F-219
LPHS–04–24–L–RT1–GP
LPHS–04–24–L–VP1–GP
(12.00 mm) .472"(PWR) (1.27 mm) .050"(SIG)
LPHS SERIES
EXTreme LPHPower SOCKET ASSEMBLY
Mates with:
LPHT
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?LPHS
–RT1
B
= Right-angle Through-hole
(Use with (1.60 mm) .062"
thick board)
(12.00) .472
(5.08)
.200
(5.08)
.200
(12.29)
.484
(0.64)
.025
(2.50)
.098 (2.58) (3.33)
.102 .131
(4.50)
.177
(4.53)
.178
(1.27)
.050
(2.51)
.099
LPHS–04–24–L–VP1–GP
SIGNAL
POSITIONS
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
–16
–20
–24
FILE NO. E111594
–32
APPLICATION
(0.38)
.015
(5.72)
.225
POWER POSITIONS
A
B
A
(–02)
(–02)
(–04)
(31.64)
1.918
(34.18)
1.346
(36.72)
1.446
(41.80)
1.646
(25.88)
1.019
(28.42)
1.119
(30.96)
1.219
(36.04)
1.419
(MOQ Required)
B
(–04)
A
(–06)
B
(–06)
A
(–08)
B
(–08)
A
(–10)
B
(–10)
(43.64) (37.88) (55.64) (49.88) (67.64) (61.88) (79.64) (73.88)
1.718 1.491 2.191 1.964 2.633 2.436 3.135 2.909
(46.18) (40.42) (58.18) (52.42) (77.18) (64.42) (82.18) (76.42)
1.818 1.591 2.291 2.064 2.763 2.536 3.235 3.009
(48.72) (42.96) (60.72) (54.96) (72.72) (66.96) (84.72) (78.96)
1.918 1.691 2.391 2.164 2.863 2.636 3.335 3.109
(53.80) (48.04) (65.80) (60.04) (77.80) (72.04) (89.80) (84.04)
2.118 1.891 2.591 2.364 3.063 2.836 3.535 3.309
A
ALSO AVAILABLE
CREEPAGE
AND
CLEARANCE
(12.00) .472
(7.49)
.295
(1.27) .050
(0.46)
.018
(0.64)
.025 SQ
Notes:
Series is rated
up to 60 A per power bank.
* EXTreme LPHPower™
is a trademark of Molex
Incorporated.
–RT2
(Use with (2.36 mm) .093"
thick board)
(5.11)
.201
(5.83)
.230
(18.00)
.709
(15.21)
.599
Lead–Free Solderable: Yes
(-RT1 & -RT2 option)
The Molex EXTreme
LPHPower™ line is a
second source to the
Samtec LPHS Series
–VP1
= Vertical Press-fit
(Total, 2 per power bank)
PROCESSING
Some lengths, styles and
options are non-standard,
non-returnable.
–L
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
(Total)
GP
TAIL
PLATING
–16, –20,
–24, –32
–02, –04,
–06, –08, –10
Insulator Material:
Black LCP
Terminal Material:
Signal: Brass
Power: Copper Alloy
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
Power: 30 A per power blade
(4 blades powered)
Signal: 1 A per signal contact
Operating Temp Range:
-40 °C to +105 °C
Voltage Rating: 250 VAC
Standard Creepage:
(2.86 mm) .113"
(with -VP1 power)
(5.63 mm) .222"
(with -RTX power)
Standard Clearance:
(2.69 mm) .105"
(with -VP1 power)
(1.36 mm) .054"
(with -RTX power)
RoHS Compliant: Yes
• Other platings
• 28 Signal positions
• No Guide post
SIGNAL
POSITIONS
POWER
POSITIONS
LPHS
Selectively loading
contacts achieves customer
specific creepage and
clearance requirements.
Contact asp@samtec.com
(2.50) .098
(21.42)
.843
(3.30)
.130
DIA
(6.83)
.269
(3.07)
.121
DIA
(3.30) .130 DIA
(2.46) .097
(3.84) .151
LPHS–04–24–L–RTX–GP
(3.07)
.121
DIA
TOOLING
(9.20)
.362
(3.25)
.128
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
• Press-Fit
CAT-PT-LPHS-XX-XX
For more information, visit
www.samtec.com/tooling
LPHS-04-32-L-VP1-GP 价格&库存
很抱歉,暂时无法提供与“LPHS-04-32-L-VP1-GP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+95.128101+12.33042
