24FLZ-RSM2-TB(LF)(SN)(P)
    JST
24FLZ-RSM2-TB(LF)(SN)(P) 数据手册
Emboss Tape FLZ CONNECTOR 0.5mm pitch/Connectors for FFC and FPC Specifications ––––––––––––––––––– HJ ST This extremely small 0.5mm pitch connector with a height of only 2.0mm above the PCB surface allows interconnection in extremely small spaces and is an example of JST's leading edge technology. • Zero insertion force mechanism • Heat resisting design suitable for surface mounting • In-line surface mount tails • Two types of connections • Embossed tape for automatic mounting • Current rating: 0.5A AC, DC • Voltage rating: 50V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/40m Ω max. After environmental testing/60m Ω max. • Insulation resistance: 800M Ω min. • Withstanding voltage: 200V AC/minute • Applicable FFC and FPC: Conductor pitch/0.5mm Conductor width/0.35mm Mating part thickness/0.3±0.03mm Note: FFC and FPC to be actually used should be checked for applicability. * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 Inner lock type 3.75 3.3 ±0.1 2.05 0.35 ±0.1 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.03mm for all centers. 3. The dimensions above should serve as a guideline. Contact JST for details. 1 5.1 0.7 2 FPC 0.6 2.1±0.1 FPC (2.95) 2 0.4 (0.7) 1.5 4.6 1.55 0.3±0.05 1.65 1.2±0.1 0.35 ±0.05 0.5±0.03 2.85 2.5 min 0.5 ±0.03 FLZ CONNECTOR Connector Normal type Circuits 6 7 B A 8 3.2 4.6 0.5 (0.7) 9 11 12 0.2 FJST 2 1.9 10 13 14 15 16 Reverse type 17 18 19 B A (0.7) 4.6 3.2 20 21 0.5 23 2 1.9 22 FJST 0.2 24 25 26 27 28 30 33 Normal type Model No. Normal type Reverse type 06FLZ-SM2-TB 06FLZ-RSM2-TB 07FLZ-SM2-TB 07FLZ-RSM2-TB 08FLZ-SM2-TB 08FLZ-RSM2-TB 09FLZ-SM2-TB 09FLZ-RSM2-TB 10FLZ-SM2-TB 10FLZ-RSM2-TB 11FLZ-SM2-TB 11FLZ-RSM2-TB 12FLZ-SM2-TB 12FLZ-RSM2-TB 13FLZ-SM2-TB 13FLZ-RSM2-TB 14FLZ-SM2-TB 14FLZ-RSM2-TB 15FLZ-SM2-TB 15FLZ-RSM2-TB 16FLZ-SM2-TB 16FLZ-RSM2-TB 17FLZ-SM2-TB 17FLZ-RSM2-TB 18FLZ-SM2-TB 18FLZ-RSM2-TB 19FLZ-SM2-TB 19FLZ-RSM2-TB 20FLZ-SM2-TB 20FLZ-RSM2-TB 21FLZ-SM2-TB 21FLZ-RSM2-TB 22FLZ-SM2-TB 22FLZ-RSM2-TB 23FLZ-SM2-TB 23FLZ-RSM2-TB 24FLZ-SM2-TB 24FLZ-RSM2-TB 25FLZ-SM2-TB 25FLZ-RSM2-TB 26FLZ-SM2-TB 26FLZ-RSM2-TB 27FLZ-SM2-TB 27FLZ-RSM2-TB 28FLZ-SM2-TB 28FLZ-RSM2-TB 30FLZ-SM2-TB 30FLZ-RSM2-TB ― 33FLZ-SM2-TB Dimensions (mm) A B Q'ty / reel 2.5 8.9 2,800 3.0 9.4 2,800 3.5 9.9 2,800 4.0 10.4 2,800 4.5 10.9 2,800 5.0 11.4 2,800 5.5 11.9 2,800 6.0 12.4 2,800 6.5 12.9 2,800 7.0 13.4 2,800 7.5 13.9 2,800 8.0 14.4 2,800 8.5 14.9 2,800 9.0 15.4 2,800 9.5 15.9 2,800 10.0 16.4 2,800 10.5 16.9 2,800 11.0 17.4 2,800 11.5 17.9 2,800 12.0 18.4 2,800 12.5 18.9 2,800 13.0 19.4 2,800 13.5 19.9 2,800 14.5 20.9 2,800 16.0 22.4 2,800 B Circuits A 3.6 5.1 0.7 13 0.5 30 32 1.9 FJST 0.2 34 36 40 42 Reverse type 45 50 Dimensions (mm) Model No. Normal type Reverse type A B 13.1 ― 13FLZ-RSM2-R-TB 6.0 21.6 30FLZ-SM2-R-TB ― 14.5 22.6 32FLZ-SM2-R-TB 32FLZ-RSM2-R-TB 15.5 23.6 34FLZ-SM2-R-TB 34FLZ-RSM2-R-TB 16.5 24.6 36FLZ-SM2-R-TB 36FLZ-RSM2-R-TB 17.5 26.6 40FLZ-SM2-R-TB 40FLZ-RSM2-R-TB 19.5 27.6 42FLZ-SM2-R-TB ― 20.5 29.1 45FLZ-SM2-R-TB ― 22.0 31.6 50FLZ-SM2-R-TB ― 24.5 Q'ty / reel 2,800 2,800 2,800 2,800 2,800 2,800 2,800 2,800 2,800 B A 5.1 3.6 Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) Slider housing: PA 6T, UL94V-0 (black) Housing: PA 6T, UL94V-0 Nomal type...gray Reverse type...natural Solder tab: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) 1.9 0.2 FJST Material and Finish 0.7 0.5 RoHS compliance This product displays (LF)(SN) on a label. Note: The products listed above are supplied on embossed tape. Lead section dimensions of FFC and FPC 0.5× (N+1)±0.05 0.5 ±0.1 0.5 ±0.1 0.35 ±0.04 0.3 ±0.03 (5.5) 3 min 0.5 ±0.03 ±0.03 0.5×(N−1) Conductor Reinforcing layer Cover layer Note: N --- Number of circuits Base layer 2
24FLZ-RSM2-TB(LF)(SN)(P) 价格&库存
很抱歉,暂时无法提供与“24FLZ-RSM2-TB(LF)(SN)(P)”相匹配的价格&库存,您可以联系我们找货
