TIGER CLAW™
SOCKET STRIP
8
G b p s
(2.00 mm) .0787" PITCH • MMS SERIES
MMS
Board Mates:
TMMH, TMM,MTMM, MMT,
TW, LTMM, ZLTMM, TSH
Cable Mates:
TCMD
SPECIFICATIONS
Insulator Material:
Black LCP
Contact Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating (MMS/TMM):
3.9 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Insertion Depth:
DH = (2.13 mm) .084" to
(2.79 mm) .110"
SH = (2.13 mm) .084"
minimum or pass-through
Top Entry DV/SV =
(2.13 mm) .084" to
(4.32 mm) .170"
Bottom Entry DV/SV =
(4.27 mm) .168" minimum
(Plus board)
MMS
NO. PINS
PER ROW
01
02 thru 40
(2.00)
.0787
PLATING
OPTION
–F
–L
= 10 µ" (0.25 µm)
Gold contact,
Matte Tin on tail
—SV
–SH
= Single
Horizontal
–DV
—DH
No. of positions x
(2.00) .0787 + (0.56) .022
(4.45)
.175
—DH
—SH
—DV
—SV
MMS
-1
NO. PINS
PER ROW
02 thru 40
—DV
—SH
—SV
02
(2.00)
.0787
PLATING
OPTION
–F
—SV
ROW
OPTION
= Polarized Position
–K
–SH
= (5.50 mm) .217" DIA
Polyimide Film
Pick & Place Pad
(3 positions min.)
(–SV & –DV only)
= Single
Horizontal
–DV
= Double
Vertical
—SH
–M
= Metal Pick & Place Pad
(4 positions min.)
(–DV only)
–DH
= Double
Horizontal
–P
= Plastic Pick & Place Pad
(4 positions min.)
(–SV & –DV only)
(4.17)
.164
(4.00)
.157
—DH
—P
(1.22)
.048
—M
(1.22)
.048
(1.39)
.055
(1.39)
.055
(4.50)
.177
—SV
OTHER
OPTION
–“XX”
= Single
Vertical
= 10 µ" (0.25 µm)
Gold contact,
Matte Tin on tail
(3.05)
.120
—DH
–SV
= Gold flash
on contact,
Matte Tin on tail
(2.16)
.085
(2.92)
.115
(3.05)
.120
(2.92)
.115
No. of positions x
F-224 (Rev 10NOV23)
–“XX”
= Polarized
Position
= Double
Horizontal
—DV
—DV
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
OPTION
–DH
(4.00)
.157
MOQ Required
Alignment Pin (–DV only)
Locking clips and Through-hole
pass-through options
Other platings
–SV
= Single
Vertical
= Double
Vertical
–L
ALSO AVAILABLE
ROW
OPTION
= Gold flash on contact,
Matte Tin on tail
—SH
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.15 mm) .006" max*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
-1
—SH
—DV
–TR
= Tape & Reel
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
—DH
samtec.com?MMS
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“MMS-117-02-F-DV”相匹配的价格&库存,您可以联系我们找货
