Ha-VIS eCon 2000 Full Gigabit Ethernet Basic PoE / PoE+
4 to 7 Ethernet ports RJ45, FOC, and PoE / PoE+
English
Unmanaged Plug and Play Ethernet switches for DIN rail assembly in control
cabinets
Commercial temp.: 0 °C ... +55 °C / Industrial temp.: -40 °C ... +70 °C
Energy
Efficient
Ethernet
■ Energy supply of up to 4 terminal devices via PoE+ (137 watts) in ac-
cordance with IEEE 802.3at
■ Full Gigabit Ethernet non-blocking switch architecture according to IEEE 802.3
■ Support of jumbo frames (10 kB)
■ Variants with industrial temperature range of -40 °C ... +70 ° C
■ Wide range power supply 24/48 VDC
■ Surge protection and reverse polarity protection
■ Minimum energy consumption due to energy-efficient Ethernet
Target markets
Machinery & Robotics
Automation
Industrial network
infrastructures
Wind Energy,
Solar Energy
Transportation
Shipbuilding
General description
The Ha-VIS eCon 2000 Full Gigabit family of unmanaged Ethernet switches
is equipped with up to 7 gigabit Ethernet ports and allow for cost-efficient
and quick expansion and/or reconstruction of network infrastructures
with high bandwidth requirements. In this, all variants support extra-long
Ethernet frames (jumbo frames). The switches work as power sourcing
equipment (PSE) and are capable of simultaneously providing the full
PoE output of 34.2 watts on up to four ports. Due to the extremely flat
design, these switches can be accommodated in installations where space
is restricted towards the cable connection at the front. The selection
includes various combinations of variants with RJ45 and fibre optic ports.
Automatic detection of the transmission rate (auto-negotiation) and of the
wiring of the twisted pair data cable (auto-polarity and auto-MDI(X)) allow for
simple plug and play. All variants are available with the temperature ranges
"Industrial" and "Commercial".
Technical characteristics
Switch features
Ethernet ports 10BASE-T / 100BASE-TX EEE / 1000BASE-TX EEE
Enclosure width
120 mm
Type of connection
RJ45
Auto-negotiation
Yes
Store and Forward
Auto-polarity
Yes
Supported standards
IEEE 802.3
Frame size
Auto-MDI(X)
10 kBytes
MAC table size
Transfer conditions
8k entries
Transfer speed
10 / 100 / 1000 Mbit/s
Transfer length
100 m (Twisted Pair, Cat 5)
Number of interfaces
5, 7
Switching technology
Packet buffer size
1 Mbit
Non-blocking
Yes
Quality of Service
Yes
Energy-efficient Ethernet
Yes
PROFINET-compatible
Yes
EthernetIP-compatible
Yes
Ethernet ports 1000BASE-SX / 1000BASE-LX
Type of fibre
24 VDC
48 VDC
Surge protection
Yes
Reverse polarity proof
Yes
Starting current
3.2 A
Overcurrent protection at input
54 VDC
9 VDC ... 60 VDC
6.40 A
Yes (4 A)
Max. power consumption
@ 24 VDC
3.60 W ... 4.80 W
Conductor cross-section
0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG)
Type of connection
Pinout
3-pole, pluggable screw type terminal block
Supply circuit (according to 60950)
Transfer length
Input sensitivity
7.20 A
SELV (circuit breaker 10 A)
HARTING Technology Group
P.O.Box 1473, D-32325 Espelkamp
Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany
ICPN-Service@harting.com | Service hotline: +49 5772 47-9479
Fax: +49 5772 47-495 | www.HARTING.com/de/ethernet-switches
FOC
850 nm
Transfer speed
Output power
Single-mode (SM)
SC Duplex
Transfer conditions
Wavelength
Permissible voltage range
Multi-mode (MM)
Type of connection
Power supply
Nominal voltage
Yes
Twisted pair
1310 nm
1000 Mbit/s
0.55 km
10 km
-9.5 dBm ... -4 dBm
-9.5 dBm ... -3 dBm
≤ -17 dBm
≤ -21 dBm
Environmental conditions
Commercial temperature range
Industrial temperature range
Storage temperature range
0 °C ... +55 °C
-40 °C ... +70 °C
-40 °C ... +85 °C
Relative humidity (operation)
0% ... 95 % (non-condensing)
Relative humidity (storage and
transport)
Air pressure
2000 m (795 hPa)
Note: We reserve the right to make technical changes to the products and to the content of this
document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the
rights to this document and the topics and illustrations contained within it. Copying, disclosure to
third parties or use of its content - even partially - is forbidden without the prior written consent
of the HARTING Technologiegruppe.
