Printview: Male header with angled solder pins; 3-pole; pin spacing 3.5 mm / 0.138 in - Item No.: 20911423
0.138 in
Item No.: 2091-1423
Marking
Business data
Supplier
WAGO
Item no.
2091-1423
GTIN / EAN
4050821161080
Content
1
Order amount
200
Customer item number
Notes
Assembly of female connectors without loss of poles, allowing different functions to be divided within one male
headerCoding pins inserted into the header interface prevent mismating, allowing subsequent coding in panel
feedthrough applicationsThe female connector is fully shrouded by the male header's housing, providing vibration
resistance up to 20 g
Technical data
Miscellaneous
No. of poles
3
Pin Spacing
3.5 mm (0.0 in %)
Color
light gray
Ratings according to 1
IEC/EN 60664-1
Overvoltage category EN 1
III
Pollution degree (1)
2
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Rated voltage EN (1) [V]
160 [V]
Rated surge voltage (1) [kV]
2.5 [kV]
Nominal current [A]
10 [A]
Overvoltage category EN 2
II
Degree of pollution (2)
2
Rated voltage EN (2) [V]
320 [V]
Rated surge voltage (2) [kV]
2.5 [kV]
Nominal current (2) [A]
10 [A]
Overvoltage category EN 3
III
Degree of pollution (3)
3
Rated voltage EN (3) [V]
160 [V]
Rated surge voltage (3) [kV]
2.5 [kV]
Nominal current (3) [A]
10 [A]
Solder pin length [mm]
3.6 [mm]
Solder pin diameter [mm]
1 [mm]
Tolerance of drilled hole [mm]
1.2(+ 0.1) [mm]
Material group
I
Insulating material
Polyphtalamid (PPA GF)
Flammability rating per UL 94
V0
Limit temperature range
-60 C … 100 C
Contact material
Electrolytic copper (Ecu)
Contact plating
tin-plated
Fire load [MJ]
0.026 [MJ]
Weight [g]
1.28 [g]
Width
12.5 mm / 0.492 in
Height
16 mm / 0.63 in
Height from the surface
12.4 mm / 0.488 in
Length
17.5 mm / 0.689 in
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“2091-1423”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 20+5.1140120+0.61689
- 50+5.0901250+0.61401
- 200+5.09000200+0.61400
- 500+5.08989500+0.61398
- 2000+5.089772000+0.61397
