Pair, with cable Category 5 acc. to DIN EN 50 173-1) Termination, device-side Han® 3 A RJ45 (female) Diagnostics (LED) • Status Link (Link/Act) - terminal device is connected: Green data transmission in process: Green flashing • Data transfer rate (Speed) - 1000 Mbit/s: Green 100 Mbit/s: Yellow 10 Mbit/s: OFF Topology • Line • Star • mixed Power supply Input voltage 24 / 48 V DC (12 V ... 60 V DC) - redundant Termination, device-side Han® 4 A, male, for redundant power supply including fixing screw 09 20 000 9918 to maintain IP 67 Diagnostics (LED) Power supply - LED Green Alarm signalling contact (​for Ha-VIS eCon 7100-AA only) Alarm signalling contact Change-over contact, potential-free, 24 V DC / 0.5 A Termination, device-side Han® 3 A, male Diagnostics (LED) Error - Red Design features Ha-VIS eCon 7050 Ha-VIS eCon 7100 Housing material zinc die-cast zinc die-cast Dimensions (W x H x D) 45 x 120 x 87 mm (without connectors) 90 x 120 x 87 mm (without connectors) Degree of protection acc. to DIN EN 60 529 IP 65 / IP 67 IP 65 / IP 67 Assembly • • • • Wall mounting, vertical assembly Weight approx. 0.8 kg Wall mounting, vertical assembly Wall mounting, flat assembly 35 mm top-hat rail acc. to EN 60 715 Environmental conditions Stock temperature A·1 Relative humidity 40 -40 °C ... +85 °C 10 % ... +95 % (non-condensing) approx. 1.4 kg Ha-VIS eCon 7000 Technical characteristics Ha-VIS eCon 7050-B1, eCon 7100-B1 Number of ports 5x / 10x 10/100Base-T(X) Cable types according to IEEE 802.3 Shielded Twisted Pair (STP) or Unshielded Twisted Pair (UTP), Category 5 Data rate 10 Mbit/s or 100 Mbit/s (M12 D-coding) Maximum cable length 100 m (Twisted Pair, with cable Category 5 acc. to DIN EN 50 173-1) Termination, device-side M12 D-coding (female) Diagnostics (LED) • Status Link (Link/Act) - terminal device is connected: Green data transmission in process: Green flashing • Data transfer rate (Speed) - 100 Mbit/s: Yellow 10 Mbit/s: OFF Topology • Line • Star • mixed Power supply Input voltage 24 / 48 V DC (12 V ... 60 V DC) - redundant Termination, device-side M12 A-coding, male, for redundant power supply Diagnostics (LED) Power supply - LED Green eCon 7000 Ethernet interface – M12 Alarm signalling contact (​for Ha-VIS eCon 7100 only) Alarm signalling contact Change-over contact, potential-free, 24 V DC / 0.5 A Termination, device-side M12 D-coding, male Diagnostics (LED) Error - Red Design features Ha-VIS eCon 7050 Ha-VIS eCon 7100 Housing material zinc die-cast zinc die-cast Dimensions (W x H x D) 45 x 120 x 87 mm (without connectors) 90 x 120 x 87 mm (without connectors) Degree of protection acc. to DIN EN 60 529 IP 65 / IP 67 IP 65 / IP 67 Assembly • • • • Wall mounting, vertical assembly Weight approx. 0.8 kg Wall mounting, vertical assembly Wall mounting, flat assembly 35 mm top-hat rail acc. to EN 60 715 approx. 1.4 kg Environmental conditions Stock temperature -40 °C ... +85 °C Relative humidity 10 % ... +95 % (non-condensing) A·1 41 Ha-VIS eCon 7000 Ethernet Switch Ha-VIS eCon 7050-A1 5-port Ethernet Switch with extended input voltage range for use in harsh industrial environments eCon 7000 ​Unmanaged IP 65 / IP 67 ​EtherNet/IP compatible 5x 10/100Base-T(X) / Han® 3 A RJ45 (female) Input voltage / Termination Permissible range (min./max.) Input current 24 / 48 V DC / Han® 4 A, male, for redundant power supply 12 V ... 60 V DC approx. 110 mA (at 24 V DC) Housing material Dimensions (W x H x D) Weight Working temperature MTBF zinc die-cast 45 x 120 x 87 mm approx. 