231-133/001-000
231-133/001-000
    WAGO(万可电子)
    接线端子
231-133/001-000 数据手册
Male Headers with Solder Pins MCS MIDI Classic 6 391 With 1 x 1 mm straight solder pins Pin spacing: 5 mm / 0.197 in. 320 V/4 kV/2 12 A With 1.2 x 1.2 mm straight solder pins Pin spacing: 5 mm / 0.197 in. 300 V/10 A 320 V/4 kV/2 16 A 300 V/15 A With 1 x 1 mm angled solder pins Pin spacing: 5 mm / 0.197 in. 320 V/4 kV/2 12 A >3,8< L = (pole no. – 1) x pin spacing + 8.2 mm Pole No. Item No. 231-132/001-000 231-133/001-000 231-134/001-000 231-135/001-000 231-136/001-000 231-137/001-000 231-138/001-000 231-139/001-000 231-140/001-000 231-141/001-000 231-142/001-000 231-143/001-000 231-144/001-000 231-145/001-000 231-146/001-000 231-147/001-000 231-148/001-000 231-149/001-000 231-150/001-000 231-151/001-000 231-152/001-000 231-153/001-000 231-154/001-000 7,5 < Pack. Unit 200 200 200 200 100 100 100 100 100 100 100 50 50 50 50 50 50 50 50 50 50 50 50 Pole No. 6,5 (_10 _) 5 6 L = (pole no. – 1) x pin spacing + 8.2 mm L1 = L + 5 mm L2 = L1 + 7.4 mm Pack. Unit Male header with 1.2 x 1.2 mm straight solder pins, gray  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 4,1 > 4,1< > 4,1< < _____ L _____> Item No. 4,1 5 5 3,8 ___> > 5< L = (pole no. – 1) x pin spacing + 8.2 mm Male header with 1 x 1 mm straight solder pins, gray  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 >3,8< > 8,4 < 3,8 > 4,1< > 4,1< < _____ L _____> > 5< > 5 > 8,4 < 3,8 > 5 300 V/10 A 231-162/001-000 231-163/001-000 231-164/001-000 231-165/001-000 231-166/001-000 231-167/001-000 231-168/001-000 231-169/001-000 231-170/001-000 231-171/001-000 231-172/001-000 231-173/001-000 231-174/001-000 231-175/001-000 231-176/001-000 231-177/001-000 231-178/001-000 231-179/001-000 231-180/001-000 231-181/001-000 231-182/001-000 231-183/001-000 231-184/001-000 1 M  CS MIDI male headers with straight solder pins are also available with 3.8 mm pin projection upon request. Replace item no. suffix: . . . /001-000 with . . . /046-000. Pole No. Item No. Pack. Unit Male header with 1 x 1 mm angled solder pins, gray 200 200 200 200 100 100 100 100 100 100 100 50 50 50 50 50 50 50 50 50 50 50 50  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 231-432/001-000 231-433/001-000 231-434/001-000 231-435/001-000 231-436/001-000 231-437/001-000 231-438/001-000 231-439/001-000 231-440/001-000 231-441/001-000 231-442/001-000 231-443/001-000 231-444/001-000 231-445/001-000 231-446/001-000 231-447/001-000 231-448/001-000 231-449/001-000 231-450/001-000 231-451/001-000 231-452/001-000 231-453/001-000 231-454/001-000 200 200 200 200 100 100 100 100 100 100 100 50 50 50 50 50 50 50 50 50 50 50 50
231-133/001-000 价格&库存
很抱歉,暂时无法提供与“231-133/001-000”相匹配的价格&库存,您可以联系我们找货
    • 1+5.29200
    • 10+4.17960
    • 30+3.62880
    库存:89
