21033821401
21033821401
    HARTING(浩亭)
    Conn M12 Circular PIN 4 POS IDT ST Cable Mount 4 Terminal 1 Port
21033821401 数据手册
Product data sheet 21 03 382 1401 M12-PP-CC-IDC-4P-DCOD-M-STR-SHLD M12-PP-CC-IDC-4P-DCOD-M-STR-SHLD Part number 21 03 382 1401 Specification M12-PP-CC-IDC-4P-DCOD-M-STRSHLD HARTING eCatalogue https://b2b.harting.com/21033821401 Image is for illustration purposes only. Please refer to product description. Identification Category Connectors Series Circular connectors M12 Identification PushPull Element Cable connector Specification Straight Version Termination method HARAX® connection technology Gender Male Shielding Shielded Number of contacts 4 Coding D-coding Locking type Outer PushPull Details For Fast Ethernet applications only Technical characteristics Conductor cross-section 0.34 mm² Conductor cross-section AWG 22 Wire outer diameter ≤1.6 mm Rated current 4 A Rated voltage 50 V Rated impulse voltage 1.5 kV Pollution degree 3 Page 1 / 3 | Creation date 2024-03-13 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com Product data sheet 21 03 382 1401 M12-PP-CC-IDC-4P-DCOD-M-STR-SHLD Technical characteristics Transmission characteristics Cat. 5 Class D up to 100 MHz Overvoltage category III Data rate 10 Mbit/s 100 Mbit/s Insulation resistance >108 Ω Contact resistance ≤10 mΩ Limiting temperature -40 ... +85 °C Mating cycles ≥100 Degree of protection acc. to IEC 60529 IP65 / IP67 mated condition Cable diameter 5.7 ... 8.8 mm Isolation group I (600 ≤ CTI) Material properties Material (insert) Polyamide (PA) Material (contacts) Copper alloy Surface (contacts) Au over Ni Mating side Material (hood/housing) Zinc die-cast RoHS compliant with exemption RoHS exemptions 6(c): Copper alloy containing up to 4 % lead by weight ELV status compliant with exemption China RoHS 50 REACH Annex XVII substances Not contained REACH ANNEX XIV substances Not contained REACH SVHC substances Yes REACH SVHC substances Lead ECHA SCIP number 0d7d3693-d625-47ab-934a-d241bf72c86e California Proposition 65 substances Yes California Proposition 65 substances Lead Nickel Naphthalene Specifications and approvals Specifications IEC 61076-2-101 IEC 61076-2-010 Page 2 / 3 | Creation date 2024-03-13 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com Product data sheet 21 03 382 1401 M12-PP-CC-IDC-4P-DCOD-M-STR-SHLD Specifications and approvals UL / CSA UL 2238 CYJV2.E302521 CSA-C22.2 No. 182.3 CYJV8.E302521 PROFINET Yes Commercial data Packaging size 1 Net weight 54.8 g Country of origin Romania European customs tariff number 85366990 GTIN 5713140226807 ETIM EC002635 eCl@ss 27440116 Circular connector (for field assembly) Page 3 / 3 | Creation date 2024-03-13 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com
21033821401 价格&库存
很抱歉,暂时无法提供与“21033821401”相匹配的价格&库存,您可以联系我们找货
    • 1+474.856841+59.60750
    • 10+411.2125210+51.61840
    • 50+383.3962650+48.12670
    • 1+503.800461+63.24072
    • 10+428.1801110+53.74830
    • 25+401.3885225+50.38522
    • 50+382.2470550+47.98245
    • 100+364.02359100+45.69490
    • 250+348.19365250+43.70781
    库存:2