0.8 kg -40 °C ... +70 °C 1.150.000 h Part number Ha-VIS eCon 7050-A1 Ethernet Switch with 5 RJ45 ports 20 70 305 3923 42 X Number of ports, Copper / Termination Identification A·1 PROFINET compatible Drawing X Dimensions in mm Ha-VIS eCon 7000 Ethernet Switch Ha-VIS eCon 7050-B1 5-port Ethernet Switch for industrial Ethernet networks with extended input voltage range, with M12 system cabling IP 65 / IP 67 PROFINET compatible X ​EtherNet/IP compatible Number of ports, Copper / Termination 5x 10/100Base-T(X) / M12 D-coding (female) Input voltage / Termination Permissible range (min./max.) Input current 24 / 48 V DC / M12 A-coding, male, for redundant power supply 12 V ... 60 V DC approx. 110 mA (at 24 V DC) Housing material Dimensions (W x H x D) Weight Working temperature Approvals MTBF zinc die-cast 45 x 120 x 87 mm approx. 0.8 kg -40 °C ... +70 °C e1 1.140.000 h Identification Part number Drawing X eCon 7000 ​Unmanaged Dimensions in mm Ha-VIS eCon 7050-B1 Ethernet Switch with 5 ports M12 D-coding 20 70 305 3943 A·1 43 Ha-VIS eCon 7000 Ethernet Switch Ha-VIS eCon 7100-B1 10-port Ethernet Switch for industrial Ethernet networks, with M12 system cabling eCon 7000 ​Unmanaged IP 65 / IP 67 ​EtherNet/IP compatible 10x 10/100Base-T(X) / M12 D-coding (female) Input voltage / Termination Permissible range (min./max.) Input current Alarm signalling contact 24 / 48 V DC / M12 A-coding, male, for redundant power supply 12 V ... 60 V DC approx. 150 mA (at 24 V DC) Change-over contact, potential-free, 24 V DC / 0.5 A M12 D-coding, male Housing material Dimensions (W x H x D) Weight Working temperature MTBF zinc die-cast 90 x 120 x 87 mm approx. 1.4 kg -40 °C ... +70 °C 740.000 h Part number Ha-VIS eCon 7100-B1 Ethernet Switch with 10 ports M12 D-coding 20 70 310 3942 44 X Number of ports, Copper / Termination Identification A·1 PROFINET compatible Drawing X Dimensions in mm Ha-VIS eCon 7000 Ethernet Switch Ha-VIS eCon 7100-AA 10-port Ethernet Switch for use in harsh industrial environments, with 2 Gigabit ports IP 65 / IP 67 PROFINET compatible X ​EtherNet/IP compatible Number of ports, Copper / Termination 8x 10/100Base-T(X) / Han® 3 A RJ45 (female) 2x 10/100/1000-Base-T(X) / Han® 3 A RJ45 (female) Input voltage / Termination Permissible range (min./max.) Input current Alarm signalling contact 24 / 48 V DC / Han® 4 A, male, for redundant power supply 12 V ... 60 V DC approx. 230 mA (at 24 V DC) Change-over contact, potential-free, 24 V DC / 0.5 A Han® 3 A, male Housing material Dimensions (W x H x D) Weight Working temperature zinc die-cast 90 x 120 x 87 mm approx. 1.4 kg -40 °C ... +70 °C Identification Part number Drawing X eCon 7000 ​Unmanaged Dimensions in mm Ha-VIS eCon 7100-AA Ethernet Switch with 10 ports RJ45 20 70 310 3924 A·1 45 Ha-VIS eCon 7000 – Accessories Identification Part number Han A® Connectors and Protection covers Hood 19 20 003 14401) Metal, straight, metric Female insert 09 20 004 2711 Female insert 09 20 003 2711 Cable gland 19 00 000 5080 Protection cover 09 20 003 5426 Protection cover 09 20 003 5425 eCon 7000 Han® 4 A for power supply Han® 3 A for Alarm signalling contact (Ha-VIS eCon 7100-AA only) Metal, IP 65, metric, M20, cable ∅: 5 mm ... 9 mm Han® 3 A, female insert Han® 3 A, male insert for RJ45 interface HARAX® Connectors and Protection covers HARAX® M12-L Circular Connectors 21 03 212 2305 Protection cover M12 21 01 000 0003 A-coding for Ethernet A·1 46 1) ... Order insert fixing screw 09 20 000 9918 separately Drawing Dimensions in mm Ha-VIS eCon 7000 – Accessories Identification Part number Drawing Dimensions in mm Assembly Set for assembly on standard rail 20 80 000 0003 Set for panel mounting 20 80 010 0001 Set for panel mounting 20 80 024 0002 Set for panel mounting Ha-VIS eCon 7100 20 80 010 0002 according to DIN EN 60 715 eCon 7000 vertical assembly flat assembly vertical assembly A·1 47 eCon 7000 Notes A·1 48
20703053943 价格&库存
很抱歉,暂时无法提供与“20703053943”相匹配的价格&库存,您可以联系我们找货