PoE
Enclosures
Number of PoE ports
4
Standard
IEEE 802.3af / IEEE 802.3at
PoE type
PSE
Supported mode
Alternative A
Power supply PSE
48 VDC
Maximum Power consumption
Maximum output power PSE
54 VDC
375 mA
638 mA
15.4 W per port
61.6 W total
34.2 W per port
136.8 W total
Supported cabling
See 802.3at, section 33.1.4
PoE pinout
Alternative A, MDI-X (1/2 = V-, 3/6 = V+)
Status and diagnostic displays
Power ("Pwr")
illuminated green
Supply voltage is applied
Link/Activity ("L/A") off
No link
Link/Activity ("L/A") illuminated green
Link/Activity ("L/A") flashes green
Link is active
Link is active and data is transferred
Link speed ("Spd") off
10 Mbit/s
Link speed ("Spd") illuminated yellow
100 Mbit/s
Link speed ("Spd") illuminated green
PoE status off
Enclosure width
Dimensions H x W x D (without
block and holding bracket)
120 mm
113.5 mm x 120 mm x 27.3 mm
Weight
410 g ... 442 g
Type of installation
35 mm DIN rail acc. to EN 60 715
Material enclosures
Anodised aluminium
Protection class (with pluggable
screw type terminal block)
IP30
Protection class
III
Approvals
CE, FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK, ABB IIT
EMC and environmental conditions
EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024)
Electrostatic discharge (ESD) EN 61 000-4-2
Electromagnetic field EN 61 000-4-3
Rapid transients (burst) EN 61 000-4-4
Surge voltages EN 61 000-4-5
Conducted interference voltages EN 61 000-4-6
EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15)
1000 Mbit/s
PoE is inactive / low voltage
PoE status illuminated green
Voltage in PoE range
PoE status illuminated blue
Voltage in PoE+ range
PoE status illuminated red
Fault
Mechanical stability (EN 60721-3)
IEC 60068-2-6 Vibration
IEC 60068-2-6 Resonance search
IEC 60068-2-27 Shock test
Included in delivery
■ Pluggable screw type terminal block for power supply
■ Installation instructions
Drawings
Technical characteristics / order information
Ports / order information
Enclosure
width
Power consumption @ 24
VDC
without PoE
MTBF
in million h
RJ45
SFP
SC
4
3x MM (0.55 km)
120 mm
0.19 A
0.98
Ha-VIS eCon 2043GB-AD-P 24 02 404 3130 Ha-VIS eCon 2043GBT-AD-P
24 02 404 3120
4
3x SM (10 km)
120 mm
0.20 A
0.98
Ha-VIS eCon 2043GB-AF-P
24 02 404 3230 Ha-VIS eCon 2043GBT-AF-P
24 02 404 3220
5
120 mm
0.15 A
1.01
Ha-VIS eCon 2050GB-A-P
24 02 405 0030 Ha-VIS eCon 2050GBT-A-P
24 02 405 0020
5
2x MM (0.55 km)
120 mm
0.19 A
0.98
Ha-VIS eCon 2052GB-AD-P 24 02 405 2130 Ha-VIS eCon 2052GBT-AD-P
24 02 405 2120
5
2x SM (10 km)
120 mm
0.20 A
0.98
Ha-VIS eCon 2052GB-AF-P
24 02 405 2230 Ha-VIS eCon 2052GBT-AF-P
24 02 405 2220
6
1x MM (0.55 km)
120 mm
0.19 A
0.98
Ha-VIS eCon 2061GB-AD-P
24 02 406 1130 Ha-VIS eCon 2061GBT-AD-P
24 02 406 1120
6
1x SM (10 km)
120 mm
0.20 A
0.98
Ha-VIS eCon 2061GB-AF-P
24 02 406 1230 Ha-VIS eCon 2061GBT-AF-P
24 02 406 1220
7
120 mm
0.19 A
0.98
Ha-VIS eCon 2070GB-A-P
24 02 407 0030 Ha-VIS eCon 2070GBT-A-P
24 02 407 0020
Copyright© 2014
All rights reserved
Date of issue 02.2015
ICPN Datasheet 0840/01
Switch
Part no.
Switch
Part no.
很抱歉,暂时无法提供与“24024050030”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6193.677821+801.24678
- 国内价格
- 1+4977.05065
- 5+4621.54361
