280-530
280-530
    WAGO(万可电子)
280-530 数据手册
Data sheet Item no.: 280-530 Product description: DOUBLE DECK TERMINAL BLOCK WITH HORIZONTAL JUMPERING ON LOWER LEVEL THROUGH/THROUGH SUITABLE FOR EX I APPLICATIONS Packing unit 50 pieces Product group Number of levels Cross section [mm ²] Cross section [AWG] Connection method Measured voltage EN Measured shock voltage Pollution degree Current intensity EN Weight Color Wiring type No. of connection Points No. of potentials Height Height Width Width Depth Depth Strip length from Strip length to Strip length Mounting © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 1 (Rail Mounted Terminal Blocks) 2 0.08 - 2.5 mm² 28 - 12 AWG CAGE CLAMP® CONNECTION 500 V 6 kV 3 20 A 10.677 g blue Front- entry 4 2 58.5 mm 2.3 in 5 mm 0.197 in 74 mm 2.91 in 8 mm 9 mm 0.33 in TS 35
280-530 价格&库存
很抱歉,暂时无法提供与“280-530”相匹配的价格&库存,您可以联系我们找货
