LS2-115-02-L-D-A
LS2-115-02-L-D-A
    SAMTEC(申泰)
    SMD,P=2mm
    板对板连接器 SMT
LS2-115-02-L-D-A 数据手册
SELF MATING HERMAPHRODITIC STRIP (2.00 mm) .0787" PITCH • LS2 SERIES LS2 LS2 Mates: LS2 SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: 3.2 A per pin (6 adjacent pins powered) Voltage Rating: 475 VAC mated with LS2 Operating Temp Range: -55 °C to +125 °C - 1 - NO. PINS PER ROW 05, 10, 15, 20, 25, 30 - LEAD STYLE –01 =Throughhole –02 = Surface Mount PLATING OPTION - –F D - TAIL OPTION –01 only = Gold flash on contact, Matte Tin on tail –RA1 = Right-angle (Shroud Down) –L –RA2 = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail = Right-angle (Shroud Up) OPTION –K = (6.30 mm) .248" DIA Polyimide Film Pick & Place Pad (–02 only) –TR = Tape & Reel –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.15 mm) .006" max* *(.004" stencil solution may be available; contact ipg@samtec.com) - No. of positions x (2.00) .0787 + (1.57) .062 (5.27) .208 APPLICATION Through-Hole (-01) =(9.65 mm) .380" (6.35) .250 (8.38) .330 Surface Mount (-02) =(13.71 mm) .540" (6.83) .269 STYLE —02 No. of positions x (2.00) .0787 + (1.57) .062 —RA1 (5.27) .208 —RA2 ALSO AVAILABLE MOQ Required (6.35) .250 Alignment pin Other platings Other stack heights STYLE —01 —RA1 —RA2 Note: Some lengths, styles and options are non-standard, non-returnable. F-224 samtec.com?LS2 Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
LS2-115-02-L-D-A 价格&库存
很抱歉,暂时无法提供与“LS2-115-02-L-D-A”相匹配的价格&库存,您可以联系我们找货
LS2-115-02-L-D-A
  • 18+53.3182318+6.87375
